[JAVA] JList Selectie
  • 215 views sinds 30-01-2008
  • XTREEMRaGE
  • Laatst online: 10:00
XTREEMRaGE
XTRËËM|RåGË
Goedendag tweakers/tweaksters,
Ik heb zelf een klein simpel applicatie in elkaar gezeg om wat lekker van java te leren :).
Java:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
import javax.swing.*;
import java.awt.event.*;
import java.awt.*;
public class JListOpdracht extends JFrame implements ActionListener{
    private JButton knopA = new JButton("A");
    private JButton knopB = new JButton("B");
    private JButton knopC = new JButton("C");
    private JButton knopClear = new JButton("Clear");
    String woorden[] = { "Aal", "Aap", "Aas", "Arend", "Bom", "Boom", "Bos", "Bot", "Car", "Colt", "Computer", "Creative"};
    private JList list = new JList(woorden);
   public JListOpdracht(){
        Container container = getContentPane();
        container.setLayout(new BorderLayout());
        JPanel p1 = new JPanel();
        p1.setLayout(new GridLayout(1,4));
        p1.add(knopA);
        p1.add(knopB);
        p1.add(knopC);
        p1.add(knopClear);
        knopA.addActionListener(this);
        knopB.addActionListener(this);
        knopC.addActionListener(this);
        knopClear.addActionListener(this);
        JPanel p2 = new JPanel();
        p2.setLayout(new BorderLayout());
        p2.add(list, BorderLayout.CENTER);
        p2.add(p1, BorderLayout.NORTH);
        container.add(p2, BorderLayout.CENTER);
    public void actionPerformed(ActionEvent e){
        JButton knop = (JButton) e.getSource();
        if (knop == knopA){
            System.out.println("Knop A is geklikt");
            int start = 0;
            int einde = 3;
            list.setSelectionInterval(start, einde);
        else if (knop == knopB){
            System.out.println("Knop B is geklikt");
            int start = 4;
            int einde = 7;
        else if (knop == knopC){
            System.out.println("Knop C is geklikt");
            int start = 8;
            int einde = 11;
        else if (knop == knopClear){
            System.out.println("Knop Clear is geklikt");
            list.clearSelection();
        public static void main(String[] args){
        JListOpdracht frame = new JListOpdracht();
        frame.setTitle("Knoppen drukken");
        frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
        frame.setSize(400, 250);
        frame.setVisible(true);
Zal wel newbie code voor jullie zijn, maar he ben een beginner :).
Dit werkt gelukkig en ben ver gekomen(voor mij dan :P ) maar niet echt wat ik wilde hebben.
Wat ik eigenlijk wil, is dat ie moet gaan kijken welke woorden met een A, B of C begint en die selecteerd.
Dus als ik op knop A druk moet ie alle woorden die begint met A selecteren.
Je zou zeggen dat ie het wel leuk doet, maar als ik de code hieronder verander:
Java:
in
Java:
String woorden[] = { "Car", "Aap", "Bom", "Arend", "Aas", "Computer", "Bos", "Bot", "Aal", "Colt", "Boom", "Creative"};
En ik druk nu knop A in dan selecteerd ie natuurlijk de eerste 4 woorden, maar de bedoeling is dat ie alleen de woorden die beginnen met A selecteerd.
Ik heb ff gezocht op google en heb ik dit gevonden:
Java:
    String prefix = "A";
    // Search forward, starting from index 0, looking for an item that starts with "A"
    int start = 0;
    javax.swing.text.Position.Bias direction = javax.swing.text.Position.Bias.Forward;
    int woorden = list.getNextMatch(prefix, start, direction);
link van de code hierboven
Nu is ie wel leuk aan het zoeken, maar hoe krijg ik hem zover dat ie ook werkelijk de woorden selecteerd?
Of kan het heel anders??? Makkelijker??? ;)
Ik hoop dat mijn vraag een beetje duidelijk is B)
Bedankt voor jullie hulp _/-\o_
[ Voor 8% gewijzigd door XTREEMRaGE op 09-01-2006 17:18 ]
GöÐ, ®Ë§þËÇT åñÐ Höñöµ® | LÜ©K>SkïLL | XT®ËËM|®åGË ||Funky Monkeys || Fm
  • bigbeng
  • Laatst online: 26-11-2021
Zie javadoc: http://java.sun.com/j2se/...ml#setSelectedIndices(int[])
Je kan op die manier een array van indexwaarden meegeven die moeten worden geselecteerd. Hoe je die indexen bepaalt, daar zul je zelf de code voor moeten schrijven.
  • NetForce1
  • Laatst online: 28-10 22:47
NetForce1
(inspiratie == 0) -> true
bigbeng schreef op maandag 09 januari 2006 @ 17:50:
Een hint richting String.startsWith is misschien op zijn plaats.
De wereld ligt aan je voeten. Je moet alleen diep genoeg willen bukken...
"Wie geen fouten maakt maakt meestal niets!"
  • XTREEMRaGE
XTREEMRaGE
XTRËËM|RåGË
Ok tnx :D
Ga morgen ff uitproberen, helaas vandaag geen tijd :/
btw de code die als laatst is opgegeven is nix?
of... ik weet het ook ff nie meer ;x
Morgen weer :>
[ Voor 46% gewijzigd door XTREEMRaGE op 09-01-2006 19:31 ]
  • XTREEMRaGE
XTREEMRaGE
XTRËËM|RåGË
Nou ik kom er niet uit :(
pff was ik maar een java wizz :)
Uiteindelijk kom je toch weer terecht op de prefix, wat ik had gegeven als laatste code :X
Maar ja, hoe ik dat werkend kan krijgen ben ik nog niet achter ;)
  • bigbeng
Java:
public int[] getIndexes( String startLetter ) {
   int[] retval = new int[0];
   for ( int i=0; i < woorden.length; i++ ) {
      if ( woorden[i].startsWith(startLetter)  ) {
          retval = addToArray( i, retval );
   return retval;
private int[] addToArray( int value, int[] baseArray )
   int[] retval = new int[baseArray.length+1];
   for (int i=0; i < baseArray.length; i++) {
      retval[i] = baseArray[i];
   retval[baseArray.length] = value;
   return retval;
Zo, met deze code krijg je een array van het type int terug die je aan de eerder door mij genoemde methode van JList kunt voeren.
Hierbij ga ik ervan uit dat de volgorde van de strings in de variabele "woorden" gelijk is aan die in je JList.
De methode addToArray heb ik toegevoegd omdat je vantevoren niet kan weten hoe lang de array moet worden en een array heeft een vaste lengte in Java. Een andere mogelijkheid zou zijn eerst te bepalen hoe groot je array moet worden, hem te creeren en vervolgens te vullen. In feite doorloop je dan de for-lus in getIndexes 2x. Je moet zelf maar bepalen wat jij het handigst vindt.
  • Robtimus
  • Laatst online: 14:05
Robtimus
me Robtimus no like you
bigbeng schreef op woensdag 11 januari 2006 @ 13:16:
Java:
Tip: System.arraycopy(baseArray, 0, retval, 0, baseArray.length);
Deze method is niet voor niets native.
More than meets the eye
There is no I in TEAM... but there is ME
system specs
  • Kwistnix
  • Laatst online: 08:29
IceManX schreef op woensdag 11 januari 2006 @ 17:53:
Agezien van het feit dat System.arraycopy() handig is in het gebruik denk ik dat de native implementatie hiervan in de meeste gevallen qua performance een micro-optimalisatie is.
Wel een goeie tip overigens :)
  • Confusion
  • Laatst online: 01-07 21:46
Confusion
Fallen from grace
FallenAngel666 schreef op woensdag 11 januari 2006 @ 18:39:
Dat is natuurlijk waar, maar ook uit documentatie-oogpunt is het betere code.
Wie trösten wir uns, die Mörder aller Mörder?
  • bigbeng
Goeie tip, dit topic gaat op de bookmarklijst voor toekomstige referentie. (Zo zie je maar weer dat hands-on leren van een taal ook z'n nadelen heeft ;) )
  • XTREEMRaGE
XTREEMRaGE
XTRËËM|RåGË
:> zal ik ff doornemen tnx _/-\o_
[ Voor 3% gewijzigd door XTREEMRaGE op 12-01-2006 16:45 ]
