[2000] Fout branden DVD
Hey,
PROBLEEM IS OPGELOST, TOPIC KAN OP SLOT!
Ik probeerde net een .ISO DVD te branden, maar ik kreeg deze foutmelding (log) (Alcohol 120%):
########################### System Information ###########################
Windows 2000 Professional 5.0 Service Pack 4 (Build 2195)
Processor info: AMD Athlon(tm) 64 Processor 3400+ (2410MHz)
Memory Available to Windows: 1.048.048 KB
############################ Program Information ###########################
File Name: E:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2004 Alcohol Soft Development Team
Version: 1.9.2 ( Build 1705 )
Date: 2006/01/19
Hash: c21b38e4c8187a027f7901f631ea4df3
File Name: E:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Description: Alcohol virtual device control library
Original: alcoholx.dll
Copyright: Copyright (C) 2000-2004
Version: 3.47.0 ( Build 0 )
Date: 2004/04/30
Hash: c11b59c21722ca30141696c21b72578d
File Name: E:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Copyright: Copyright(C) 2002-2003 Alcohol Soft Development Team
Version: 2.3.7 ( Build 505 )
Date: 2004/05/05
Hash: 0e6f733d3f570f3b0328261d11a2794e
########################### User Information ###########################
User Name: UN-REGISTERED
Company Name: UN-REGISTERED
Registered User ID: UN-REGISTERED
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 128
Examine the accuracy of data read from physical device: Yes
Turn off "Auto-Select best write speed" function if possible: No
Overburn disc(s): No
Fill memory buffer before recording discs: Yes
Ignore Media Type: Yes
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language: Dutch
############################ Device(s) List ############################
(M:) HP DVD Writer 630c (atapi, Port 1, Bus 0, Target 0, Lun 0)
(N:) SAMSUNG DVD-ROM SD-616E (atapi, Port 1, Bus 0, Target 1, Lun 0)
(I:) Generic DVD-ROM (d347prt, Port 4, Bus 0, Target 0, Lun 0)
(P:) AXV CD/DVD-ROM (a347scsi, Port 5, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
1394BUS.SYS a347bus.sys a347scsi.sys ACPI.sys afd.sys
ASAPIW2k.sys ATMFD.DLL audstub.sys Beep.SYS BOOTVID.DLL
Cdfs.SYS Cdr4_2K.SYS Cdralw2k.SYS cdrom.sys CLASSPNP.SYS
ctac32k.sys ctaud2k.sys ctoss2k.sys ctprxy2k.sys ctsfm2k.sys
d347bus.sys d347prt.sys disk.sys Diskperf.sys dmio.sys
dmload.sys dump_atapi.sys dump_WMILIB.SYS EFS.SYS emupia2k.sys
Fips.SYS Fs_Rec.SYS ftdisk.sys gameenum.sys GEARAspiWDM.sys
ha10kx2k.sys hal.dll hap16v2k.sys HIDCLASS.SYS HIDPARSE.SYS
hidusb.sys ipsec.sys isapnp.sys kbdclass.sys kbdhid.sys
kl1.sys klif.sys klmc.sys kmixer.sys KS.SYS
KSecDD.sys LHidKE.Sys LHidUsbK.Sys LMouKE.Sys LUsbKbd.sys
mnmdd.SYS mouclass.sys mouhid.sys MountMgr.sys mrxsmb.sys
msdv.sys Msfs.SYS msgpc.sys Mup.sys NDIS.sys
ndistapi.sys ndiswan.sys NDProxy.SYS netbios.sys netbt.sys
Npfs.SYS ntdll.dll Ntfs.sys ntoskrnl.exe Null.SYS
nv4_disp.dll nv4_mini.sys ohci1394.sys openhci.sys parallel.sys
parport.sys PartMgr.sys ParVdm.SYS pci.sys pciide.sys
PCIIDEX.SYS pfc.sys PfModNT.sys portcls.sys PQNTDrv.SYS
ptilink.sys PxHelp20.sys rasacd.sys rasl2tp.sys raspptp.sys
raspti.sys rdbss.sys SCSIPORT.SYS SECDRV.SYS serenum.sys
serial.sys snapman.sys srv.sys STREAM.SYS swenum.sys
sysaudio.sys tcpip.sys TDI.SYS tifsfilt.sys timntr.sys
update.sys USBD.SYS usbehci.sys usbhub.sys usbhub20.sys
USBPORT.SYS USBSTOR.SYS vga.sys VIDEOPRT.SYS wanarp.sys
wdmaud.sys win32k.sys WmBEnum.sys WmFilter.sys WMILIB.SYS
WmXlCore.sys zd1211u.sys ZDPNDIS5.SYS
################## Detailed Information of Device(s) ##################
(M:) HP DVD Writer 630c(1:0) detail information.
Vendor Identification: HP
Product Identification: DVD Writer 630c
Production Revision Level: CH16
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), DVD DAO
BURN-Free Technology: Unknown
Auto-Select best write speed: Not Supported
*** NOT listed in Alcohol's database. Please report to development team
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: No/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: Yes
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved and Corrected: No
C2 Pointers Support: No
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: No
Separate channel mute: No
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
Maximum Read Speed Supported (with current disc): 40X (6000 KB/Sec)
Maximum Write Speed Supported (with current Disc): 40X (6000 KB/Sec)
Current Read Speed Supported (with current Disc): 40X (6000 KB/Sec)
Current Write Speed Supported (with current Disc): 40X (6000 KB/Sec)
(N:) SAMSUNG DVD-ROM SD-616E(1:1) detail information.
Vendor Identification: SAMSUNG
Product Identification: DVD-ROM SD-616E
Production Revision Level: F505
CD-R Read/Write: Yes/No
CD-RW Read/Write: Yes/No
Test Write: No
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/No
Audio Play: Yes
Digital output (IEC958) on port 1 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Current Read Speed Supported (with current Disc): 16X (2400 KB/Sec)
(I:) Generic DVD-ROM(4:0) detail information.
Vendor Identification: Generic
Production Revision Level: 1.0
Version: ANSI X3.131:1994 (SCSI-2)
Test Write: No
DVD-ROM Read: Yes
DVD-RAM Read/Write: Yes/No
Audio Play: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
R-W De-interleaved and Corrected: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
P through W in Lead-In: No
Maximum Read Speed Supported (with current disc): 32X (4800 KB/Sec)
Current Read Speed Supported (with current Disc): 32X (4800 KB/Sec)
###################### Source Disc/Image Information ######################
Type: Standard ISO image-bestand
Lokatie: D:\Downloads\
Naam: Call_of_Duty_2_DVD+crack+serial.ISO
Grootte: 3615.86 MB
Sessie: 1
Track: 1
Sessie 01:
Track 01: DVD, Lengte: 1851322(3.53 GB), Adres: 000000
####################### Dumping/Recording Progress Log #######################
14:13:26 Processor info : AMD Athlon(tm) 64 Processor 3400+ (2410MHz)
14:13:26 Hoeveelheid geheugen beschikbaar voor Windows: 1.048.048 KB
14:13:26 Geheugen Buffer gebruik: 128 MB
14:13:26 Image-bestand bezig met laden: D:\Downloads\Call_of_Duty_2_DVD+crack+serial.ISO
14:13:26 DVD Source Info : Sessie: 1, Track: 1, Lengte: 3.53 GB / 411:24:22
14:13:31 (M:) HP DVD Writer 630c(1:0): Brand methode/snelheid
14:13:31 Branden - DVD DAO - 8.0X (11040 KB/Sec)
14:24:10 (M:) HP DVD Writer 630c(1:0) - [Write ERROR] LBA: 909664, Length: 16
S:KEY - 05/21/02 - "Invalid Address For Write"
14:24:10 (M:) HP DVD Writer 630c(1:0): Branden mislukt!
14:24:10 Fout bericht : [05/21/02] - Invalid Address For Write
14:24:10 Image-bestand laden geannuleerd!
14:24:13 Er is iets mis met de brand-procedure!
Bekijk de log-bestand en vertel de Technical Support over de fouten die erin staan.
Kunnen jullie zien wat er mis is met m'n brander etc.?
Sorry dat ik het topic heb geopend. Heb opnieuw gebrand op een lagere snelheid, nu werkt het :D.
Topic kan op slot.
  • DukeBox
Zet dat dan ff bovenaan :P moet nu voor niets spacen..
