Ik probeer PHP 4.4.2 met CURL te installeren op Red Hat Linux 9, maar krijg telkens een error bij
commando: ./configure --with-curl=/usr
Bij het onderdeel "Configuring extensions" krijg ik de volgende melding
checking for curl_easy_perform in -lcurl... no
configure: error: There is something wrong. Please check config.log for more information.
Dit staat in de config.log
configure:12036: checking for yp_get_default_domain
configure:12064: gcc -o conftest -g -O2 conftest.c 1>&5
/tmp/ccmBojkd.o(.text+0xa): In function `main':
/var/sadmin/install/php-4.4.2/configure:12058: undefined reference to `yp_get_default_domain'
collect2: ld returned 1 exit status
configure: failed program was:
#line 12041 "configure"
#include "confdefs.h"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char yp_get_default_domain(); below. */
#include <assert.h>
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
int main() {
/* The GNU C library defines this for functions which it implements
to always fail with ENOSYS. Some functions are actually named
something starting with __ and the normal name is an alias. */
#if defined (__stub_yp_get_default_domain) || defined (__stub___yp_get_default_domain)
choke me
#else
Iemand die mij kan helpen?
#include <assert.h>
int main() {
choke me
#else
