Features Highlight :
¡Ž.Cool air is drawn through a fan duct and blown directly onto CPU with a 120mm adjustable fan which will fit with all motherboards and maximizes cooling.\
¡ŽOne 80mm fan on top of the case exhausts the hot air which rises and accumulates.
¡ŽDual, standard USB ports at front of case for easy access.
¡ŽDrawer-style motherboard tray for easy installation and maintenance.
¡ŽFull EMI shielding to protect user from harmful electronic emissions.
¡Ž[b][i]
Entire case is constructed of aluminum to conduct and disperse heat like a huge heat sink.[/b][/i]
¡ŽHighly flexible power supply options of 300W, 400W.
¡ŽTool-free assembly/disassembly for quick and convenient maintenance or upgrades.
Material: All Aluminum Alloys
Drive Bay: 5.25' Bays (exposed) x 3
3.5' Bays (exposed) x 2
3.5' Bays (hidden) x 6
Slot Bracket: 7
M/B Type: Standard ATX MB
I/O Bracket: Standard ATX
Power Supply: Optional Power Supply Unit (r 300W or 400W)
Cooling: One 80 mmx 80 mmx 25 mm Fan attached top panel
One 120mm auxiliary fan-ducting system
USB port: Dual standard USB front port
Weight: Case :5.5 Kg
Power Supply : 2 Kg
Dimension: 497 mm x 196 mm x 452 mm
:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~:9~
