[debian]Mldonkey start niet!
  • 131 views sinds 30-01-2008
dit is de foutmelding die ik krijg!
Set niceness of the process: 0
Set uid/gid of the process (1000, 1000)
Set umask of the process: 18
Chdir to home dir: /home/midian/.mldonkey
Writing PID (2766) to pidfile: /home/midian/.mldonkey/mldonkey.pid
Launching MLnet process
/usr/bin/mlnet: error while loading shared libraries: libgd.so.2: cannot open shared object file: No such file or directory
Process PID ( 2767 ) exit with return code 127
Process respawning too fast : only live 0.
Stopping processes PID ( 2767 0 0 )
Waiting termination of process 2767
Process 2767 terminated
Process stopped PID ( 2767 0 0 )
MLDonkey server end
Het heeft ooit wel gewerkt! :?
  • Paultje3181
  • Laatst online: 00:11
op de een of andere manier mis je libgd.so.2 zo te zien... Zorg eerst eens dat je die hebt.
Verder is je startpost erg karig... wat meer info is wel handig...
Paultje3181 schreef op maandag 10 april 2006 @ 22:06:
Al geprobeerd libgd.so.2 te instaleren. Hij zit in dit pakketje "libgd2-xpm".
Maar als ik die met apt-get probeer te instaleren dan geeft ie dit aan:
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
libgd2-xpm: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-12 is to be installed
Depends: libfontconfig1 (>= 2.3.0) but it is not going to be installed
Depends: libfreetype6 (>= 2.1.5-1) but it is not going to be installed
Depends: libjpeg62 but it is not going to be installed
Depends: libpng12-0 (>= 1.2.8rel) but it is not going to be installed
Depends: libx11-6 but it is not going to be installed
Depends: libxpm4 but it is not going to be installed
mldonkey-server: Depends: libc6 (>= 2.3.5-1) but 2.3.2.ds1-12 is to be installed
Depends: libgcc1 (>= 1:4.0.2) but 1:3.3.3-9 is to be installed
Depends: libstdc++6 (>= 4.0.2-4) but it is not going to be installed
Depends: dpkg (>= 1.10.27) but 1.10.21 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
  • daft_dutch
  • Laatst online: 28-02 01:03
daft_dutch
je draait waarschijnlijk sid of etch
welkom bij de wereld die unstable heet gewoon ff wachten
  • Jaap-Jan
  • Laatst online: 01:37
daft_dutch schreef op maandag 10 april 2006 @ 23:38:
Of je zorgt ervoor dat je prioriteiten in orde zijn en dat je niet zomaar spullen uit unstable gaat installeren maar dat apt eerst kijkt of je stable spullen kunt krijgen voordat hij grijpt naar unstable packages ;).
Als ik dat namelijk zo zie heeft hij sarge geïnstalleerd en in zijn sources.list ook de unstable repository toegevoegd.
Wat doet 'ie als je dit uitvoert:
apt-get install libgd2-xpm/stable
Permanente oplossing (mits aanname dat je sarge en unstable mixt klopt):
Dit neerzetten in /etc/apt/apt.conf (aanmaken als hij niet bestaat):
APT::Default-Release "stable";
[ Voor 42% gewijzigd door Jaap-Jan op 11-04-2006 00:19 ]
| Last.fm | "Mr Bent liked counting. You could trust numbers, except perhaps for pi, but he was working on that in his spare time and it was bound to give in sooner or later." -Terry Pratchett
Japie_17 schreef op maandag 10 april 2006 @ 23:47:
Ik draai testing, stable vondt ik net weer iets te oud, en die libgd2-xpm is er ook gewoon als testing variant. Maar als ik die probeer te instaleren dan krijg ik dus het gezeur wat ik hierboven al heb gepost!
In mijn sources.list staan enkel testing repositorys.
Iemand nog een suggestie om mldonkey aan de praat te krijgen?
Of kan ik heel debian opnieuw instaleren vanwege die file? ( I love linux )
  • Jaap-Jan
Verwijderd schreef op dinsdag 11 april 2006 @ 19:14:
Neuh, je moet even geduld hebben totdat de nieuwe packages beschikbaar zijn in Testing. Dat is het risico van Testing ;).
[ Voor 3% gewijzigd door Jaap-Jan op 11-04-2006 20:16 ]
Japie_17 schreef op dinsdag 11 april 2006 @ 20:15:
Nou voorheen deed ie het gewoon :S
Kickje, zou fijn zijn als iemand nog een idee heeft om libgd.so.2 aan de praat te krijgen op mijn Debian pc. Alles opnieuw installeren is zo ontzettend veel werk!
  • koffiedrinker
  • Laatst online: 24-09 15:08
koffiedrinker
Archlinux werkt dagelijks
Bovenstaande quote geeft al aan wat je moet doen. Wachten totdat het kort gecorrigeerd in Debian. Heb je al gekeken of er nieuwe pakketen zijn voor libgd2-xpm en/of mldonkey? En anders kan je nog proberen om er een bugreport van te maken bij Debian.
Koffie werkt echt!
koffiedrinker schreef op zaterdag 22 april 2006 @ 17:35:
Als ik libgd2-xpm probeer te installeren krijg ik dit:
E: This installation run will require temporarily removing the essential package e2fsprogs due to a Conflicts/Pre-Depends loop. This is often bad, but if you really want to do it, activate the APT::Force-LoopBreak option.
E: Internal Error, Could not early remove e2fsprogs
Als ik e2fsprogs probeer te verwijderen zegtie dat dat erg slecht kan zijn......
Hij draait weer, bedankt voor de hulp!
