HET ULTIEME OVERKLOKKERSMOEDERBORD!!!
Tenminste...voor 440 BX fans
AX6BC Pro II
(Millennium Edition)
Model: AX6BC Pro II (Millennium Edition)
Form Factor: ATX
Memory Slots: DIMM x 3
Chipsets: Intel 440BX
CPU Bus Clock
Spec 100
Max: 153
Notes: Black PCB with Platinum Heatsink and Platinum Plate for Millennium Year
Key Features Support Intel Pentium II, Pentium III & Celeron CPU
Special Military Grade BLACK PCB
24K Platinum-plated "Millennium Edition" Logo Plate for Year 2000
Enlarged 24K Platinum-plated Heatsink for Better Heat Dissipation
CPU Jumper-less Design
16 Sets of FSB Clock from 66MHz to 153MHz
CPU clock ratio from 1.5X to 8.0X
CPU Vcore adjustment for Overclockers through BIOS setting
Support 1X / 2X AGP mode
Enhancement of 2200uf Low ESR Capacitors for Overall Stability
Frequency Isolation Wall Deployment for Signal Integrity
Over Current Protection Circuit
System Thermal Monitoring
System Voltage Monitoring
CPU and Housing Fan monitoring
Zero Voltage Wake On Modem
Wake On LAN
Wake On RTC Timer
Wake On Keyboard
Wake On Mouse
AC Power On Auto Recovery
Resetable Fuse Providing Short Circuit Protection for Keyboard and USB Device
PC99 Color coded I/O connector
ACPI Suspend To Hard Drive
Multi-language BIOS support
AOpen Full Colored Easy Installation Guide
AOpen Bonus Pack CD (Online manual and Norton
Anti-Virus included)
SpecificationsCPU: Intel Pentium II / Intel Pentium III / Intel Celeron slot1 CPU Table
ASIC: Intel 440BX AGPset
Architecture: 6 PCI slots +1AGP slot
Max. Main Memory: Max. 384MB SDRAM or 768MB Registered SDRAM for 168pin DIMM*3
DIMM Type: 8/16/32/64/128/256 MB
BIOS: Award Plug and Play 2MB Flash ROM BIOS with ACPI support for PC98 / Windows 98
On Board I/O:
2 Serial Ports (UART 16C550 Support)
1 Parallel Port (SPP/EPP/ECP Support)
2 Channel E-IDE (Mode 4 and Bus master Ultra DMA 33 Support)
1 Floppy Drive Connector (1.2/1.44/2.88MB)
2 Channel Universal Serial Bus Ports
1 PS/2 Mouse Port
1 PS/2 Keyboard Port
Real Time Clock: Built-in ASIC
Battery: 3V Lithium Battery
Green Function: Yes
Connector: IrDA, Wake On LAN, SB-LINKWake On Modem
Board Size: 202mm x 305mm, ATX Form Factor
We're trapped in the belly of this horrible machine. And the machine is bleeding to death.
