Ik gebruik Motherboard Monitor daarvoor met de DIMM SPD Plugin. Komt iets dergelijks uitrollen:
Manufacturer - Name :Winbond Electronic
Manufacturer - Location :83 ($53)
Manufacturer - Part Number DP100-064082AU
Manufacturer - Revision code :00 ($0000)
Manufacturer - Manufacturing date :$9929
Manufacturer - Assembly Serial Number :0000
Manufacturer - Manufacturer Specific Data :
Memory - Type :Sync Dram
Memory - Row Addresses :12
Memory - Column Addresses Memory - Module Banks :1
Memory - Data Width :64
Memory - Data Width continuation :0
Memory - Voltage interface standard :1
Memory - Cycle time at Max. Supported CAS :10 ns.
Memory - SDRAM Access from Clock at :6 ns.
Memory - DIMM Configuration type :None
Memory - Refresh Rate/Type :Self Refresh, Normal (15.625 us)
Memory - Minimum Clock Delay :1
Memory - Burst Lengths Supported age 1 2 4 8
Memory - Banks on Each SDRAM device :4
Memory - CAS Latencies Supported :2 3
Memory - CS Latencies Supported :0
Memory - WE Latencies Supported :0
Memory - Min. Clock Cycle Time @ CL X-1 :10 ns.
Memory - Max. Data Access Time from Clock @ CL X-1 :6 ns.
Memory - Min. Clock Cycle Time @ CL X-2 :63,75 ns.
Memory - Max. Data Access Time from Clock @ CL X-2 :63,75 ns.
Memory - Minimum Row Precharge Time :20 ns.
Memory - Minimum Row Active to Row Active delay :16 ns.
Memory - Minimum RAS to CAS delay :20 ns.
Memory - Minimum RAS Pulse Width :45 ns.
Memory - Module Bank Density :64 MB.
Memory - Module Total Density :64 MB.
Memory - Speed :100 Mhz
