Ik zet hieronder ff het e-mailtje wat ik naar Promise heb gestuurd, dus in het engels:
Kunnen jullie hier oplossingen voor aandragen?Hi,
I'm kind of having trouble with your Ultra66 controller card. It won't work stable in my system. The first problem is: In MS-DOS I cannot access my HD that's connected to the Ultra66, and in Win98 (First Edition) the drive letter assigned to my HD is not D: (which should be normal for a second HD) but it is F:, after my 3 partitions on my first drive.
OK, some info on my system:
- Abit KA7 with Athlon650 (running at 100x6,5)
- 1x 17 Gb Maxtor on primary IDE port
- 1x CD-RW on secondary IDE port
- 128Mb PC100 SDRAM
- Asus V6600 DeLuxe
- SoundBlaster Live! Value
- 10/100Mbit network controller
- Promise Ultra66 controller
- 1x 20 Gb Quantum HD on primary IDE port
- 1x DVD-ROM and 1x ZIP-100 on secondary IDE port
I also had the problem that if I attached both HD's to the Promise and set the BIOS to boot from SCSI, the HD's were accessable from MS-DOS, but Win98 would not install and Norton Ghost wasn't able to place back the backup created just a day ago when the HD's weren't on the Promise, but the CD-ROM's were.
And then the final problem, which I'm not sure belongs here, but I might as well ask: I get a lot of registry errors with Windows since I'm using the Abit KA7, does this have anything to do with your card? Or is this Abit's problem?
If nothing is written below, I was the last to reply...
