HDTV naar DVD-image werkwijze
  • bruutone
  • Laatst online: 10-10 08:26
Ik wil een image maken die compatible is met mediacenter 2005 zonder de hdtv videobestanden te moeten encoderen. Scheelt me een hoop tijd en het is bovendien gewenst om de kwaliteit intact te houden.Gaarne suggesties...
Proces en gebruikte programma's
stap 1
.ts bestanden samenvoegen en splitten naar mpeg [1024 mb max per vob/mpeg] = HDTV2Mpeg [gelukt ]
stap 2
Handmatig veranderen van bestandsnamen naar VTS_01_1.VOB en oplopend.
stap 3
.ifo bestand maken met Ifoedit volgens onderstaande uitleg
The files you need are:
video_ts.ifo & .bup, vts_xx_0.ifo & .bup and the vts_xx_x.vob
Probably IFO structure isn't correct (PowerDVD can't handle your files). So, you need to re-create correct video_ts.ifo with the help of IFOEdit program.
1) Start IfoEdit, and press the button 'Create IFOs'.
2) Leave the options like they are. Click on arrow to load "1st VOB of Title-set". Or just specify the first VOB file of your several VOB files. For example, VTS_02_1.VOB.
3) Next, we want to have the new IFOs in the same directory, so check the box: 'Same as source'.
4) Click OK. IfoEdit scans now the VOB files and collects all IFO-releated information.
5) After it has finished collecting all needed information from the VOB files, it creates two new IFO files. For example, VIDEO_TS.IFO and VTS_01_0.IFO.
6) Now we need to do some little modifications. Click on VTS_01_0.IFO, and you will notice that the audio and subpicture attributes doesn't have a language specified.
7) To change that, double click the audio-subpicture stream. Specify the language of this stream, and click OK.
8) Done for this IFO file. Because VIDEO_TS.IFO holds a copy of the title-set attributes, you need to do the same in VIDEO_TS.IFO. So select the VIDEO_TS.IFO in IfoEdit, and specify again the language for the two streams.
stap 4
Image maken met ImgTool Burn of andere image software.
Errors
22.1.2006
NeroAPI
11:35:58 #1 Phase 112 File APIProgress.cpp, Line 278
DVD-Video files reallocation started
11:35:58 #2 DVDREALLOC -19 File DVDVideoCompilation.cpp, Line 1211
File size is not a multiple of a logical block size (2 KB)
11:35:58 #3 Phase 115 File APIProgress.cpp, Line 278
DVD-Video files reallocation failed
11:35:58 #4 Text 0 File NeroAPIBurnFS.cpp, Line 212
Failed to realloc DVD video files
Wat doe ik verkeerd?
