betekent dit de dood van m'n cd brander? :'(
  • Morgoth
  • Laatst online: 11-09 23:41
Ik krijg telkens allemaal errors, zomaar ineens. Heb lekker gebrand nog gister en nu vandaag wil ik een cdbranden en vage errors, deze:
23:41:29 #13 SCSI -1135 File Cdrdrv.cpp, Line 1287
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x0503F0B0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x07
CDB Data: 0x2A 0x00 0x00 0x00 0x04 0xCE 0x00 0x00 0x1E 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x00 0x05 0x64 0x0A
0x00 0x00 0x00 0x00 0x0C 0x07
23:41:29 #14 mmc -1135 File Writer.cpp, Line 284
Write error
23:41:29 #15 Text 0 File ThreadedTransfer.cpp, Line 205
all writers idle, stopping conversion
23:41:29 #16 Text 0 File ThreadedTransfer.cpp, Line 199
conversion idle, stopping reader
23:42:44 #17 SCSI -1093 File Cdrdrv.cpp, Line 1098
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x5B 0x00 0x01 0x00 0x00 0x01 0x00 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x00 0x03 0xB0 0x0A
0x00 0x00 0x00 0x00 0x02 0x00
23:42:44 #18 mmc -1093 File WriterStatus.cpp, Line 152
No seek complete
23:42:44 #19 TRANSFER -18 File WriterStatus.cpp, Line 152
Could not perform EndTrack
23:42:44 #20 CDR -201 File WriterStatus.cpp, Line 155
Invalid writestate
23:42:44 #21 TRANSFER -18 File WriterStatus.cpp, Line 155
23:42:44 #22 SCSI -400 File Cdrdrv.cpp, Line 1098
Sense Key: 0x09 (KEY_VENDOR_SPECIFIC)
Sense Code: 0x80
Sense Qual: 0x07
CDB Data: 0x5B 0x00 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x09 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x80 0x07
23:42:44 #23 mmc -400 File WriterStatus.cpp, Line 194
SCSI Target error
23:42:44 #24 TRANSFER -19 File WriterStatus.cpp, Line 194
Could not perform Fixation
23:42:44 #25 Text 0 File WriterStatus.cpp, Line 203
falling back to disc fixation
23:42:44 #26 SCSI -400 File Cdrdrv.cpp, Line 1098
Sense Code: 0x80
Sense Qual: 0x07
23:42:44 #27 mmc -400 File WriterStatus.cpp, Line 194
SCSI Target error
Nog tips ofzo? Of is hier gewoon niks aan te doen? :(
  • BitByter
  • Registratie: Juli 1999
  • Laatst online: 07-09 18:13
BitByter
Prutst dit forum
welke brander
welke proggel(s) ??? :?
  • Neman
  • Laatst online: 30-08 12:47
Neman
Een uit de lucht gegrepen naam
Kan ook een vage cdr zijn geweest, probeer maar 's een andere. Als dit een CDD3610 brander van Philips is, dan mag je duimen dat je garantieperiode nog niet voorbij is :).
  • Morgoth
aargh sorry :(
TIs een plextor scsi2 4x brander 12x lezen.
Ik gebruik nero 5.0
Het zijn wel noname cd's maar die hiervoor gingen prima, ik heb nu al 3 coasters :(
PROBEER CDRWIN..WERKT BIJ MIJ PFECT!NERO IS SOWIESO KUT...HEB JE ER NOG MEER OPSTAAN..
DAAR HEEFT IE ALTIJD RUZIE MEE!
JE KAN OOK PROBEREN DE NIEUWE FIRMWARE OPNIEUW TE INSTALLEREN.ALS IK DIE FOETEN ZIE ZIT HET IN JE DRIVER.
  • Cliffie
  • Laatst online: 15:55
Cliffie
Trompetslet
zet je capslock eens uit man, pffff
17x DMEGC DM300-M156-60BK @ Enphase | 3300Wp Oost & 1800Wp West (Gouda)
ja, sorry!:?
  • Kaastosti
  • Laatst online: 19:38
Kaastosti
Vrolijkheid alom!
Okee, zoals STAYFAN al zegt.. het kan aan het brandprogramma liggen, maar dat Nero kut is ben ik het niet mee eens.
Easy CD Creator is kut, maar Nero heeft bij mij nog nooit problemen gegeven en ik heb toch echt flinke meuk cd's in die brander gepropt...
Misschien heb je een proggie geinstalleerd wat een driverbestand van Nero heeft overschreven of iets in die richting. Bedenk ff wat je de laatste tijd op je PC gezet hebt en rel dat er weer ff af, kijken wattie doet.
Een vergissing is menselijk, maar om er echt een puinhoop van te maken heb je een computer nodig.
  • Morgoth
ik uninstall nero wel ff en update de firmware wel, en dan nog is kijken...
  • Morgoth
hmmz als ik de firmware wil installen dan execute ik de exe en dan zegt ie dat ie de file wnaspi32.dll nodig heeft. Die staat in de nero dir, en op m'n desktop dir. Maar als ik dan op next klik zegt ie dat ie die file niet kan vinden :?
is dat nou ff kut voor je>:)
maar goed. probeer eerst ff opnieuw te branden, anders burnprogramma re-inst., anders driver re-inst. (mocht je trouwens onder win2k werken: chk ff in je hardware profile of je secundairy ide-channel wel op dma-if available staat (standaard op PIO)) als dat niet werkt ben je een sukkel.
  • Morgoth
tis een scsi brander dus dat zal weinig nut hebben |:(
Op dinsdag 23 januari 2001 00:33 schreef mbrio het volgende:
Wie is hier nou een sukkel?;)
Wat dacht je er van om dat aspi bestandje in je windows/winnt directory te copieren, bij voorkeur in de system32 directory.
Anders check de adaptec site ff voor aspi drivers.
succes(8>
  • Morgoth
Jah ik heb nu dat bestand in de system dir van winnt gegooit en dan doet ie het wel, alleen moet ik nog ff jumpertje verzetten van de cdwriter om te upgraden, maar dat doe ik vanavond als ik thuis ben.
  • Morgoth
hmpf het haalt allemaal niks uit :|
Hij wil alleen nog branden op 1x :|
