Quicktime en Mplayer onder gentoo
Ik zou graag deze filmpjes willen bekijken via mplayer en firefox op mijn gentoo systeem, maar dat werkt niet. Via de command, direct naar de URI ziet het er zo uit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
eric@ERIC ~ $ mplayer http://www-tc.pbs.org/wgbh/nova/elegant/media2/eu-doubled.mov?mii=1
MPlayer 1.0pre7try2-3.3.6 (C) 2000-2005 MPlayer Team
CPU: Advanced Micro Devices Athlon MP/XP/XP-M Barton (Family: 6, Stepping: 0)
Detected cache-line size is 64 bytes
MMX2 supported but disabled
3DNowExt supported but disabled
CPUflags:  MMX: 1 MMX2: 0 3DNow: 1 3DNow2: 0 SSE: 1 SSE2: 0
Compiled for x86 CPU with extensions: MMX 3DNow SSE
85 audio & 196 video codecs
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
Playing http://www-tc.pbs.org/wgbh/nova/elegant/media2/eu-doubled.mov?mii=1.
Resolving www-tc.pbs.org for AF_INET...
Connecting to server www-tc.pbs.org[81.22.32.114]:80 ...
Cache size set to 8192 KBytes
Connected to server: www-tc.pbs.org
Cache fill:  1.41% (117869 bytes)    QuickTime/MOV file format detected.
Compressed header uses zlib algo!
Compressed header size: 5370 / 48220
MOV track #0: 1 chunks, 0 samples
Generic track - not completely understood! (id: 0)
MOV track #1: 1 chunks, 0 samples
Generic track - not completely understood! (id: 1)
MOV track #2: 1 chunks, 0 samples
Generic track - not completely understood! (id: 2)
MOV track #3: 1 chunks, 0 samples
Generic track - not completely understood! (id: 3)
MOV track #4: 1 chunks, 0 samples
Generic track - not completely understood! (id: 4)
MOV track #5: 1 chunks, 0 samples
MOV: Found unknown movie atom \uffffAllocated 256 entries for palette
Loading palette from file
Image size: 837 x 21 (8 bpp)
Display size: 837 x 21
Fourcc: gif   Codec: 'GIF'
MOV track #6: 1 chunks, 0 samples
Generic track - not completely understood! (id: 6)
MOV track #7: 0 chunks, 0 samples
*** constant samplesize & variable duration not yet supported! ***
Contact the author if you have such sample file!
Generic track - not completely understood! (id: 7)
MOV: longest streams: A: #-1 (0 samples)  V: #5 (1 samples)
VIDEO:  [gif ]  837x21  8bpp  1.000 fps    0.0 kbps ( 0.0 kbyte/s)
Clip info:
 copyright: \uffff 2003 WGBH Educational Foundation
 encoder: Made with LiveStage Pro
vo: X11 running at 1152x864 with depth 24 and 32 bpp (":0.0" => local display)
Cannot find codec matching selected -vo and video format 0x20666967.
Read DOCS/HTML/en/codecs.html!
Exiting... (End of file)
Apples High Definition trailers in quicktime doen het wel perfect!
Weet iemand een oplossing?
  • Wilke
  • Laatst online: 21-10 12:03
Niet echt een oplossing, maar als je bovenstaande log naar de auteurs mailed (zoals in de output staat):
Samen met een linkje naar het betreffende bestand (ergens zelf hosten bij voorkeur), wie weet fixen ze het dan een keer!
  • Osiris
Codec: 'GIF'.. Heb je de +gif-USE-flag geset bij 't compilen? Ik namelijk niet en hier werkt ie ook niet, kga em ff recompilen (meteen updaten :P)
+gif gedoe heb ik... Ook +quicktime staat er bij, maar niet bij het emergen.
tvp?
