[postfix] connection timed out
  • trinite_t
  • Laatst online: 08-10 15:11
Ik heb op mijn server postfix draaien, dit werkt perfect, mits ik een relayhost instel:
relayhost = mail.wanadoo.nl
maar als ik deze weg haal, krijg ik opeens timeouts bij het versturen van mail, of een "Undelivered Mail Returned to Sender"
bij de timeouts krijg ik het volgende in m'n logs:
Jan 21 11:58:51 localhost postfix/pickup[6029]: 3E5B915732A: uid=0 from=<root>
Jan 21 11:58:51 localhost postfix/cleanup[6172]: 3E5B915732A: message-id=<20060121105850.3E5B915732A@*.mine.nu>
Jan 21 11:58:51 localhost postfix/qmgr[6030]: 3E5B915732A: from=<root@*.mine.nu>, size=312, nrcpt=1 (queue active)
Jan 21 11:59:21 localhost postfix/smtp[6174]: connect to gmail.com[64.233.171.107]: Connection timed out (port 25)
Jan 21 11:59:51 localhost postfix/smtp[6174]: connect to gmail.com[216.239.57.107]: Connection timed out (port 25)
Jan 21 12:00:21 localhost postfix/smtp[6174]: connect to gmail.com[64.233.161.107]: Connection timed out (port 25)
Jan 21 12:00:21 localhost postfix/smtp[6174]: 3E5B915732A: to=<*@gmail.com>, relay=none, delay=91, status=deferre
d (connect to gmail.com[64.233.161.107]: Connection timed out)
Jan 21 12:02:15 localhost postfix/qmgr[6030]: 22D5B157543: from=<root@*.mine.nu>, size=305, nrcpt=1 (queue active)
Jan 21 12:02:45 localhost postfix/smtp[6338]: connect to hotmail.com[64.4.32.7]: Connection timed out (port 25)
Jan 21 12:03:15 localhost postfix/smtp[6338]: connect to hotmail.com[64.4.33.7]: Connection timed out (port 25)
Jan 21 12:03:15 localhost postfix/smtp[6338]: 22D5B157543: to=<*@hotmail.com>, relay=none, delay=61, status=defer
red (connect to hotmail.com[64.4.33.7]: Connection timed out)
en de mail die ik binnenkreeg:
The Postfix program
<*@student.utwente.nl>: Host or domain name not found. Name service error
    for name=student.utwente.nl type=A: Host found but no data record of
    requested type
Reporting-MTA: dns; *.mine.nu
X-Postfix-Queue-ID: D049C157658
X-Postfix-Sender: rfc822; root@*.mine.nu
Arrival-Date: Sat, 21 Jan 2006 12:22:17 +0100 (CET)
Final-Recipient: rfc822; *@student.utwente.nl
Action: failed
Status: 5.0.0
Diagnostic-Code: X-Postfix; Host or domain name not found. Name service error
    requested type
weet iemand hoe dit te fixen is? ik zit nu namelijk aan de mailserver van wanadoo vast.. (die is snel zat, maar zonder wanadoo is de mail toch echt nog sneller op z'n plek.)
The easiest way to solve a problem is just to solve it.
  • Spleasure
  • Laatst online: 23-09 14:04
Spleasure
Ik hier?
Dat komt omdat wanadoo het niet toestaat om direct naar andere SMTP servers te verbinden, uit oogpunt van beveiliging: zo kunnen spywarbots geen spam gaan versturen zonder dat wanadoo het merkt en de klant kan afsluiten of een andere maatregel kan nemen.
  • trinite_t
hmmz, das jammer.. maar nu weet ik iig dat het niet aan mijn instellingen ligt :D. dan moet ik het nog maar een tijdje doen met de wanadoo mailserver
