speedtouch 546 langzamere upload dan st510 ?
  • DDX
  • Laatst online: 12:44
vandaag van kpn pakketje gehad met een speedtouch 546
(ivm verlenging xs4all abonnement gratis)
en net aangesloten
nu connect de 546 alleen maximaal op 8000/928
(meerdere resets geprobeerd)
terwijl de 510 op 8000/992 connect
(xs4all fast abonnement)
weet iemand waar dit aan kan liggen ?
adsl info uitdraaien :
546:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
=>adsl info
Modemstate            :  up
Operation Mode        :  G.992.1 Annex A
Channel Mode          :  fast
Number of resets      :  1
Vendor                              Local           Remote
  Country             :               0f               0f
  Vendor              :             TMMB             ALCB
  VendorSpecific      :             0000             0000
  StandardRevisionNr  :               00               01
                                  Downstream        Upstream
Margin       [dB]     :             12.5              7.0
Attenuation  [dB]     :              8.5              6.0
OutputPower  [dBm]    :             11.5             11.5
Available Bandwidth                 Cells/s           Kbit/s
  Downstream          :            18867             8000
  Upstream            :             2188              928
Transfer statistics
    Errors
      Received FEC    :                0
      Received CRC    :                0
      Received HEC    :                0
      Transmitted FEC :                0
      Transmitted CRC :                0
      Transmitted HEC :                0
     Near end failures since reset
      Loss of frame:          0 failures
      Loss of signal:         0 failures
      Loss of power:          0 failures
      Errored seconds:        0 seconds
     Near end failures last 15 minutes
      Loss of frame:          0 seconds
      Loss of signal:         0 seconds
      Loss of power:          0 seconds
     Near end failures current day
     Near end failures previous day
510 :
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
=>adsl info
Modemstate            :  up
Operation Mode        :  G.DMT Annex A  [POTS Overlay Mode]
Channel Mode          :  fast
Vendor (ITU)                        Local           Remote
  Country             :               0f               0f
  Vendor              :             ALCB             ALCB
  StandardRevisionNr  :               01               01
                                  Downstream        Upstream
Margin       [dB]     :                8                6
Attenuation  [dB]     :                9                7
  Upstream            :             2339              992
Transfer statistics
  Total since power On              Cells             Kbit
    Downstream        :            61771            26190
    Upstream          :            19391             8221
  Current Connection
    Downstream        :            61745            26179
    Errors
      Received FEC    :                0
      Received CRC    :                0
      Received HEC    :                0
    Far End Failure
      No Failure
    Near end failure
      No failure
    Far end failures since reset
      Loss of link:           0 failures
    Far end failures last 15 minutes
      Loss of link:           0 seconds
    Far end failures current day
    Far end failures previous day
https://www.strava.com/athletes/2323035
  • DDX
schopje ?
[ Voor 31% gewijzigd door DDX op 17-02-2006 10:24 ]
  • GH45T
  • Laatst online: 29-10 07:30
Misschien is de 546 iets conservatiever met het bepalen van de lijnkwaliteit. Misschien zijn er in het verleden problemen geweest omdat de 510 net iets te snelle verbindingen opzet.
Woon je ver van de kpn centrale af?
  • DDX
volgens http://spike.oli.tudelft.nl/adsl/postcodecentrale.cfm 170meter
(ik kan hem nog net niet zien vanuit m'n huis)
voorlopig maar weer de 510 aangesloten ivm betere upload snelheid
  • epias
Als je remote vendor verandert naar BDCM (=Broadcom) en dus je wijkcentrale is geupgrade, probeer het dan nog eens met de speedtouch 546. In principe zou het dan iets beter moeten gaan.
