[fedora core 4] Oracle prerequisite checks gaan niet goed
  • Y0ur1
Hi!
ik probeer hier op mijn fedora core 4 bak (XP2400, 1 gig ram, 170 gig hd) Oracle te installeren alleen krijg een aantal errors bij de prerequirise check, om precies te zijn bij het "check kernel parameters" gedeelte, ik krijg de volgende test, met wat fouten:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
Checking operating system requirements ...
Expected result: One of redhat-3,redhat-4,SuSE-9,asianux-1,asianux-2
Actual Result: redhat-4
Check complete. The overall result of this check is: Passed
Checking operating system package requirements ...
Checking for make-3.79; found make-1:3.80-7.    Passed
Checking for binutils-2.14; found binutils-2.15.94.0.2.2-2. Passed
Checking for gcc-3.2; found gcc-4.0.0-8.    Passed
Checking for libaio-0.3.96; found libaio-0.3.104-2. Passed
Checking kernel parameters
Checking for semmsl=250; found semmsl=250.  Passed
Checking for semmns=32000; found semmns=32000.  Passed
Checking for semopm=100; found semopm=32.   Failed <<<<
Checking for semmni=128; found semmni=128.  Passed
Checking for shmmax=536870912; found shmmax=33554432.   Failed <<<<
Checking for shmmni=4096; found shmmni=4096.    Passed
Checking for shmall=2097152; found shmall=2097152.  Passed
Checking for file-max=65536; found file-max=100887. Passed
Checking for VERSION=2.6.9; found VERSION=2.6.11-1.1369_FC4.    Passed
Checking for ip_local_port_range=1024 - 65000; found ip_local_port_range=32768 - 61000. Failed <<<<
Checking for rmem_default=262144; found rmem_default=110592.    Failed <<<<
Checking for rmem_max=262144; found rmem_max=131071.    Failed <<<<
Checking for wmem_default=262144; found wmem_default=110592.    Failed <<<<
Checking for wmem_max=262144; found wmem_max=131071.    Failed <<<<
Check complete. The overall result of this check is: Failed <<<<
Problem: The kernel parameters do not meet the minimum requirements (see above).
Recommendation: Perform operating system specific instructions to update the kernel parameters.
Checking Recommended glibc version
Expected result: ATLEAST=2.3.2-95.27
Actual Result: 2.3.5-10
Checking physical memory requirements ...
Expected result: 922MB
Actual Result: 992MB
Checking available swap space requirements ...
Expected result: 1488MB
Actual Result: 1983MB
Checking Network Configuration requirements ...
Check complete. The overall result of this check is: Not executed <<<<
Recommendation: Oracle supports installations on systems with DHCP-assigned public IP addresses.  However, the primary network interface on the system should be configured with a static IP address in order for the Oracle Software to function properly.  See the Installation Guide for more details on installing the software on systems configured with DHCP.
Validating ORACLE_BASE location (if set) ...
Checking Oracle Home path for spaces...
Checking for proper system clean-up....
Checking for Oracle Home incompatibilities ....
Actual Result: NEW_HOME
Iemand die mij hierbij kan helpen? Onder windows installeren is nooit een probleem voor mij geweest, echter onder linux gaat ie nog niet helemaal goed.
alvast bedankt
[ Voor 3% gewijzigd door Y0ur1 op 22-01-2006 19:19 ]
  • MrBarBarian
  • Laatst online: 07-03-2023
Kernel parameters aanpassen en rebooten
http://www.google.nl/sear...+oracle&btnG=Zoeken&meta=
Hoe dit moet staat LETTERLIJK in de oracle documentatie..
[ Voor 61% gewijzigd door MrBarBarian op 22-01-2006 19:25 ]
iRacing Profiel
