Hallo, is het mogelijk om op een PC VNC Server te installeren, om dan van een andere PC, uit een heel ander netwerk enzo in die VNC server te benaderen via VNC viewer?
Dit kan over het internet. (internet IP, indien je een router hebt moet je wel de poorten forwarden
UltraVNC
What is it?
UltraVNC is an easy to use, fast and free sotware that can display the screen of another computer (via internet or network) on your own screen. The program allows you to use your mouse and keyboard to control the other PC remotely. It means that you can work on a remote computer, as if you were sitting in front of it, right from your current location.
If you provide computer support, you can easy access your customer's computers from anywhere in the world and resolve helpdesk issues remotely ! Your customers don't have to pre-install software or execute complex procedures to get remote helpdesk support. UltraVNC allows you to remotely control a computer over any TCP/IP connection.
UltraVNC key features include FileTransfer, Video Driver, Encryption Plugins, MS Logon, high performances over all kinds of connections, Viewer Toolbar, JavaViewer with FileTransfer, autoscaling and serverside scaling, Multiple Monitors support, Repeater/proxy support, good Security and Text Chat.
UltraVNC also has powerfull addons like Repeater, SingleClick packager and Nat to Nat connector, that help you to easely handle the most complex connection situations.
UltraVNC runs under Windows™ operating systems (95, 98, Me, NT4, 2000, XP, 2003...), but its embedded JavaViewer allows you to connect (and make File Transfers) from a simple Web Browser on any Operating system supporting Java™ (Linux, Mac OS...) to an UltraVNC server.
map poort 5900 TCP op je router naar het IP adres van de PC waar VNC op staat. Verbind dan vanaf de andere PC naar het internet IP adres van de PC waar VNC op draait (voor je internet IP, ga naar de site www.whatismyip.com op de PC met VNC geinstalleerd).
Voor info over portmappings zie google, documentatie van je router of ' het grote portmappings verhaal' hier op GoT
JaVerwijderd schreef op dinsdag 28 maart 2006 @ 19:40:
Dit is al de zoveelste keer dat je een 'ik dump mijn vraag hier neer' topic plaatst en op slot gezet word.
Check je mail over enkele ogenblikken.
Braaikamer - Smoke&BBQ - Huis
