[malware] Trojan connect naar IRC? *
Ik vond een lange lijst connecties in mijn firewall waarvan ik geen idee heb wat het is
hier een stukje paste:
2005-12-19 23:35:23 CLOSE TCP 10.0.0.1 83.53.189.150 3750 6667 - - - - - - - - -
2005-12-19 23:35:25 OPEN TCP 10.0.0.1 83.53.189.150 3751 6667 - - - - - - - - -
2005-12-19 23:35:27 CLOSE TCP 10.0.0.1 83.53.189.150 3751 6667 - - - - - - - - -
2005-12-19 23:35:29 OPEN TCP 10.0.0.1 83.53.189.150 3752 6667 - - - - - - - - -
2005-12-19 23:35:30 CLOSE TCP 10.0.0.1 83.53.189.150 3752 6667 - - - - - - - - -
2005-12-19 23:35:32 OPEN TCP 10.0.0.1 83.53.189.150 3753 6667 - - - - - - - - -
2005-12-19 23:35:33 CLOSE TCP 10.0.0.1 83.53.189.150 3753 6667 - - - - - - - - -
2005-12-19 23:35:35 OPEN TCP 10.0.0.1 83.53.189.150 3754 6667 - - - - - - - - -
2005-12-19 23:35:36 CLOSE TCP 10.0.0.1 83.53.189.150 3754 6667 - - - - - - - - -
2005-12-19 23:35:38 OPEN TCP 10.0.0.1 83.53.189.150 3755 6667 - - - - - - - - -
2005-12-19 23:35:40 CLOSE TCP 10.0.0.1 83.53.189.150 3755 6667 - - - - - - - - -
2005-12-19 23:35:42 OPEN TCP 10.0.0.1 83.53.189.150 3756 6667 - - - - - - - - -
2005-12-19 23:35:43 CLOSE TCP 10.0.0.1 83.53.189.150 3756 6667 - - - - - - - - -
2005-12-19 23:35:45 OPEN TCP 10.0.0.1 83.53.189.150 3757 6667 - - - - - - - - -
2005-12-19 23:35:46 CLOSE TCP 10.0.0.1 83.53.189.150 3757 6667 - - - - - - - - -
2005-12-19 23:35:48 OPEN TCP 10.0.0.1 83.53.189.150 3758 6667 - - - - - - - - -
2005-12-19 23:35:50 CLOSE TCP 10.0.0.1 83.53.189.150 3758 6667 - - - - - - - - -
2005-12-19 23:35:52 OPEN TCP 10.0.0.1 83.53.189.150 3759 6667 - - - - - - - - -
2005-12-19 23:35:53 CLOSE TCP 10.0.0.1 83.53.189.150 3759 6667 - - - - - - - - -
2005-12-19 23:35:55 OPEN TCP 10.0.0.1 83.53.189.150 3760 6667 - - - - - - - - -
2005-12-19 23:35:56 CLOSE TCP 10.0.0.1 83.53.189.150 3760 6667 - - - - - - - - -
2005-12-19 23:35:58 OPEN TCP 10.0.0.1 83.53.189.150 3761 6667 - - - - - - - - -
2005-12-19 23:36:00 CLOSE TCP 10.0.0.1 83.53.189.150 3761 6667 - - - - - - - - -
2005-12-19 23:36:02 OPEN TCP 10.0.0.1 83.53.189.150 3762 6667 - - - - - - - - -
2005-12-19 23:36:03 CLOSE TCP 10.0.0.1 83.53.189.150 3762 6667 -
Weet iemand wat hier aan de hand is geweest? bedankt
  • McKaamos
McKaamos
Master of the Edit-button
onsuccesvolle pogingen om verbinding te maken met IRC?
ik heb nog nooit een IRC progje gebruikt....
wat is jou uitslag bij http://www.whatismyip.com.com
Is het dat 83 nummer?
[ Voor 17% gewijzigd door Verwijderd op 20-12-2005 11:55 ]
  • MuddyMagical
  • Laatst online: 12:26
Hmmm, zou kunnen zijn dat je pc is geinfecteerd met een virus / trojan die verbinding probeert te maken naar een bepaalde IRC server om daar zijn opdrachten vandaan te halen.
Virusscanner en HitmanPro draaien!
  • Dark0r
  • Laatst online: 22-09 16:22
Dark0r
WAT
geinfecteerd met een irc worm die nu probeerd te connecten ?
  • BCC
  • Laatst online: 14:50
BCC
Dark0r schreef op dinsdag 20 december 2005 @ 11:55:
Ik weet het wel zeker.
Nee, het is niet mijn IP range, ik vrees ook een worm of bot ofzo maar als ik een virusscan doe komt ie met een trojan in de MSN.exe file nota bene, welke naturrlijk nooit verwijderd kan worden..
I
  • jbr
  • Laatst online: 03-07 10:26
jbr
Right back @ ya
Inderdaad, ook mijn eerste gedachte ... post maar eens een screenie van je processen uit taakbeheer....
Een goeie bak teringherrie in de morgen is een dag zonder zorgen!
  • Jazzy
  • Laatst online: 24-10 23:57
Jazzy
Moderator SSC/PB/AI
Moooooh!
Verwijderd schreef op dinsdag 20 december 2005 @ 12:00:
I
Veilige modus, andere virusscanner, etc.
  • Brede P
  • Laatst online: 08-01 14:43
MSN.EXE is een virus.
MSN Messenger gaat schuil onder de naam msnmsgr.exe.
  • jbr
jbr
Right back @ ya
Integendeel. MSN Messenger gebruikt msnmsgr.exe, als je denkt dat het dat is. het is een duidelijke poging om verborgen te blijven.
//edit
500 Tweakers, 1 gedachte! })
[ Voor 5% gewijzigd door jbr op 20-12-2005 12:03 ]
  • Rone
Rone
Moderator Tweaking
http://www.grc.com/port_6667.htm
Purpose:IRCU
Trojan Sightings:   Dark FTP, EGO, Maniac rootkit, Moses, ScheduleAgent, SubSeven,
The Thing (modified), Trinity, WinSatan
http://www.liutilities.co...skspro/processlibrary/MSN
Description
MSN.exe is a process belonging to MSN Explorer which adds new features to Internet Explorer. This is a non-essential process. Disabling or enabling this is down to user preference.
Note
MSN.exe is also a process which is registered as the W32.Flita Trojan. This Trojan allows attackers to access your computer, stealing passwords and personal data. It is a registered security risk and should be removed immediately.
Symantec Security Response:
http://securityresponse.s.../venc/data/w32.flita.html
[ Voor 27% gewijzigd door Rone op 20-12-2005 12:05 ]
PC1: 9800X3D + RX 9070 XT
PC2: 5800X3D + RTX 3080
  • MuddyMagical
Alsjeblieft : http://securityresponse.s.../venc/data/w32.flita.html
Leuker kunnen we het niet maken, wel makkelijker... :)
@ r00n: En dan snel editten hé! ;(
[ Voor 13% gewijzigd door MuddyMagical op 20-12-2005 12:08 ]
bedankt zover iedereen, ik zal nog eens scannen...
  • Rone
Rone
Moderator Tweaking
MuddyMagical schreef op dinsdag 20 december 2005 @ 12:07:
Ik vind ook maar informatie along the way.
Moet ik die dan maar niet toevoegen aan mijn post omdat jij twee minuten later dezelfde pagina vindt :?
Mijn edit is van 12:05. Jouw post is van 12:07... Let even op, wil je? :)
[ Voor 12% gewijzigd door Rone op 20-12-2005 12:15 ]
  • MuddyMagical
r00n schreef op dinsdag 20 december 2005 @ 12:09:
Ja, maar ik kan niet knippen en plakken... Moest heel dat adres overtypen... Maar ik ben niet boos hoor.. :P ;)
  • pasta
  • Laatst online: 29-08 10:23
pasta
Ondertitel
Even een titelfix :)
Maar goed, lees Beveiliging en Virussen - Nieuw topic starten eens door, ik mis namelijk nog een hoop informatie in je TS. Zo had je kunnen kijken met HijackThis icm Google en Jotti's online malware scan of je nog meer verdachte files tegenkomt. Je kunt vervolgens een volledige scan draaien met 1 van de virusscanners die het bestand herkent. :)
Signature
Wellicht een trojan die naar een botnetje connect.
Btw, je kan beter geen ip adressen posten. Je kan voor de gein mIRC een opstarten en connecten naar de server waarna je PC verbinding wil maken.
Groet,
Jeroen
  • Clueless
  • Laatst online: 26-09 13:56
Verwijderd schreef op dinsdag 20 december 2005 @ 17:39:
Groet,
Jeroen
Bijna wel zeker ja... of jij moet iets in Spanje hebben naast Sinterklaas? :P
inetnum: 83.51.241.0 - 83.56.132.255
netname: RIMA
descr: TELEFONICA DE ESPANA
descr: Provider Local Registry
country: ES
admin-c: AFG2-RIPE
admin-c: JB986-RIPE
tech-c: FLT14-RIPE
tech-c: FSB3-RIPE
status: ASSIGNED PA
remarks: ***************************************************
remarks: For ABUSE/SPAM/INTRUSION issues
remarks: PLEASE CONTACT THROUGH LINK
remarks: http://www.telefonicaonline.com/nemesys/
remarks: or send mail to nemesys@telefonica.es
remarks: any mail to adminis.ripe@telefonica.es will be ignored
I Don't Know, So Don't Shoot Me
