[SUSE9.3] DVD programma crasht bij afspelen
Ik probeer de dvd functie aan te krijgen in SUSE 9.3, nou was ik bijna zover dat ik het werkend kreeg.. begon er weer een nieuw probleem.
Ik heb in de eerste instantie na zoeken, deze pagina gevonden, met daarop het volgende:
I couldn't find any SUSE installation sources for the DVD decoding program, so you'll have to download it on your own. Go to your Gecko menu, then select Internet, then Web Browser, then click on Web Browser (Konqueror). When Konqueror opens, copy and paste in this address:
http://download.videolan....bdvdcss2-1.2.9-1.i386.rpm
Or just click here if you want a link. Konqueror will ask you what you want to do with the file. You could save it to your Desktop, then double-click it to install it, but an easier way is to select the Open With button. That will bring up a popup window. In that window, click on System, then Configuration, then Package Manager (KPackage). (If you do not have KPackage installed, go back to the YaST software manager and install the kdeadmin3 package, then restart this process.) The KPackage program will read the DVD decoding package from the Web. Click on the Install button at the bottom of the KPackage window, then click on Install in the next window too. You will be asked for your root password; type it in and press Enter. Shortly thereafter, the DVD decoding library will be installed. Click on the Done button, then close KPackage and Konqueror.
Next you'll have to modify the video player so that it will play DVDs. While it originally had this functionality built in, Novell has removed it to make life more difficult for people who want to watch DVDs on their computer.
Go into YaST and select Software Management. The familiar package selection screen will come up. In the Search box, type in xine and then click Search. About two dozen entries will appear in the right-hand pane. Right-click on all of the blue-colored packages (there should be at least two) and select Update from the drop-down menu. Click on Accept when you're done, and then click on Continue in the ensuing Automatic Changes screen. The updated software will now download and install properly. When it's finished, a popup window will ask you if you'd like to install more software. Click on Finish and you'll be brought back to YaST's software manager.
Na dit allemaal gedaan te hebben, kreeg ik dus een melding "Warning: This version of Xine lacks support for playing DVD discs for legal reasons". Ook na wat enig zoekwerk deze mogelijkheden gevonden. En daarna de eerste 4 stappen uitgevoerd van deze pagina.
Bij stap 4 ging het mis, ik merkte op dat het bestand wat ik daar installeer, overeenkomt met het bestand wat ik als aller eerste geinstalleerd had, alleen was het versie nummer anders. Ter verduidelijking, als eerste las ik dus dat ik "libdvdcss2-1.2.9-1.i386.rpm" en toen ik bij stap 4 op deze pagina kwam, kon ik "libdvdcss-1.2.8-1.network.i386.rpm" niet installeren omdat deze conflicten gaf met het eerder geinstalleerde bestand. Best logisch, want het een is nieuwer dan de ander, dus ik probeerde weer een dvd af te spelen.
Helaas lukte dit weer niet, zodra de dvd afgespeeld wordt, knalt/crasht het programma eruit, en krijg ik de volgende foutmelding:
(no debugging symbols found)
Using host libthread_db library "/lib/tls/libthread_db.so.1".
0xffffe410 in ?? ()
#0 0xffffe410 in ?? ()
#1 0xbfffe058 in ?? ()
#2 0x00000002 in ?? ()
#3 0x00000000 in ?? ()
#4 0x4139105e in siglongjmp () from /lib/tls/libpthread.so.0
#5 0x412bf35a in XInitThreads () from /usr/X11R6/lib/libX11.so.6
#6 0x412865f6 in XFreeCursor () from /usr/X11R6/lib/libX11.so.6
#7 0x40bfcf3c in QCursorData::~QCursorData ()
from /usr/lib/qt3/lib/libqt-mt.so.3
#8 0x40bfd18b in QCursor::~QCursor () from /usr/lib/qt3/lib/libqt-mt.so.3
#9 0x40bfd1d1 in QCursor::~QCursor () from /usr/lib/qt3/lib/libqt-mt.so.3
#10 0x414cf05c in __cxa_finalize () from /lib/tls/libc.so.6
#11 0x40be0ef2 in ?? () from /usr/lib/qt3/lib/libqt-mt.so.3
#12 0x4111d7e0 in ?? () from /usr/lib/qt3/lib/libqt-mt.so.3
#13 0x44706cb0 in ?? ()
#14 0xbfffe138 in ?? ()
#15 0x44ad388b in ?? () from /usr/lib/libldap-2.2.so.7
#16 0x41114140 in ?? () from /usr/lib/qt3/lib/libqt-mt.so.3
#17 0x411158d4 in ?? () from /usr/lib/qt3/lib/libqt-mt.so.3
#18 0xbfffe148 in ?? ()
#19 0x4104772a in _fini () from /usr/lib/qt3/lib/libqt-mt.so.3
#20 0x4104772a in _fini () from /usr/lib/qt3/lib/libqt-mt.so.3
#21 0x4000da5d in _dl_rtld_di_serinfo () from /lib/ld-linux.so.2
#22 0x414cedf0 in exit () from /lib/tls/libc.so.6
#23 0x40be97f2 in QApplication::x11_initialize_style ()
#24 0x4087187d in KApplication::xioErrhandler ()
from /opt/kde3/lib/libkdecore.so.4
#25 0x408718c9 in KApplication::xioErrhandler ()
#26 0x412a118d in _XIOError () from /usr/X11R6/lib/libX11.so.6
#27 0x412a28c6 in _XEatData () from /usr/X11R6/lib/libX11.so.6
#28 0x412a3d13 in _XEventsQueued () from /usr/X11R6/lib/libX11.so.6
#29 0x41293221 in XPending () from /usr/X11R6/lib/libX11.so.6
#30 0x40c03bd0 in QEventLoop::processEvents ()
#31 0x40c6ee51 in QEventLoop::enterLoop () from /usr/lib/qt3/lib/libqt-mt.so.3
#32 0x40c6ec96 in QEventLoop::exec () from /usr/lib/qt3/lib/libqt-mt.so.3
#33 0x40c5894f in QApplication::exec () from /usr/lib/qt3/lib/libqt-mt.so.3
#34 0x08060de2 in ?? ()
#35 0xbffff020 in ?? ()
#36 0x00000000 in ?? ()
#37 0x00000000 in ?? ()
#38 0x00000000 in ?? ()
#39 0x00000000 in ?? ()
#40 0x00000001 in ?? ()
#41 0x0808f2b8 in std::basic_streambuf<char, std::char_traits<char> >::_S_pback_size ()
#42 0x00000000 in ?? ()
#43 0x0808f4e0 in std::basic_streambuf<char, std::char_traits<char> >::_S_pback_size ()
#44 0x0808f4bc in std::basic_streambuf<char, std::char_traits<char> >::_S_pback_size ()
#45 0x00000004 in ?? ()
#46 0x0000001d in ?? ()
#47 0x415b9ff4 in ?? () from /lib/tls/libc.so.6
#48 0x415bb800 in __malloc_initialize_hook () from /lib/tls/libc.so.6
#49 0x080903e4 in typeinfo name for QResizeEvent ()
#50 0xbffff038 in ?? ()
#51 0x08095fa8 in typeinfo name for QAsciiDict<int> ()
#52 0x415bb820 in __malloc_initialize_hook () from /lib/tls/libc.so.6
#53 0x08108028 in ?? ()
#54 0x00000000 in ?? ()
#55 0x08107cc0 in ?? ()
#56 0x081282b8 in ?? ()
#57 0x08127d28 in ?? ()
#58 0x08135db8 in ?? ()
#59 0x00000000 in ?? ()
#60 0x00000000 in ?? ()
#61 0x00000001 in ?? ()
#62 0x080a4c20 in ?? ()
#63 0x415b9f00 in ?? () from /lib/tls/libc.so.6
#64 0x00000000 in ?? ()
#65 0x0814b8e8 in ?? ()
#66 0x08119298 in ?? ()
#67 0x081109f0 in ?? ()
#68 0x08090300 in vtable for QDragMoveEvent ()
#69 0x0809602c in typeinfo name for QAsciiDict<int> ()
#70 0x08119720 in ?? ()
#71 0x0811a748 in ?? ()
#72 0x0812d0f8 in ?? ()
#73 0x08099a28 in vtable for QCString ()
#74 0x080a3950 in ?? ()
#75 0xbffff110 in ?? ()
#76 0x0810de60 in ?? ()
#77 0x080a54c8 in ?? ()
#78 0x00000123 in ?? ()
#79 0x000000ff in ?? ()
#80 0x080903e4 in typeinfo name for QResizeEvent ()
#81 0x00000000 in ?? ()
#82 0x0809c0c0 in ?? ()
#83 0x080a2601 in ?? ()
#84 0x080a2e68 in ?? ()
#85 0x0814f220 in ?? ()
#86 0x40f8191c in QGDict::look_ascii () from /usr/lib/qt3/lib/libqt-mt.so.3
#87 0x414b9e80 in __libc_start_main () from /lib/tls/libc.so.6
#88 0x08060b81 in ?? ()
Iemand enig idee wat er fout is gegaan?
