Targa Traveller 856W MT32
  • 674 views sinds 30-01-2008
Vandaag in de folder van Lidl de Targa Traveller 856W MT32 Targa.nl 856W
Vanaf 30 januari voor EUR 1.499,- bij de Lidl incl. notebooktas, extra accu en 36maanden garantie (conform folder)
Op enkele kleine wijzigingen in de specificaties kom ik op de 856W uit, vandaar. Iemand al ervaringen met het systeem?
onderstaand komt van Targa
Model Targa Traveller 856W MT32
Processor AMD® Turion® 64 MT32 with AMD PowerNow!® technology
RAM 1024 MB DDR-RAM, extendable up to 2 GB, in total 2x 200 Pin SO-DIMM slots
Display 17" WXGA+ TFT (16:10 format)
Physical resolution: ergonomic 1440 x 900
In display lid integr. 1.300.000Pixel Webcam
Graphics ATI® Mobility® Radeon® X700 - 128 MB GDDR3 memory
Hard disk 100 GB hard disk with 5400 RPM
NEC Double Layer Multinorm DVD+R DL, DVD+R/RW, DVD-R/RW and CD-R/RW drive
Write :8 speed DVD+R, 8 speed DVD+RW, 4 speed DVD+R Double Layer, 8 speed DVD-R, 6 speed DVD-RW, 4 speed DVD-R Double Layer, 20 speed CD-RW, 24 speed CD-R
Read: 8 speed DVD-ROM, 8 speed DVD+R/-R, 5 speed DVD Double Layer, 8 speed DVD+RW/-RW, 24 speed CD-R, 20 speed CD-RW
Audio-System AC 97 compatible, 5.1 6 channel Dolby Surround Sound through optional SPDIF
4 speakers plus subwoofer
PCMCIA PC card standard compatible, Card Bus support, 1x Type-II-PC-Card
Bus types 4 x USB 2.0, 1x Firewire (IEEE 1394), Mic-In/ Speaker-Out, 1 x 15 pin external monitor, 1 x S-Video Out, Modem (RJ11), LAN (RJ45), 1 x PCMCIA TYP II, 1x Express Card, 5-in-1 Card Reader
Communication Bluetooth 2.0, WirelessLAN** MSI Mini PCI 802.11g 54 Mbit incl. antenna, 56K V.90 modem, 10/100/1000 MBit LAN (prepared for network and DSL)
Keyboard 19 mm keys, Windows® keys, embedded numeric keypad
Power supply 100-V to 240-V power pack (90 Watt) with automatic voltage adjustment, 2x intelligent Li-Ion rechargeable batteries, mains independent operation: up to 5 h (with two batteries and depending on the application)
Dimensions (WxHxD) mm 395 x 35 x 277 mm
Weight 3.4 kg including rechargeable battery
DVB-T digital and analog TV card with radio tuner
Warranty 2 years incl. pick-up and return service (6 months on the rechargeable battery)
