Overclock probleempje
Ik heb een dual cellie 500
@566 met 2.3v werkt alles goed zet ik um op 600 dan krijg ik na verloop van tijd in win2k een blauw scherm met beginning psychical memory dump en dan gaat ie rebooten :'( Weet iemand of hier wat aan te doen is? Hier m'n geheugen info:
SPD dump of Dimm in socket :0
SPD - Number of bytes available :128 bytes
SPD - Total bytes of memory device :256 bytes
SPD - Revision :1.2
SPD - Checksum :OK
Manufacturer - Name :Unknown ID: 0000000000000000
Manufacturer - Location :0 ($00)
Manufacturer - Part Number :
Manufacturer - Revision code :00 ($0000)
Manufacturer - Manufacturing date :$0000
Manufacturer - Assembly Serial Number :0000
Manufacturer - Manufacturer Specific Data :
Memory - Type :Sync Dram
Memory - Row Addresses :0 | 12
Memory - Column Addresses :0 | 9
Memory - Module Banks :1
Memory - Data Width :64
Memory - Voltage interface standard :LVTTL
Memory - Cycle time at Max. Supported CAS :10.0 ns.
Memory - SDRAM Access from Clock at :6.0 ns.
Memory - DIMM Configuration type :None
Memory - Refresh Rate/Type :Self Refresh, Normal (15.625 us)
Memory - Minimum Clock Delay :1
Memory - Burst Lengths Supported :Page 1 2 4 8
Memory - Banks on Each SDRAM device :4
Memory - CAS Latencies Supported :2 3
Memory - CS Latencies Supported :0
Memory - WE Latencies Supported :0
Memory - Min. Clock Cycle Time @ CL X-1 :15.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-1 :9.0 ns.
Memory - Min. Clock Cycle Time @ CL X-2 :0.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-2 :0.0 ns.
Memory - Minimum Row Precharge Time :30 ns.
Memory - Minimum Row Active to Row Active delay :30 ns.
Memory - Minimum RAS to CAS delay :30 ns.
Memory - Minimum RAS Pulse Width :60 ns.
Memory - Module Bank Density :64 MB.
Memory - Module Total Density :64 MB.
Memory - Speed :100 Mhz
SPD dump of Dimm in socket :1
SPD - Revision :1.2
SPD - Checksum :OK
Manufacturer - Manufacturing date :$FFFF
Manufacturer - Assembly Serial Number :255255255255
Memory - Cycle time at Max. Supported CAS :8.0 ns.
Memory - Min. Clock Cycle Time @ CL X-1 :10.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-1 :6.0 ns.
Memory - Minimum Row Precharge Time :20 ns.
Memory - Minimum Row Active to Row Active delay :20 ns.
Memory - Minimum RAS to CAS delay :20 ns.
Memory - Minimum RAS Pulse Width :50 ns.
Memory - Speed :125 Mhz
  • Daan
  • Laatst online: 00:09
Als je voltage al op zijn max. staat denk ik dat je op de limiet zit. Die Cellie's 500 gaan niet zo hard.
Op zaterdag 20 januari 2001 12:03 schreef Phreak het volgende:
@566 doet ie ook op 2.2v, maar weet je een goed werkende voltage mod dan?
