Ik heb mijn Speedtouch geconfigureerd dat ik zelf met pptp 'in kan bellen'.
Ik krijg nu een heel raar iets als ik de buitenwereld ping:
Een 2de testje dat ik gedaan is met ab (apachebench) met 1 request. Reactie tijd is minimaal en ook exact 200ms of 400ms (soms een paar ms korter of langer)
Het modem/router is als volgt ingesteld:
(Modem/router heb ik tijdje in router mode gedraaid en hier waren geen problemen daarmee)
29
30
| 64 bytes from 194.109.6.66: icmp_seq=1 ttl=61 time=24.4 ms 64 bytes from 194.109.6.66: icmp_seq=2 ttl=61 time=12.8 ms 64 bytes from 194.109.6.66: icmp_seq=3 ttl=61 time=204 ms 64 bytes from 194.109.6.66: icmp_seq=4 ttl=61 time=196 ms 64 bytes from 194.109.6.66: icmp_seq=5 ttl=61 time=187 ms 64 bytes from 194.109.6.66: icmp_seq=6 ttl=61 time=172 ms 64 bytes from 194.109.6.66: icmp_seq=7 ttl=61 time=171 ms 64 bytes from 194.109.6.66: icmp_seq=8 ttl=61 time=166 ms 64 bytes from 194.109.6.66: icmp_seq=9 ttl=61 time=162 ms 64 bytes from 194.109.6.66: icmp_seq=10 ttl=61 time=158 ms 64 bytes from 194.109.6.66: icmp_seq=11 ttl=61 time=150 ms 64 bytes from 194.109.6.66: icmp_seq=12 ttl=61 time=146 ms 64 bytes from 194.109.6.66: icmp_seq=13 ttl=61 time=44.6 ms 64 bytes from 194.109.6.66: icmp_seq=14 ttl=61 time=129 ms 64 bytes from 194.109.6.66: icmp_seq=15 ttl=61 time=121 ms 64 bytes from 194.109.6.66: icmp_seq=16 ttl=61 time=113 ms 64 bytes from 194.109.6.66: icmp_seq=17 ttl=61 time=104 ms 64 bytes from 194.109.6.66: icmp_seq=18 ttl=61 time=96.9 ms 64 bytes from 194.109.6.66: icmp_seq=19 ttl=61 time=87.6 ms 64 bytes from 194.109.6.66: icmp_seq=20 ttl=61 time=76.3 ms 64 bytes from 194.109.6.66: icmp_seq=21 ttl=61 time=68.1 ms 64 bytes from 194.109.6.66: icmp_seq=22 ttl=61 time=59.8 ms 64 bytes from 194.109.6.66: icmp_seq=23 ttl=61 time=55.6 ms 64 bytes from 194.109.6.66: icmp_seq=24 ttl=61 time=47.4 ms 64 bytes from 194.109.6.66: icmp_seq=25 ttl=61 time=38.6 ms 64 bytes from 194.109.6.66: icmp_seq=26 ttl=61 time=30.4 ms 64 bytes from 194.109.6.66: icmp_seq=27 ttl=61 time=22.2 ms 64 bytes from 194.109.6.66: icmp_seq=28 ttl=61 time=14.0 ms etc. etc. |
Wat kan dit rare gedrag van ping tijden veroorzaken en waardoor kan het dat latency zowiezo langzaam is?- Begin met factorydefaults
- Telnet 10.0.0.138 username is Administrator (casesensitive)
- atm -> phonebook
{Administrator}[atm phonebook]=>add
name = PVC
addr = 8.48
:atm phonebook add name=PVC addr=8*48
{Administrator}[pptp]=>profadd
name = PVC
[qos] =
[encaps] = vcmux
[ac] = never
:pptp profadd name=PVC encaps=vcmux ac=never
Nu werkt PPTP dial up :-)
Penpal International: https://www.penpalinternational.net/ - Mijn solar: https://frankdebot.nl/solar/
