Netscreen 5gt achter Speedtouch Home
  • 120 views sinds 30-01-2008
  • DaSquad117
  • Laatst online: 20-10 13:32
Volgende situatie:
Adsl verbinding met een Alcatel Speedtouch Home en daar achter een Netscreen 5gt Firewall. Om internetverbinding te hebben moet ik alleen de untrust interface van de 5gt instellen als pppoe. Nu krijg ik totaal geen verbinding.
Dit zijn m'n instellingen:
(eth3 is de untrust interface die verbinding maakt met de modem)
ns5gt-> get pppoe name eth3
PPPoE instance: eth3, id: 0, Instance is enabled
bound to interface ethernet3 at state Closed
cached MAC addr: 00.10.db.4d.43.c1
acceptable authentication protocols: ANY
username: *********@skynet, password: ***************
acceptable AC: unset(default to any)
acceptable service: unset(default to any)
idle timeout: 0 minutes, manual IP configuration: OFF
PPP Parameters:
lcp echo timeout: 30 seconds, lcp echo retries 30
netmask: 255.255.255.255, default route metric 1
auto connect: 10 seconds
clear ip on disconnect: OFF, update dhcp server: ON, admin preference 100
total connections tried: 681, successful connections: 0
in ppp data pkts: 0, out ppp data pkts: 0
in ppp ctrl pkts: 0, out ppp ctrl pkts: 0
in pppoe ctrl pkts: 0, out pppoe ctrl pkts: 681
total input bytes: 0, total output bytes: 21792
dropped pppoe/ppp ctrl pkts: 0
ns5gt-> get pppoe all
Column E: Y - Instance is enabled, N - Instance is disabled
Id PPPoE Instance E Interface User Mac addr State
0 eth3 Y ethernet3 **********@s 0010db4d43c1 Closed
ns5gt-> get int eth3
Interface ethernet3:
number 1, if_info 88, if_index 0, mode route
link up, phy-link up/half-duplex
vsys Root, zone Untrust, vr trust-vr
PPPoE instance eth3 enabled
admin mtu 0, operating mtu 1492, default mtu 1492
*ip 0.0.0.0/0 mac 0010.db4d.43c1
*manage ip 0.0.0.0, mac 0010.db4d.43c1
pmtu-v4 disabled
ping disabled, telnet disabled, SSH disabled, SNMP disabled
web disabled, ident-reset disabled, SSL disabled
DNS Proxy disabled, webauth disabled, webauth-ip 0.0.0.0
OSPF disabled BGP disabled RIP disabled RIPng disabled mtrace disabled
PIM: not configured IGMP not configured
bandwidth: physical 10000kbps, configured egress [gbw 0kbps mbw 0kbps]
configured ingress mbw 0kbps, current bw 0kbps
total allocated gbw 0kbps
DHCP-Relay disabled
DHCP-server disabled
Number of SW session: 2063, hw sess err cnt 0
Doe ik hier iets fout, of iets over 't hoofd gekeken?
je zit bij Skynet/Belgacom ? Welk ADSL abonnement heb je daar ?
Ik heb even door de handleiding i.v.m. de installatie gekeken en kon ook niets bijzonders tegenkomen, klik anders even hier en kijk of je iets gemist hebt....
  • DaSquad117
Ik zit bij Skynet met een ADSL Go abonnement
Ik heb wel een gewone Netscreen 5GT, geen Netscreen 5GT ADSL. Die is met een apart adsl interface. Ik moet via die modem, verbinding maken met internet en die zit aangesloten op m'n untrust ethernet interface.
  • DaSquad117
Netscreen helemaal gereset, config eraf gegooit en zo. De firewall ingesteld volgens de manual, geen oplossing. De connectie blijft closed. Zou 't aan de modem kunnen liggen? Maar gewoon aangesloten en in Windows PPPOE geconfigureerd gaat ie wel. :?
[ Voor 83% gewijzigd door DaSquad117 op 12-03-2006 15:11 ]
