[COD2] Fatal error bij opstarten
  • 100 views sinds 30-01-2008
Ik krijg een fatal error bij het opstarten:
CoD2 MP 1.0 build win-x86 Oct 6 2005
----- FS_Startup -----
Current language: english
Current search path:
D:\GAMES\Call of Duty 2\main\iw_14.iwd (4038 files)
D:\GAMES\Call of Duty 2\main\iw_13.iwd (22624 files)
D:\GAMES\Call of Duty 2\main\iw_12.iwd (1016 files)
D:\GAMES\Call of Duty 2\main\iw_11.iwd (1462 files)
D:\GAMES\Call of Duty 2\main\iw_10.iwd (1936 files)
D:\GAMES\Call of Duty 2\main\iw_09.iwd (2142 files)
D:\GAMES\Call of Duty 2\main\iw_08.iwd (2723 files)
D:\GAMES\Call of Duty 2\main\iw_07.iwd (3384 files)
D:\GAMES\Call of Duty 2\main\iw_06.iwd (990 files)
D:\GAMES\Call of Duty 2\main\iw_05.iwd (928 files)
D:\GAMES\Call of Duty 2\main\iw_01.iwd (16 files)
D:\GAMES\Call of Duty 2\main\iw_00.iwd (102 files)
D:\GAMES\Call of Duty 2/main
D:\GAMES\Call of Duty 2/raw
D:\GAMES\Call of Duty 2/raw_shared
D:\GAMES\Call of Duty 2/devraw
D:\GAMES\Call of Duty 2/devraw_shared
D:\GAMES\Call of Duty 2\main\localized_english_iw10.iwd (414 files)
localized assets iwd file for english
D:\GAMES\Call of Duty 2\main\localized_english_iw09.iwd (98 files)
D:\GAMES\Call of Duty 2\main\localized_english_iw08.iwd (8 files)
D:\GAMES\Call of Duty 2\main\localized_english_iw07.iwd (1014 files)
D:\GAMES\Call of Duty 2\main\localized_english_iw06.iwd (3110 files)
D:\GAMES\Call of Duty 2\main\localized_english_iw05.iwd (5310 files)
D:\GAMES\Call of Duty 2\main\localized_english_iw04.iwd (6240 files)
D:\GAMES\Call of Duty 2\main\localized_english_iw03.iwd (6580 files)
D:\GAMES\Call of Duty 2\main\localized_english_iw02.iwd (6404 files)
D:\GAMES\Call of Duty 2\main\localized_english_iw01.iwd (5510 files)
D:\GAMES\Call of Duty 2\main\localized_english_iw00.iwd (4764 files)
File Handles:
80813 files in iwd files
execing default_mp.cfg
couldn't exec language.cfg
========= autoconfigure
configure_mp.csv: using CPU configuration 2 GHz 512 MB
execing configure_mp.cfg
configure_mp.csv: using GPU configuration "GeForce FX 59*"
Measured CPU speed is 2.08 GHz
System memory is 1024 MB (capped at 1 GB)
Video card is "NVIDIA GeForce FX 5900"
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: FRENKIEGANGSTA
IP: 192.168.2.102
IP: 192.168.254.1
IP: 192.168.142.1
----- Initializing Renderer ----
----- Client Initialization -----
----- Client Initialization Complete -----
----- R_Init -----
Getting Direct3D 9 interface...
Pixel shader version is 2.0
Vertex shader version is 2.0
Video card or driver doesn't support separate alpha blend, glow will be disabled.
Direct3D 7 code path is available.
Direct3D 9 code path is available.
Using Direct3D 7 code path because r_rendererPreference is set to dx7.
Attempting 800 x 600 fullscreen with 32 bpp at 60 hz
Game window successfully created.
Creating Direct3D device...
Com_TouchMemory: 0 msec. Using sum: 0
Initializing render targets...
Requested frame buffer to be 24-bit color with 8-bit alpha
DirectX returned a frame buffer that is 24-bit color with 8-bit alpha
Initializing static model cache...
Initializing dynamic buffers...
Initializing particle cloud buffer...
Creating Direct3D queries...
Setting initial state...
DirectX reports 128 MB of video memory and 328 MB of available texture memory.
Using video memory size to cap used texture memory at 112 MB.
Texture detail is set automatically for DirectX 7.
Using picmip 0 on most textures, 0 on normal maps, and 0 on specular maps
ERROR: Couldn't open techniqueSet 'materials_dx7/techniquesets/default.techset'
Error during initialization:
couldn't load material '$default'
sys specs: amd xp 2800+, 1gig ram, geforce fx5900
kan iemand me helpen?
  • EyeWitness
  • Laatst online: 16-10 09:43
Legaal?
jazeker, en kan op het internet niets vinden. Ben er de hele dag al mee bezig. Heeft het met ontbrekende files van COD2 te maken of met dx7? Hij maakt ook geen config file (config_mp.cfg) aan, omdat ie niet zo ver komt denk ik.
IK heb ook een blauw scherm. Hier is een afdruk van het scherm : http://users.pandora.be/wimdb/Photo-0098.jpg
IK gebruik ook een Gforce 6600 gt 1 gb ram , genoeg harde schijf,... de rest is in feite niet zo belangerijk. COD 1 kan ik in multiplayer zonder problemen spelen, COD 2 kan ik spelen, maar COD
multiplayer lukt totaal niet, ik krijg telkens day blauwe scherm. Niets helpt....
dit heb ik reeds geprobeerd: update win xp
update COD 2 patches
update directx 9
COD helemaal verwijderd + resterende gegevens, daarna opnieuw geinstalleerd.
IN de computerwinkel vinden ze het ook niet, ze hebben het geheugen verwisseld, grafische kaart eens vervangen, updates hier en daar. Niets helpt gewoon.
tot nu toe vind ik niets die me geholpen heeft. Op een Mac machine zou dit nooit gebeuren...
  • Crash
  • Laatst online: 17-10 11:25
Rustig dude, 4 topics kicken omdat jij een mogelijk zelfde error hebt is niet bepaald een strak plan :o Open liever een eigen topic :)
