[2003] DNS Update Failed in log
  • 109 views sinds 30-01-2008
  • GregoryBE
  • Laatst online: 01-07 15:32
Hallo
Ik zat met een DNS update probleem op een 2003 server, daarom om alle problemen te vermijden heb ik de windows 2003 server volledig geherinstalleerd, en erna First Server Configuration gedaan.
(Hier zit DNS,DHCP en Domain server in.
Wanneer ik er een XP PC'tje aanhang via DHCP, (of laten we zeggen ene heleboel pctjes)
geeft het log nog steeds dit:
Wat wilt zeggen DNS update failed
Microsoft DHCP Service Activity Log
Google zegt mij zeer weinig en de MS site ook,
is dit normaal?
Event ID Meaning
00 The log was started.
01 The log was stopped.
02 The log was temporarily paused due to low disk space.
10 A new IP address was leased to a client.
11 A lease was renewed by a client.
12 A lease was released by a client.
13 An IP address was found to be in use on the network.
14 A lease request could not be satisfied because the scope's
address pool was exhausted.
15 A lease was denied.
16 A lease was deleted.
17 A lease was expired.
20 A BOOTP address was leased to a client.
21 A dynamic BOOTP address was leased to a client.
22 A BOOTP request could not be satisfied because the scope's
address pool for BOOTP was exhausted.
23 A BOOTP IP address was deleted after checking to see it was
not in use.
24 IP address cleanup operation has began.
25 IP address cleanup statistics.
30 DNS update request to the named DNS server
31 DNS update failed
32 DNS update successful
50+ Codes above 50 are used for Rogue Server Detection information.
ID,Date,Time,Description,IP Address,Host Name,MAC Address
00,03/14/06,19:55:17,Started,,,,
55,03/14/06,19:55:23,Authorized(servicing),,,,
01,03/14/06,19:56:54,Stopped,,,,
00,03/14/06,19:58:02,Started,,,,
50,03/14/06,19:58:12,Unreachable Domain,,sjt.local,8250,
56,03/14/06,19:58:12,Authorization failure, stopped servicing,,sjt.local,,
50,03/14/06,19:58:12,Unreachable Domain,,sjt.local,8240,
55,03/14/06,19:58:47,Authorized(servicing),,sjt.local,,
30,03/14/06,19:59:53,DNS Update Request,216.2.168.192,jonathan.,,
10,03/14/06,19:59:53,Assign,192.168.2.216,jonathan.,00B0D0BEFD7C,
30,03/14/06,19:59:56,DNS Update Request,216.2.168.192,jonathan.,,
11,03/14/06,19:59:56,Renew,192.168.2.216,jonathan.,00B0D0BEFD7C,
31,03/14/06,20:00:04,DNS Update Failed,192.168.2.216,jonathan.,2,
30,03/14/06,20:00:04,DNS Update Request,216.2.168.192,jonathan.,,
11,03/14/06,20:00:04,Renew,192.168.2.216,jonathan.,00B0D0BEFD7C,
31,03/14/06,20:00:07,DNS Update Failed,192.168.2.216,jonathan.,2,
30,03/14/06,20:00:07,DNS Update Request,216.2.168.192,jonathan.,,
11,03/14/06,20:00:07,Renew,192.168.2.216,jonathan.,00B0D0BEFD7C,
31,03/14/06,20:00:11,DNS Update Failed,192.168.2.216,jonathan.,-1,
31,03/14/06,20:00:17,DNS Update Failed,192.168.2.216,jonathan.,-1,
30,03/14/06,20:06:16,DNS Update Request,148.2.168.192,informatica24.,,
10,03/14/06,20:06:16,Assign,192.168.2.148,informatica24.,0050BFD6E0E0,
31,03/14/06,20:06:30,DNS Update Failed,192.168.2.148,informatica24.,-1,
30,03/14/06,20:06:53,DNS Update Request,155.2.168.192,informatica20.,,
10,03/14/06,20:06:53,Assign,192.168.2.155,informatica20.,0040F483D11B,
31,03/14/06,20:07:05,DNS Update Failed,192.168.2.155,informatica20.,-1,
30,03/14/06,20:08:13,DNS Update Request,170.2.168.192,informatica18.,,
10,03/14/06,20:08:13,Assign,192.168.2.170,informatica18.,000AE62F3133,
31,03/14/06,20:08:27,DNS Update Failed,192.168.2.170,informatica18.,-1,
30,03/14/06,20:09:49,DNS Update Request,146.2.168.192,informatica23.,,
10,03/14/06,20:09:49,Assign,192.168.2.146,informatica23.,0050BFD6E0B3,
31,03/14/06,20:10:03,DNS Update Failed,192.168.2.146,informatica23.,-1,
30,03/14/06,20:21:41,DNS Update Request,175.2.168.192,klaspc1.,,
10,03/14/06,20:21:41,Assign,192.168.2.175,klaspc1.,0050FC0E3EB7,
31,03/14/06,20:21:55,DNS Update Failed,192.168.2.175,klaspc1.,-1,
30,03/14/06,20:29:04,DNS Update Request,166.2.168.192,informatica19.,,
10,03/14/06,20:29:04,Assign,192.168.2.166,informatica19.,0050BFD6DA77,
31,03/14/06,20:29:18,DNS Update Failed,192.168.2.166,informatica19.,-1,
24,03/14/06,20:58:02,Database Cleanup Begin,,,,
30,03/14/06,20:58:02,DNS Update Request,146.2.168.192,informatica23.,,
30,03/14/06,20:58:02,DNS Update Request,148.2.168.192,informatica24.,,
30,03/14/06,20:58:02,DNS Update Request,155.2.168.192,informatica20.,,
30,03/14/06,20:58:02,DNS Update Request,166.2.168.192,informatica19.,,
30,03/14/06,20:58:02,DNS Update Request,170.2.168.192,informatica18.,,
30,03/14/06,20:58:02,DNS Update Request,175.2.168.192,klaspc1.,,
30,03/14/06,20:58:02,DNS Update Request,216.2.168.192,jonathan.,,
25,03/14/06,20:58:02,0 leases expired and 0 leases deleted,,,,
31,03/14/06,20:58:17,DNS Update Failed,192.168.2.146,informatica23.,-1,
31,03/14/06,20:58:28,DNS Update Failed,192.168.2.148,informatica24.,-1,
31,03/14/06,20:58:46,DNS Update Failed,192.168.2.155,informatica20.,-1,
31,03/14/06,20:58:58,DNS Update Failed,192.168.2.166,informatica19.,-1,
31,03/14/06,20:59:12,DNS Update Failed,192.168.2.170,informatica18.,-1,
31,03/14/06,20:59:24,DNS Update Failed,192.168.2.175,klaspc1.,-1,
31,03/14/06,20:59:36,DNS Update Failed,192.168.2.216,jonathan.,-1,
It's just a matter of time...
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Hoe staan de instellingen precies voor de clients in dhcp? Heb je daarin wel een useraccount gedefinieeerd met de juiste rechten om dns te updaten?
Check ook http://support.microsoft....aspx?scid=kb;en-us;816592 eens :P
Mijn spoorwegfotografie
  • Donaldinho
  • Laatst online: 21:02
plus het lijkt erop dat je scope op/leeg is. Probeer eens je scope te vergroten danwel je scavaging aan te zetten?
edit, niet goed gelezen, hij maakt ze gewoon leeg...hoe staan update settings van je dns server? secure/etc only?
[ Voor 35% gewijzigd door Donaldinho op 14-03-2006 22:41 ]
You almost can’t blame him or the other diet gurus for leaning in on the techno-bullshit market; it’s hard to fill up a 300 page diet book on “eat a bit less and find a type of exercise that doesn’t make you hate life.”
  • GregoryBE
Hieronder even mijn configuratie:
Afbeeldingslocatie: http://users.skynet.be/GreTech/tweakers/1DHCP_scope_general.JPG
Afbeeldingslocatie: http://users.skynet.be/GreTech/tweakers/2DHCP_DNS.JPG
Afbeeldingslocatie: http://users.skynet.be/GreTech/tweakers/actdir_en_dhcp_credentials.JPG
- Ik had juist ook om te proberen, een nieuwe user aangemaakt in de active dir "DHCP" deze lid gemaakt van DnsUpdateProxy, en dan deze ingesteld in Credentials bij Advanced opties
Dit geeft dezelfde foutmelding in het LOG
- En wanneer ik de Client zijn instellingen verander
zoals http://support.microsoft.com/default.aspx?scid=kb;en-us;816592#XSLTH3287121122120121120120(is dus alleen DNS suffix veranderen, de rest stond al goed) dan doet hij het nog niet.
laat ook nog je server opties zien en een ipconfig /all van een client
  • GregoryBE
Verwijderd schreef op woensdag 15 maart 2006 @ 15:11:
Server opties zie je hierboven geloof k,
en hieronder clientopties van IPCONFIG /ALL
Windows IP-configuratie
Host-naam . . . . . . . . . . . .: jonathan
Primair DNS-achtervoegsel. . . . .:
Knooppunttype . . . . . . . . . . : hybride
IP-routering ingeschakeld. . . . .: nee
WINS-proxy ingeschakeld . . . . . : nee
DNS-achtervoegselzoeklijst. . . . : sjt.local
Ethernet-adapter LAN-verbinding:
Verbindingsspec. DNS-achtervoegsel:
Beschrijving . . . . . . . . . . .:
3Com 3C920 Integrated Fast Ethernet Controller (3C905C-TX-compatibel)
Fysiek adres. . . . . . . . . . . : 00-B0-D0-BE-FD-7C
DHCP ingeshakeld. . . . . . . . . : ja
Autom. configuratie ingeschakeld. : ja
IP-adres. . . . . . . . . . . . . : 192.168.2.216
Subnetmasker. . . . . . . . . . . : 255.255.0.0
Standaardgateway. . . . . . . . . : 192.168.1.1
DHCP-server . . . . . . . . . . . : 192.168.1.17
DNS-servers . . . . . . . . . . . : 192.168.2.1
195.130.130.131
Primaire WINS-server. . . . . . . : 192.168.2.1
Lease verkregen . . . . . . . . . : woensdag 15 maart 2006 15:21:54
Lease verlopen . . . . . . . . . : maandag 20 maart 2006 18:21:54
  • Donaldinho
Is er een speciale reden dat je een /16 ipv /24 subnet gekozen hebt voor je 192 interne adressen?
195.130.130.131
wat is dat 195 adres? Extern van ISP? Zo ja, verwijderen :)
  • GregoryBE
Verwijderd schreef op woensdag 15 maart 2006 @ 19:05:
Waarom als ik vragen mag? want ik heb hem er express bijgezet, als onze DNS server down zou zijn.
  • GregoryBE
Donaldinho schreef op woensdag 15 maart 2006 @ 17:49:
Ja, wij gebruiken 2 range
192.168.1.xxx voor alle vaste ip adressen
192.168.2.xxx , hierop gaat de DHCP zijn gang.
  • sanfranjake
sanfranjake
(overleden)
GregoryBE schreef op woensdag 15 maart 2006 @ 19:26:
Omdat die constructie en Active Directory niet samen gaan. Zat over te vinden op GoT :)
  • elevator
elevator
Officieel moto fan :)
Jouw DNS server mag niet down zijn :) Windows selecteert (semi-) random een DNS server uit om te gebruiken, het is dus een load balancing systeem en geen failover systeem.
Dit betekent dat 'srj.local' af en toe aan jouw ISP's DNS server gevraagd zal worden (of sterker nog - jouw ISP's dns server zal af en toe vragen om die DNS entry te reggen in zijn server) en af en toe aan jouw eigen interne DNS server, dat werkt natuurlijk niet :)
  • Donaldinho
Als je twee subnets wilt lijkt me dat je dan JUIST een 255.255.255.0 subnet moet hebben toch? Anders zien je machines het als een subnet, namelijk het subnet 192.168.host netwerk..
[ Voor 4% gewijzigd door Donaldinho op 15-03-2006 20:08 ]
  • GregoryBE
Donaldinho schreef op woensdag 15 maart 2006 @ 20:07:
We hebben het eerst even geprobeerd, maar dan vinden de hosts in 192.168.1.x de PC's in 192.168.2.xxx niet daarmee
  • GregoryBE
elevator schreef op woensdag 15 maart 2006 @ 19:36:
Ik heb de andere DNSen eens weg gedaan, de foutmelding is er nog steeds
maar wrm noemt de DNS optie dan "Alternatieve DNS", ik heb zelf een keer gehad dat de eerste DNS uitstond, en een andere pc waar de alternatieve dns er bij stond, kon wel op het internet en degene met 1 dns niet.
Heb je ook ipconfig /flushdns en ipconfig /registerdns gedaan?
  • sanfranjake
sanfranjake
(overleden)
GregoryBE, ga je eens inlezen in hoe dns werkt. Daarmee zou je bij : http://technet2.microsoft...a32-63d895a7924b1033.mspx prima kunnen beginnen.
Het is natuurlijk niet de bedoeling dat we de werking ervan stap voor stap gaan uitleggen, zie daarover ook de Algemene gedragsregels (Netiquette).
[ Voor 27% gewijzigd door sanfranjake op 15-03-2006 20:49 ]
