[Debian] IPAC-NG Foutmelding
  • NaLiN
NaLiN
Muziek moet ragge
Ik heb de laatste versie van ipac-ng is gedownload om is verkeer te gaan monitoren. Ik heb ipac-ng-1.31 geinstalleerd zonder problemen. Via de search en google kon ik hier geen goed antwoord opvinden.... :'(
Zo snel ik fetchipac -Sv doe krijg ik het volgende:
Flushing accounting chains..
Reading and parsing rules file "/etc/ipac-ng/ipac-rules.conf"
Setting up acc chains..
Setup tables..
Setting up accounting rules..
 calloc failed
: Cannot allocate memory
Mijn ipac-rules.conf:
incoming from internet|ipac~o|eth0|all||||
outgoing to internet|ipac~i|eth0|all||||
Mijn ipac.conf:
29
30
31
32
33
34
35
36
37
38
39
40
41
# This is the main ipac-ng configuration file.  It contains the
# configuration directives that give the ipac-ng its instructions.
## mode of operations: operate only like old ipac or not
#classic mode =  yes
## specify access agent.
#       supported are: files, postg. files works with classic mode only
access agent = files
## accouting agent.
#       iptables and ipchains are only options
#       (ipchains is not recommended)
account agent = iptables
## storage. gdbm, postgre and plain-file supported.
#       (plain-file is not recommended)
storage = gdbm
## rules file for classic mode
rules file = /etc/ipac-ng/ipac-rules.conf
## login all users at startup
# (specific only for nonclassic mode - only those who has enough cash!)
#login at start = yes
## support for traffic passing to\from auth host
#       (specific only for nonclassic mode)
## name or ip of the auth host
## disable support if not specified,
##auth host = sibinet.com
# dont store lines containing only zeroes - speedup processing and save space
drop zero lines = yes
Mijn geheugen:
             total       used       free     shared    buffers     cached
Mem:        515936     504204      11732          0      68580     180212
-/+ buffers/cache:     255412     260524
Swap:      1108444      46720    1061724
Mijn kernel 2.6.12-1-686-smp
hallo
  • Wirehead
  • Laatst online: 18-10 12:08
Zelfde probleem hier, heb er ook niet direct een oplossing voor.
Echter, ik ben momenteel vnstat aan het proberen en het ziet er redelijk goed uit + is geen "echte" daemon.
Que accuraatheid zal ik je het antwoord nog verschuldigd moeten zijn, ben het nog aan het testen. Zit ook in de Apt-repository's, ter info.
Denon AVR-X2800H, Quadral Amun Mk.III, Technics SL-7, DIY PhonoPre, AT-152LP / 4.225kW Heckert Solar / SMA 3.0-1AV-41 / Kia e-Niro 64kWh First Edition
  • cool_zero
  • Laatst online: 08-07 21:36
Mijn ipac-rules.conf heeft wat minder rechte strepen aan het eind nodig, maar dat kan misschien komen omdat ik stable draai en dus een wat oudere versie van ipac-ng gebruik, zo ziet die er bij mij uit:
De niet zo nette calloc fout krijg je waarschijnlijk door een misconfiguratie in je ipac.conf, daar staat namelijk het volgende in de comments:
#       supported are: files, postg. ---> files works with classic mode only <----
En dan moet je dus classic mode aan zetten:
classic mode =  yes
