COD2 problemen met mod
hallo,
ik heb de volgende Mod voor CoD2:
RAIDERS RCMoDV2
http://www.callofduty2fil...les-article-print-25.html
Deze probeer ik te installeren maar het lukt mij niet!
The included config files are quite intuitive and self-explanatory. If you encounter any problems installing this mod, please refer all inquiries for help to our support website.
Contents of Download:
RCMoDV2_CFG.zip
RCMoDV2_IWD.zip
RCModV2_Readme1st.txt
Once both files are unzipped into folder alongside MAIN, (admin created), (ie; mysite_name) and set fs_game to the same name as that folder. This is done to avoid confusion, client problems and induce neatness and ease of file location and verification.
The Contents of your created (mysite_name) folder:
codserver.cfg
gametypes.cfg
rcmod.cfg
weapons.cfg
RCMoDV2_custom.iwd
RCMoDV2_graphics.iwd
RCMoDV2_scripts.iw d
RCMoDV2_weapons.iwd
Command Lines:
WINDOWS
"C:\Program Files\Activision\Call of Duty 2" +set fs_game (mysite_name) +set dedicated 2 +exec codserver.cfg +map_rotate
nu heb ik dus alle bestanden in de main map gezet van het spel.
en het doel gezet op:
"E:\Games\Activision\Call of Duty2\CoD2MP_s.exe" +set fs_game (RCMODV2) + set dedicated 2 +exec codserver.cfg +map_rotate
zodra ik het spel opstart krijg ik een console die allemaal dingen uitvoert alleen op de een of andere manier kan hij hier sommige bestanden niet openen of uitvoeren.
dit is de melding!
File Handles:
81756 files in iwd files
execing default_mp.cfg
couldn't exec language.cfg
execing players/Els/config_mp.cfg
fs_game is write protected.
dedicated is read only.
Measured CPU speed is 1.35 GHz
System memory is 512 MB (capped at 1 GB)
Video card is "NVIDIA GeForce4 MX 440 with AGP8X"
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: tom
IP: 000.000.000.000
--- Common Initialization Complete ---
execing codserver.cfg
net_ip will be changed upon restarting.
net_noipx will be changed upon restarting.
sv_maxclients will be changed upon restarting.
logfile opened on Wed Jan 04 19:30:23 2006
sv_cheats is write protected.
execing rcmod.cfg
Working directory: E:\Games\Activision\Call of Duty2
execing weapons.cfg
Hitch warning: 3061 msec frame time
execing gametypes.cfg
g_gametype will be changed upon restarting.
execing rcmod.cfg
execing weapons.cfg
****** script compile error *******
unknown function: (file 'extreme/_ex_clientcontrol.gsc', line 643)
self maps\mp\gametypes\_weapons::updateDisabledSingleClient(self.pers["weapon"]);
ERROR: script compile error
(see console for details)
----- Server Shutdown -----
Resolving cod2master.activision.com
cod2master.activision.com resolved to 63.146.124.40:20710
Sending heartbeat to cod2master.activision.com
==== ShutdownGame ====
Hitch warning: 6109 msec frame time
Hitch warning: 17943 msec frame time
dit is trouwens niet de hele console dat is te lang maar de belangrijkste onderdelen
in het spel als ik een nieuwe server probeer op te starten zie ik wel dat de spel types anders is en in het hoofdscherm zie ik een titel
maar zodra ik dus de server start krijg ik een soort van compile error die me naar de console verwijst
hebben meer mensen deze mod? en hoe heb jij dat gedaan?
[ Voor 20% gewijzigd door Verwijderd op 04-01-2006 19:41 ]
  • Outerspace
  • Laatst online: 02:10
Outerspace
Admin General Chat
Ik heb verder geen verstand van CoD2, maar heb je ook al je codserver.cfg aangepast :?
Wauw, een sig!
  • Opdreef
  • Laatst online: 15-10 20:53
post je cfg even... trouwens... heeft raiders geen installatie ding.. heeft awe wel.. die ownt :9
doesburg schreef op woensdag 04 januari 2006 @ 19:47:
welke cfg wil je? t zijn er 4
  • Crash
  • Laatst online: 17-10 11:25
Tikje naar SPV + titelchange
ok dank je
  • Opdreef
Verwijderd schreef op woensdag 04 januari 2006 @ 19:49:
die waarop de server draait... dus niet die van mod zelf.. maar die die je opent bij de server
  • Opdreef
