[sqlce] 80004005 unspecified debuggen
  • Y3PP3R
  • Laatst online: 13-10 14:52
Hey allen,
Ik werk met .net 1.1, ppc 2002, win xp pro / iis 5/ msde.
Wat ik gevonden heb over de 80004005 error, is dat het met de juiste rechten te maken kan hebben. Nu vraag ik me af wat er mis is met de rechten tot mijn eigen lokale sqlce database?
Pull van MS SQL naar SQL CE gaat goed, dataset uit sqlce vullen gaat goed, maar adapter.update geeft de error.
Kan iemand mij een tip geven, want ik kom er niet uit?
Visual Basic:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
Friend Sub PullRegistrations()
            If mode = "online" Then
                Dim strSQL As String = "SELECT * FROM registrations WHERE deleted = 0 AND user_id = '" & CurrentUser.User_ID & "'"
                Dim strTable As String = "registrations"
                Dim strErrTable As String = ERR_TABLE & strTable
                Try
                    If DoesTableExist(strTable) Then DropTable(strTable)
                    If DoesTableExist(strErrTable) Then DropTable(strErrTable)
                    'rda.Pull(strTable, strSQL, rdaOleDbConnectString, RdaTrackOption.TrackingOnWithIndexes, strErrTable)
                    rda.Pull(strTable, strSQL, rdaOleDbConnectString, RdaTrackOption.TrackingOn, strErrTable)
                Catch err As SqlCeException
                    myLog.Write("LocalDB.PullRegistrations(): ERROR: " & ShowErrors(err))
                    MsgBox(myResx.GetString("ERR_DB_PULL_SQL"))
                Catch err As Exception
                    myLog.Write("LocalDB.PullRegistrations(): ERROR: " & err.Message)
                    MsgBox(myResx.GetString("ERR_DB_PULL"))
                End Try
            Else
                Return
            End If
            _PocketRegistrations = New SqlCeDataAdapter
            _PocketRegistrations.SelectCommand = New SqlCeCommand("SELECT * FROM registrations", _localDB)
            _PocketRegistrations.InsertCommand = New SqlCeCommand("INSERT INTO registrations(reg_id, user_id, object_id, place_id, reg_date, duration) VALUES(?, ?, ?, ?, ?, ?)", _localDB)
            _PocketRegistrations.InsertCommand.Parameters.Add("regid", SqlDbType.UniqueIdentifier, 0, "reg_id")
            _PocketRegistrations.InsertCommand.Parameters.Add("userid", SqlDbType.UniqueIdentifier, 0, "user_id")
            _PocketRegistrations.InsertCommand.Parameters.Add("objectid", SqlDbType.UniqueIdentifier, 0, "object_id")
            _PocketRegistrations.InsertCommand.Parameters.Add("placeid", SqlDbType.UniqueIdentifier, 0, "place_id")
            _PocketRegistrations.InsertCommand.Parameters.Add("datum", SqlDbType.DateTime, 0, "reg_date")
            _PocketRegistrations.InsertCommand.Parameters.Add("tijd", SqlDbType.DateTime, 0, "duration")
            _PocketRegistrations.UpdateCommand = New SqlCeCommand("UPDATE registrations SET user_id=?, object_id=?, place_id=?, reg_date=?, duration=?, deleted=? WHERE reg_id=?", _localDB)
            _PocketRegistrations.UpdateCommand.Parameters.Add("userid", SqlDbType.UniqueIdentifier, 0, "user_id")
            _PocketRegistrations.UpdateCommand.Parameters.Add("objectid", SqlDbType.UniqueIdentifier, 0, "object_id")
            _PocketRegistrations.UpdateCommand.Parameters.Add("placeid", SqlDbType.UniqueIdentifier, 0, "place_id")
            _PocketRegistrations.UpdateCommand.Parameters.Add("datum", SqlDbType.DateTime, 0, "reg_date")
            _PocketRegistrations.UpdateCommand.Parameters.Add("tijd", SqlDbType.DateTime, 0, "duration")
            _PocketRegistrations.UpdateCommand.Parameters.Add("del", SqlDbType.Bit, 0, "deleted")
            _PocketRegistrations.UpdateCommand.Parameters.Add("regid", SqlDbType.UniqueIdentifier, 0, "reg_id")
            _PocketRegistrations.UpdateCommand.Parameters("regid").SourceVersion = DataRowVersion.Original
            '_PocketRegistrations.UpdateCommand.Parameters.Add("regid", SqlDbType.UniqueIdentifier, 0, "reg_id")
            _PocketRegistrations.DeleteCommand = New SqlCeCommand("DELETE FROM registrations WHERE reg_id=?", _localDB)
            '_PocketRegistrations.DeleteCommand.Parameters.Add("regid", SqlDbType.UniqueIdentifier, 0, "reg_id")
            _localDB.Open()
            _PocketRegistrations.Fill(RegData, "registrations")
            myLog.Write("LocalDB.PullRegistrations(): sqlceadapter filled", LogFile.Logmode.Verbose)
            _localDB.Close()
            RegData.Tables("registrations").PrimaryKey = New DataColumn() {RegData.Tables("registrations").Columns("reg_id")}
            RegData.Tables("registrations").Columns("reg_id").DefaultValue = NewGuid()
            myLog.Write("LocalDB.PullRegistrations(): primary key created", LogFile.Logmode.Debug)
        End Sub
And this is the code for the MS SQL database:
SQL:
29
30
31
32
33
CREATE TABLE [registrations] (
    [reg_id]  uniqueidentifier ROWGUIDCOL  NOT NULL CONSTRAINT [DF_registrations_reg_id] DEFAULT (newid()),
    [user_id] [uniqueidentifier] NOT NULL ,
    [object_id] [uniqueidentifier] NOT NULL ,
    [place_id] [uniqueidentifier] NOT NULL ,
    [reg_date] [smalldatetime] NOT NULL ,
    [duration] [smalldatetime] NOT NULL CONSTRAINT [DF__registrat__Afsta__7A9C383C] DEFAULT (0),
    [deleted] [bit] NOT NULL CONSTRAINT [DF_registrations_deleted] DEFAULT (0),
    [processed] [bit] NOT NULL CONSTRAINT [DF_registrations_processed] DEFAULT (0),
    CONSTRAINT [PK_registrations] PRIMARY KEY  CLUSTERED
        [reg_id]
    )  ON [PRIMARY] ,
    CONSTRAINT [FK_registrations_objects] FOREIGN KEY
        [object_id]
    ) REFERENCES [objects] (
        [object_id]
    CONSTRAINT [FK_registrations_places] FOREIGN KEY
        [place_id]
    ) REFERENCES [places] (
        [place_id]
    CONSTRAINT [FK_registrations_users] FOREIGN KEY
        [user_id]
    ) REFERENCES [users] (
        [user_id]
) ON [PRIMARY]
GO
  • whoami
  • Laatst online: 11:21
Het is niet nodig om hier 100lijnen irrelevante code te posten.
Geef eens de exacte error; want het lijkt mij dat je wel nog wat meer informatie moet krijgen ?
https://fgheysels.github.io/
  • Y3PP3R
60+33=93 regel
De complete error, die ik terugkrijg, na het leesbaarmaken met showerrors() [zie msdn documentatie waar ik hem gevonden heb] is als volgt:
Errorcode: 80004005
Message: Unspecified Error
Minor Err.: 0
Source: Microsoft SQL Server 2000 Windows CE Edition
Echt niet meer info
  • Y3PP3R
* Y3PP3R schopt
sorry, maar ik krijg het niet weg en het is zeer hinderlijk voor mij :(
  • Y3PP3R
Ik heb nog geen oplossing. Wat kan ik nu als vervolg proberen?
Waar kan ik het probleem aankaarten? Bij Microsoft? Of is er een ervaren Pocket PC Dev die misschien via IM of Email mijn source wil bekijken? Want dit is helaas voor mij een grote block.
Iemand hier een idee over?
