Kan kde-base/kdebase-3.5.1-r3 net emergen
  • To_Tall
  • Laatst online: 21-10 16:35
ik krijg de volgende foutmelding bij emerge kde
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
config.pl: fast created 491 file(s).
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
Good - your configure finished. Start make now
make  all-recursive
make[1]: Entering directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1'
Making all in libkonq
make[2]: Entering directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1/libkonq'
Making all in pics
make[3]: Entering directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1/libkonq/pics'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1/libkonq/pics'
Making all in favicons
make[3]: Entering directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1/libkonq/favicons'
make[3]: Leaving directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1/libkonq/favicons'
make[3]: Entering directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1/libkonq'
/bin/sh ../libtool --silent --mode=link --tag=CXX i686-pc-linux-gnu-g++  -Wno-long-long -Wundef -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -Wall -W -Wpointer-arith -DNDEBUG -DNO_DEBUG -O2 -O2 -mtune=pentium4 -pipe -Wall -Wformat-security -Wmissing-format-attribute -Wno-non-virtual-dtor -fno-exceptions -fno-check-new -fno-common -DQT_CLEAN_NAMESPACE -DQT_NO_ASCII_CAST -DQT_NO_STL -DQT_NO_COMPAT -DQT_NO_TRANSLATION -D_GNU_SOURCE    -o konq_sound.la -rpath /usr/kde/3.5/lib/kde3 -L/usr/kde/3.5/lib -L/usr/qt/3/lib -L/usr/lib    -module -avoid-version -module -no-undefined -Wl,--no-undefined -Wl,--allow-shlib-undefined -R /usr/kde/3.5/lib -R /usr/kde/3.5/lib -R /usr/qt/3/lib -R /usr/lib  konq_sound.lo -lsoundserver_idl -lartskde
.libs/konq_sound.o: In function `KonqSoundPlayerImpl::KonqSoundPlayerImpl()':
konq_sound.cc:(.text+0x55b): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0x648): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0x689): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0x6c0): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0x785): undefined reference to `__gnu_cxx::__exchange_and_add(int volatile*, int)'
konq_sound.cc:(.text+0x7b7): undefined reference to `__gnu_cxx::__exchange_and_add(int volatile*, int)'
konq_sound.cc:(.text+0x7e9): undefined reference to `__gnu_cxx::__exchange_and_add(int volatile*, int)'
konq_sound.cc:(.text+0x95b): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0xa48): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0xa89): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0xac0): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0xb85): undefined reference to `__gnu_cxx::__exchange_and_add(int volatile*, int)'
konq_sound.cc:(.text+0xbb7): undefined reference to `__gnu_cxx::__exchange_and_add(int volatile*, int)'
konq_sound.cc:(.text+0xbe9): undefined reference to `__gnu_cxx::__exchange_and_add(int volatile*, int)'
.libs/konq_sound.o: In function `KonqSoundPlayerImpl::mimeTypes()':
konq_sound.cc:(.text+0xd75): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0xdc1): undefined reference to `std::basic_string<char, std::char_traits<char>, std::allocator<char> >::_Rep::_S_empty_rep_storage'
konq_sound.cc:(.text+0x104b): undefined reference to `__gnu_cxx::__exchange_and_add(int volatile*, int)'
konq_sound.cc:(.text+0x1090): undefined reference to `__gnu_cxx::__exchange_and_add(int volatile*, int)'
collect2: ld returned 1 exit status
make[3]: *** [konq_sound.la] Error 1
make[3]: Leaving directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1/libkonq'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1/libkonq'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/var/tmp/portage/kdebase-3.5.1-r3/work/kdebase-3.5.1'
make: *** [all] Error 2
!!! ERROR: kde-base/kdebase-3.5.1-r3 failed.
Call stack:
  ebuild.sh, line 1933:   Called dyn_compile
  ebuild.sh, line 971:   Called src_compile
  kdebase-3.5.1-r3.ebuild, line 116:   Called kde_src_compile
  kde.eclass, line 111:   Called kde_src_compile 'compile'
  kde.eclass, line 228:   Called kde_src_compile 'all' 'myconf' 'configure'
!!! died running emake, kde_src_compile:make
!!! If you need support, post the topmost build error, and the call stack if relevant.
Ook kde-base/kdegraphics-3.5.1-r2 stop met dezelfde Call Stack
Ik heb GCC en --sync uitgevoerd en GCC compiler overgezet naar de nieuw versie maar dit werkt niet
mijn systeem
Vid: Geforce 4 TI 4200 128 MB
Mem: 256 MB DDR
Mainbord: Asus P4S333
CPU Pentium4 2.2 Ghz
A Soldiers manual and a pair of boots.
  • Borromini
Borromini
Mislukt misantroop
Daar zit je probleem :).
  • Ultraman
  • Laatst online: 20:03
Ultraman
Boefje
Ik weet niet of het in dit geval de oorzaak is, maar toch denk ik dat het geen kwaad kan even je CFLAGS te vermelden. Post gewoon even de inhoud van je /etc/make.conf .
Heb je verder dingen gedaan als je geheugen nagelopen op fouten ?
