[gentoo]Bad blocks op raid+reiser
  • Boudewijn
Boudewijn
omdat het kan
Hoi
Specs:
gentoo 2005.1
amd64
reiserfs uit kernel 2.6.14
reiserfsprogs: 3.6.19
2 Seagate 120gb sata disks op raid0 onder /dev/md1 (sdb1 en sdc1 zijn de partities)
op md1 ligt een reiserfs dat gemount werd op /home
Probleem:
Bad blocks op de disks.
Ik merkte van de week dat ik segfaults kreeg en permissions denied's als ik (zelfs als root) naar bepaalde dirs ging. Dat stonk natuurlijk enorm....
Dus maar even raid-array geumount en reisfsck gedaan:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
zeus boudewijn # reiserfsck /dev/md1 --rebuild-tree
reiserfsck 3.6.19 (2003 www.namesys.com)
** Do not  run  the  program  with  --rebuild-tree  unless **
** something is broken and MAKE A BACKUP  before using it. **
** If you have bad sectors on a drive  it is usually a bad **
** idea to continue using it. Then you probably should get **
** a working hard drive, copy the file system from the bad **
** drive  to the good one -- dd_rescue is  a good tool for **
** that -- and only then run this program.                 **
** If you are using the latest reiserfsprogs and  it fails **
** please  email bug reports to reiserfs-list@namesys.com, **
** providing  as  much  information  as  possible --  your **
** hardware,  kernel,  patches,  settings,  all reiserfsck **
** messages  (including version),  the reiserfsck logfile, **
** check  the  syslog file  for  any  related information. **
** If you would like advice on using this program, support **
** is available  for $25 at  www.namesys.com/support.html. **
Will rebuild the filesystem (/dev/md1) tree
Will put log info to 'stdout'
Do you want to run this program?[N/Yes] (note need to type Yes if you do):Yes
Replaying journal..
Reiserfs journal '/dev/md1' in blocks [18..8211]: 0 transactions replayed
reiserfsck --rebuild-tree started at Mon Jan  9 18:25:49 2006
Pass 0:
####### Pass 0 #######
Loading on-disk bitmap .. ok, 35887609 blocks marked used
Skipping 9999 blocks (super block, journal, bitmaps) 35877610 blocks will be rea                           d
0%....20%....40%block 26047071: The number of items (63489) is incorrect, should                            be (1) - corrected
block 26047071: The free space (6152) is incorrect, should be (2352) - corrected
pass0: vpf-10110: block 26047071, item (0): Unknown item type found [161492200 2                           032149819 0x2c0340e0 ??? (15)] - deleted
..pass0: vpf-10420: block 35917454, item 10: Wrong order of items - change the t                           ype of the key [62005 61916 0x1 IND (1)] to Direct
pass0: vpf-10480: block 35917454, item 10: Wrong order of items - change the obj                           ect_id of the key [62005 61916 0x1 DRCT (2)] to 61032
pass0: vpf-10500: block 35917454, item 10: Wrong order of items - change the dir                           _id of the key [62005 61032 0x1 DRCT (2)] to 2249
..60%..                             left 11152660, 18859 /sec
The problem has occurred looks like a hardware problem. If you have
bad blocks, we advise you to get a new hard drive, because once you
get one bad block  that the disk  drive internals  cannot hide from
your sight,the chances of getting more are generally said to become
much higher  (precise statistics are unknown to us), and  this disk
drive is probably not expensive enough  for you to you to risk your
time and  data on it.  If you don't want to follow that follow that
advice then  if you have just a few bad blocks,  try writing to the
bad blocks  and see if the drive remaps  the bad blocks (that means
it takes a block  it has  in reserve  and allocates  it for use for
of that block number).  If it cannot remap the block,  use badblock
option (-B) with  reiserfs utils to handle this block correctly.
bread: Cannot read the block (43068928): (Input/output error).
Aborted
Hij heeft ongeveer een uur gedraaid. Net even een badblocks-tekst-bestand aangemakat, maar dan komt hij een nieuwe tegen (1 block verder dan die daarnet).
Dit schiet niet op, hij doet er nm lweer een uur over die te vinden , en geen idee hoelang het zo gaat duren voor ik de volgende heb,.
Ik heb na wat gegoogle badblocks gevonden, maar die hangt .... zowel op sdc1 als sdc1 als md1.
badblocks -b 4096 -p 4 -c 32768 -s /dev/sdc1
ook met de andere devices.
Weet iemand hoe ik dit het beste op kan lossen... ik zit beetje met handen in het haar. Er staat een practicum (voor deze week!) op die array en ik ben te lui geweest voor backup :P
If you have bad sectors on a drive it is usually a bad idea to continue using it.
Als je ff die melding goed gelezen had, had je geweten dat je eerst voor zover het mogelijk is nog backups moet gaan maken, omdat dit soort commando's (vooral reiserfs is daar berucht om) soms data kunnen vernietigen (nog ff afgezien van het opslaan van gevoelige data op een raid0 array :X ). Mijn tip, als dat practicum je wat waard is, probeer het dan te recoveren zonder gebruik te maken van dit soort tools (eg, gewoon cp, mv). Lukt dat niet, ga dan niet zitten hobby-bobben, en breng die disken naar een professioneel data recovery bureau. Daar kun je meestal voor een redelijk bedrag (afhankelijk van de damage) nog veel van je data terugkrijgen. Des te meer je zelf gaat klussen, des te groter de kans dat je weinig van je data terugziet.
[ Voor 20% gewijzigd door Verwijderd op 09-01-2006 22:18 ]
  • Boudewijn
Boudewijn
omdat het kan
mja ik kan de hele zaak niet meer mounten, maar om een dd te gaan doen , en dan low-level rotzooien lijkt me ook geen goed plan.
Nog meer ideeen?
