en
http://www.screentime.com/ ?
ScreenTime For Flash is the best way to quickly and reliably create Mac and Windows Flash-based screen savers.
ScreenTime includes the most robust support for Flash features such as dynamically updateable content, hyperlinks, XML, and interactivity. ScreenTime gives you exclusive features including a programmable settings window, NT WebLaunch, and a Flash Everywhere interface. It's the only tool with a version for both Mac and Windows. Most importantly, we've been refining and improving our software since 1995, so when you buy ScreenTime, you're buying the most bullet-proof solution on the market. ScreenTime savers are installed on millions of machines worldwide.
Just Released! ScreenTime V3 expands what is possible with Flash-based screen savers, adding the ability to download files, set custom wallpapers, read, write, copy and delete files, detect if a computer is connected to the internet and much more - all from within Flash, using ActionScript.
1e hit op Google:
http://www.google.nl/sear...ash+screensaver+mac&meta=
och ja,... dit: $199.00 zal het probleem zijn,....
Voor 99% gewijzigd door
Verwijderd op 05-04-2006 19:13
