Netwerk probleem
  • Hingking
  • Laatst online: 13-05-2025
Hingking
Duikfanaat
Omdat mijn torrent erg traag gaat en ik geen poort kan vrijmaken ben ik aan het proberen om wat netwerkeigenschappen na te gaan. Ik heb internet via de kabel, 1 PC, via een kabelmodem Motorola Cybersurfr Wave en een ethernet adapter van D-Link.
Als ik bij Windows help and support de network diagnostics draai krijg ik een foutmelding:
Pingen naar de DHCP server lukt niet: time out.
Network Adapters [00000001] D-Link DE-528 Ethernet PCI Adapter FAILED
Caption = [00000001] D-Link DE-528 Ethernet PCI Adapter
DatabasePath = %SystemRoot%\System32\drivers\etc
DefaultIPGateway = 213.118.152.1(Same Subnet) (PASSED)
Pinging 213.118.152.1 with 32 bytes of data:
Reply from 213.118.152.1: bytes=32 time=50ms TTL=50
Reply from 213.118.152.1: bytes=32 time=30ms TTL=30
Reply from 213.118.152.1: bytes=32 time=9ms TTL=9
Reply from 213.118.152.1: bytes=32 time=28ms TTL=28
Ping statistics for 213.118.152.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 9ms, Maximum = 50ms, Average = 29ms
Description = D-Link DE-528 Ethernet PCI Adapter - Packet Scheduler Miniport
DHCPEnabled = TRUE
DHCPLeaseExpires = 1:31:18 18-1-2006
DHCPLeaseObtained = 23:31:18 17-1-2006
DHCPServer = 195.130.132.99 (FAILED)
Pinging 195.130.132.99 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 195.130.132.99:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
DNSDomain = telenet.be
DNSEnabledForWINSResolution = FALSE
DNSHostName = henquet
DNSServerSearchOrder (PASSED)
195.130.131.3 (PASSED)
Pinging 195.130.131.3 with 32 bytes of data:
Reply from 195.130.131.3: bytes=32 time=15ms TTL=15
Reply from 195.130.131.3: bytes=32 time=21ms TTL=21
Reply from 195.130.131.3: bytes=32 time=4ms TTL=4
Reply from 195.130.131.3: bytes=32 time=18ms TTL=18
Ping statistics for 195.130.131.3:
Minimum = 4ms, Maximum = 21ms, Average = 14ms
195.130.130.131 (PASSED)
Pinging 195.130.130.131 with 32 bytes of data:
Reply from 195.130.130.131: bytes=32 time=11ms TTL=11
Reply from 195.130.130.131: bytes=32 time=7ms TTL=7
Reply from 195.130.130.131: bytes=32 time=13ms TTL=13
Ping statistics for 195.130.130.131:
Minimum = 7ms, Maximum = 13ms, Average = 9ms
DomainDNSRegistrationEnabled = FALSE
FullDNSRegistrationEnabled = TRUE
GatewayCostMetric = 30
Index = 1
IPAddress = 213.118.152.163 (PASSED)
Pinging 213.118.152.163 with 32 bytes of data:
Reply from 213.118.152.163: bytes=32 time<1ms TTL=0
Ping statistics for 213.118.152.163:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
IPConnectionMetric = 30
IPEnabled = TRUE
IPFilterSecurityEnabled = FALSE
IPSecPermitIPProtocols = 0
IPSecPermitTCPPorts = 0
IPSecPermitUDPPorts = 0
IPSubnet = 255.255.252.0
IPXEnabled = FALSE
MACAddress = 00:80:C8:F3:7E:E0
PMTUBHDetectEnabled = FALSE
PMTUDiscoveryEnabled = TRUE
ServiceName = RTL8029
SettingID = {C23A44EC-C8FB-47C7-92AD-AA711DF5D1CC}
TcpipNetbiosOptions = 0
TcpWindowSize = 32767
WINSEnableLMHostsLookup = TRUE
Weet iemand wat ik hiermee moet en of dit in relatie kan staan met het feit dat ik in uTorrent geen open poort vind?
Bedankt voor de hulp
  • silverstorm
  • Laatst online: 05-10 18:23
silverstorm
tearing me apart
Een van je DNS-server(195.130.132.99) leeft niet (of lijkt niet te leven). Daarna gaat hij naar de tweede DNS-server(195.130.131.3). Dit maakt verder opzich weinig uit. Wat echter wel eens wil helpen is je modem even aan en uitzetten (stekker eruit).
Verder snap ik het volgende niet.
Hingking schreef op woensdag 18 januari 2006 @ 00:17:
... ik geen poort kan vrijmaken ...
Wat bedoel je hiermee? heb je "het groote poortmappingsverhaal" door meneer Roelant al eens gelezen, misschien kun je daar iets mee.
Poverty stole your golden shoes, but it din’t steal your laughter
Fools memorize, smart people make notes
Het sysadmin irc-cafe
  • Hingking
Hingking
Duikfanaat
Bedankt voor de tip, ik ga eens kijken. Het probleem is dat ik geen poort in uTorrent kan instellen die werkt. Ik heb geen firewall geactiveerd en gebruik geen router, maar ben direct aangesloten op de kabelmodem (Motorola Cybersurfr)
Thx
