Vastlopen Laptop
hallo allen,
Ik heb een vaag probleem met mijn laptop en ik hoop dat jullie mij hier wat verder mee kunnen helpen!
gegevens Laptop:
Sonic M300
• Intel® Pentium® M optewaarderen tot 1.70 Ghz.
• Centrino Technology.
• Intel® uFCPGA CPU Packaging.
• 1024KB on-die L2 Cache.
BIOS • Phoenix BIOS
• 512KB Flash EPROM.
• PMU, Plug & Play.
CHIPSET • Intel 855GM + ICH4M
BEELDSCHERM • 15" SXGA+ (1400x1050) TFT Active Matrix Display.
• 14" XGA (1024 x 768) TFT Active Matrix LCD Display.
• 32-Bit True Colors.
GEHEUGEN • 256 MB PC2700 DDR333 SDRAM Systeem Geheugen.
• Uitbreidbaar tot 1024 MB.
• Two SO-DIMM sockets.
• Panasonic SD Memory Card Slot .
VIDEO • ATI MOBILITY RADEON 9000. (M9-CSP 3D Gfix Video Chipset).
• 64MB DDR embedded Video SDRAM.
• Power Management support enabled.
• OPENGL™ and DX8.1™ compliant.
• ATI HYPER Z™ technology.
• SMARTSHADER™ technology.
• SMOOTHVISION™ technology.
• FULLSTREAM™ technology.
• PIXEL TAPESTRY™ architecture.
• Supports MPEG II playback of 32 frames per second.
• Support LCD and external CRT Simultaneous dual Display.
PCMCIA • 1x Type II PCMCIA Card Slot met 32 bits Cardbus Support.
STORAGE • External USB 3.5" 1.44MB Floppy Drive (Optioneel).
• Up to 60GB 7200 rpm, or 80GB 5400/4200 rpm Ultra
• ATA/100 Hard Disk. (Hard Disk Height: 9.5mm).
• Combo 8X DVD/24x10x24 CD-RW Drive.
• Combo 2x1x8x DVD-R/RW/16x10x24 CD-RW Drive.
SOUND • Realtek AC'97 Audio System, 3D Stereo Sound.
• Sound Blaster Pro Compatible.
• Wavetable 3D Stereo Audio.
• 1x Ingebouwde Microphone
• 2x Ingebouwde Speakers
I/O • 3x USB2.0 Poorten
• 1x Parallel Port
• 1x SD Memory Slot
• 1x IEEE Firewire 1394 Poort
• 1x RJ45 Port for Ethernet Card
• 1x RJ-11Port for Fax Modem
• 1x External VGA Port
• 1x S-Video TV Output Port
• 1x Headphone-Out Jack
• 1x MIC-in Jack
• 1x Kensington Lock Slot
COMMUNICATIE • Ethernet 10/100BaseT Network.
• Intel Pro2100 mini-PCI 802.11b WLAN.
• 56k V.90 Modem - Smartlink.
• Infrarood Poort FIR 4 MBit/s
GEWICHT/
AFMETINGEN • 3.17 Kg inclusief batterij en 15" LCD.
• 3.05 Kg inclusief batterij en 14" LCD.
• 330 x 273 x 29,4mm
BATTERIJ • Smart Lithium-Ion Battery.
• 3.5 to 4+ Hours Run Time.
• 8 Cellen, 65Whrs Capaciteit.
• 3.5 Uur oplaadtijd (Systeem aan).
• 2.5 Uur oplaadtijd (Systeem uit).
VOEDING • Universeel AC adapter.
• Full Range 110-220V AC, 50-60Hz
• Auto Sensing Auto Switching.
Mijn laptop loopt dus vaak vast. Ik heb alles al een keer opnieuw geinstalleerd, maar dat heeft niet echt geholpen. Meestal bevriest alles, hij reageert nergens meer op, dan kan ik niets anders doen dan mijn powerknop een aantal seconden inhouden. Ik heb al memtest gedraaid en andere programma`s zoals sysoft sandra. Deze geven allen geen fouten.
Het rare is dat als ik met laptop werk terwijl ik winamp of WMP aan heb staan, dan loopt hij bijna nooit tot niet vast. Ik kan me niet herinneren dat mijn laptop toen is vastgelopen. Als ik winamp of WMP niet aan heb loopt hij wel erg snel vast. Vooral als ik mijn laptop niets laat doen.
Heeft iemand een idee wat dit kan zijn? Ik denk zelf aan een kapotte HD, omdat met winamp en WMP mijn laptop constant info van de HD vraagt. Scandisk geeft alleen geef fouten.
Ik hoop dat jullie me kunnen helpen,
Greets jw
  • Hahn
  • Laatst online: 16-10 20:20
Waar staan je energiebeheer instellingen op? Het klinkt meer op het vastlopen bij standby gaan dan dat het een hardeschijfprobleem is. Als het aan je HD zou liggen dan zou je juist problemen krijgen als WMP/WinAmp zou draaien en niet andersom.
[ Voor 3% gewijzigd door Hahn op 12-02-2006 18:41 ]
The devil is in the details.
  • SSH
SSH
Probleem bekend bij de producent?
support@micropoint.nl
edit: volgens mij zijn ze alleen failliet ;)
[ Voor 30% gewijzigd door SSH op 12-02-2006 18:41 ]
Haha, die zijn idd failliet
Neej, dat standby gaan staat uit. Hij loopt bijvoorbeeld vast als ik aan het msnen ben, maar als ik winamp of WMP ernaast draai, dan dus niet.
Iemand een idee wat het kan zijn?
  • MeNTaL_TO
  • Laatst online: 18-10 19:25
MeNTaL_TO
The future is not set
Misschien een driver niet geinstalleerd of juist wel, dit kan van alles zijn, staat er geen meldingen in je event viewer die je opweg kunnen helpen?
Ik heb zelf zoiets sinds kort met newsleecher, geen idee waarom. Windows al opnieuw geinstalleerd met nu met beta 3 nog steeds, als ik het scherm open laat staan crashed mijn xp, zet ik hem in tray blijft ie werken.
Dus probeer voor je zelf te achterhalen of je een verband ziet en probeer daar vandaan een driver te beredeneren.
[ Voor 37% gewijzigd door MeNTaL_TO op 13-02-2006 01:41 ]
Wenn ist das Nunstruck git und Slotermeyer? Ja!... Beiherhund das Oder die Flipperwaldt gersput! The Hornets of Hades have descended upon me
  • smvs
Hij loopt dus vast als hij niets doet. Dit kan dus met het terugklokken van je cpu te maken hebben (als deze teruggeklokt is loopt hij vast). Je zou eens op de Intel site kunnen kijken voor een nieuwe cpu driver of in het bios wat kunnen spelen met de power management settings.
