[Muis]Logitech MediaPlay, knoppen toewijzen
  • Saturnus
Ik ben van plan een Logitech MediaPlay muis te kopen het enige wat ik me nog afvraag is: Kan je de knoppen wijzigen? Dus dat als je in een game zit dat de volume omhoog knop dan even verdedigen is of herladen...je weet wel...
Wie heeft dus ervaring met deze muis?
The mouse also comes with a Fast Forward and Backward button, however these 2 buttons are quite useless. It doesn't work with most media format I use. And when it does work with the media I happen to be using, the forwarding or rewinding speed is simply way too slow to be effective. So far, I have been only able to get these 2 buttons to work when I am playing DVD on my PC, but again, because of the speed problem, I just stop using the buttons and simply use the pointer to click on the program interface instead. The worst part is that you can't assign these 2 buttons for something else. I wish future firmware upgrade from Logitech will allow user to assign functions to these 2 buttons.
http://www.amazon.com/gp/...6857720?v=glance&n=172282
Four of the buttons are fully programmable, you can even assign them keystrokes.
http://www.theage.com.au/...5/02/08/1107625206623.htm
This is the initial screen when starting Setpoint and it allows you to assign tasks to the various buttons. As you can see I have the Media button highlighted and I have it set to launch iTunes.
Afbeeldingslocatie: http://images.devshed.com/dh/stories/Logitech%20MediaPlay%20Mouse/Setpoint1.jpg
http://www.devhardware.co...diaPlay-Cordless-Mouse/2/
[ Voor 30% gewijzigd door Verwijderd op 28-12-2005 17:37 ]
  • Saturnus
Blijkbaar niet dus...wat als je alle knoppen op 'other' zet en in een spel gewoon zo'n knop probeert toe te wijzen?
http://images.devshed.com...lay%20Mouse/Setpoint4.jpg
Changing things here allows for Setpoint detect a game starting up and then to do such things as turn off mouse acceleration, speed, or button assignments, that you may or may not want to be applied while you're playing games.
De knoppen kunnen dus in ieder geval worden uitgeschakelt...ook toegewezen aan andere functie in een game???
[ Voor 57% gewijzigd door Saturnus op 28-12-2005 19:10 ]
  • Saturnus
Blijkbaar geen ervaringen met deze muis, misschien is de MX 610 een alternatief :|
[ Voor 97% gewijzigd door Saturnus op 29-12-2005 21:02 ]
  • Marco
  • Laatst online: 06:11
Je zegt het zelf al:
DJ Sebas schreef op woensdag 28 december 2005 @ 19:03:
Hiermee kan je dus precies doen wat jij wil.
[ Voor 86% gewijzigd door Marco op 30-12-2005 07:02 ]
Nogmaals: 4 knoppen kun je programmeren, de FF/REW niet. Misschien dat een update van Logitech dit veranderd.
  • Saturnus
Verwijderd schreef op vrijdag 30 december 2005 @ 07:39:
Ja...maar welke knoppen zijn FF en Rew, ik ben niet zo thuis in de wereld van afkortingen, de ligging van die knoppen heeft een grote invloed op de keuze.
  • breinonline
  • Laatst online: 16:43
breinonline
Are you afraid to be known?
Als je met google wat grote plaatjes zoekt, dan zie je dat de rechterknoppen bovenop FF en Rew zijn.
  • Saturnus
breinonline schreef op vrijdag 30 december 2005 @ 21:14:
Ik heb geprobeerd er achter te komen, maar dat is niet gelukt...en wat betekend FF en Rew nou?
Next/Previous?
  • breinonline
breinonline
Fast forward en Rewind (bij casettebandjes vroegah). Werken waarschijnlijk als volgende/vorige liedje knoppen.
  • Saturnus
breinonline schreef op zaterdag 31 december 2005 @ 12:44:
tnx
