Postfix trouble
Heb een probleempje met postfix. of niet met postfix. dat weet ik dus niet zeker :)
Iig gaat het mailen niet helemaal goed. Ik heb dit probleem eerder gepost op een
engelstalig forum, maar weinig response...wellicht hier meer succes.
Hoop dat engels geen probleem is op het forum hier....ik copy/paste de text namelijk van de opensuse forums. (zo ja wil ik het wel vertalen...maar gezien de meeste tweakers een hoop engels
voor hun kiezen krijgen...)
De ISP in kwestie is overigens Chello. Dat zegt mensen hier in NL weer WEL wat. :):)
I have an OpenSuse10 machine with postfix MTA installed on it.
Now I'am behind a regular ISP cable connection and there are offcourse some limitation in order.
Before I used this setup, I used a Windows box with Kerio mailserver.
It was able to RECEIVE mail but NOT SEND it. So only HALF of the MTA worked.
But this was fine by me, since I only wanted to bind a domain to my email.
Sending was just a matter of using the providers SMTP in the MUA, while receiving trough my own server.
This makes sense, as the ISP has no possible spam issues with open relay (mis)configs this way,
while enabling people to config their own domain for incomming mail.
Now I recently formatted that windows (kerio mailserver) box and installed SuSE on it.
But now all of a sudden the INCOMMING mail DOESN'T get trough. it bounces directly like:
PERM_FAILURE: SMTP Error (state 9): 554 <lennart (AT) sermo.nl>: Relay access denied
And here is de log from postfix:
Mar 12 19:03:20 phobos postfix/smtpd[11856]: NOQUEUE: reject: RCPT from zproxy.gmail.com[64.233.xxx.xxx]: 554 <lennart (AT) sermo.nl>: Relay access denied; from=<lennartz@gmail.com> to=<lennart (AT) sermo.nl> proto=ESMTP helo=<zproxy.gmail.com>
This was a mail send FROM a gmail test account, to the address above.
I called my ISP and they could only tell that there were not any changes lately in the mailserver config. Seems too much of a coincidence any way......or is it?
Hopelijk kunnen jullie er wat mee [dank!]
[ Voor 3% gewijzigd door Verwijderd op 13-03-2006 16:15 ]
Knal even je main.cf dr op
[ Voor 23% gewijzigd door Verwijderd op 12-03-2006 21:43 ]
  • weijl
lijkt erop dat je je eigen domein niet in je 'my_domains' (? of hoe et ook heet) staat.
postfix weet iig niet dat sermo.nl zijn eigen domein is, waardoor hij denkt dat hij verder moet relayen, en dat mag dus niet.
en zoals kokkerhout al zegt, knal die main.cf erop, dan is et (denk ik) meteen duidelijk waarom.
Weet wel waar je om vraagt he ;)
De rommelige parameters aan het einde van het bestand zijn
door YaST gebrouwen denk ik....ik heb het niet erin gezet, en
het lijkt me geen normaal onderdeel van het bestand, zo zonder comments.
Het probleem is een beetje, ik zou met liefde het hele document doorploegen, maar
zou niet weten wat ik moet zoeken n.a.v. die foutmelding...... :(
Code ingekort enkel de code waar het om ging staat er nu
mydestination = $myhostname, localhost.$mydomain, localhost
#mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain
#mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain,
#       mail.$mydomain, www.$mydomain, ftp.$mydomain
[ Voor 98% gewijzigd door Verwijderd op 13-03-2006 16:16 ]
  • weijl
maak daar eens van:
mydestination = $myhostname, $mydomain, localhost.$mydomain
volgens mij was dat em al.
gupje schreef op maandag 13 maart 2006 @ 00:13:
maak daar eens van:
Helaas, dat heeft niet geholpen.
De output van kerner.org (MX checker) geeft goed aan waar het fout gaat...
Dat heeft dus wel geholpen!
[ Voor 47% gewijzigd door Verwijderd op 13-03-2006 16:17 ]
  • 0siris
  • Laatst online: 11-10 09:39
Verwijderd schreef op zondag 12 maart 2006 @ 23:22:
<knip enorme lap tekst>
daar hebben ze dus het commando "postconf" op gevonden 8)7 :)
Maareh...als je nou gewoon es mydestination aanvult met je domeinnaam? Daarna natuurlijk even postfix herstarten (!).
[ Voor 5% gewijzigd door 0siris op 13-03-2006 15:28 ]
ach...in een volgend leven lach je er om!
maak daar eens van:
Correctie! het werkt wel !
Geweldig. thanx-a-million. _/-\o_ _/-\o_ _/-\o_ _/-\o_
(SuSE Yast had onderdaan het bestand ook mydestination parameter erin gezet
welke die van jou zeg maar in het midden van het bestand weer "overschreef" en dus
was er feitelijk niets aangepast, deze heb ik weg gehaald en toen werkte het!)
