[Quadro NVS 280] Baggerkaart?
  • J-air
  • Laatst online: 23-11-2023
Ik heb vanwege RMA-problemen (@$@$-gezeik) ff geen videokaart.
Nou kan ik van een vriend een Quadro NVS 280, pci-express kopen vooor ... (een laag bedrag onder 30 euro)
Ik zit dus ff zonder videokaart en vroeg me af of ik hier een beetje mee kon CS 1.6'en
Voor de rest hoeft niks alleen CS 1.6 zou ik al blij mee zijn.
Is deze kaart een beetje fatsoenlijk om tijdelijk (zeg 2-3 weekjes te hebben) mee te kunnen computeren of is het 3-maal niks?
Details;
OVERVIEW
NVIDIA Quadro NVS
The Standard for Corporate Graphics
Business professionals who spend their days in front of a workstation understand the importance and value of a solution that helps them work more efficiently. Whether it’s tracking securities across multiple displays or managing multiple desktop applications, corporate users are looking for the right solution to fit their business requirements. The NVIDIA Quadro NVS series of graphics boards deliver the compatibility, quality, and performance that corporate users demand. From small businesses to enterprise-level corporations, the NVIDIA Quadro NVS series features products to fit every user’s needs.
Utilizing the advanced nView software, the NVIDIA Quadro NVS 280 graphics board for PCI Express™ delivers next-generation multi-monitor capabilities through its dual integrated 350 MHz RAMDACs that deliver up to 2048 x1536 at 75Hz, 32bpp on each display and up to a maximum digital resolution of 1600x1200 @ 60Hz.
PCI Express Support
Designed specifically to take advantage of the next-generation PCI Express bus architecture. This new bus doubles the bandwidth of AGP 8X delivering over 4 GB per second in both upstream and downstream data transfers.
KEY FEATURES & BENEFITS
* Dual 350MHz RAMDACs delivers INDUSTRY BEST IMAGE QUALITY
* Integrated TMDS Transmitters
* High-Density DMS-59 connectors
* Low-profile form factor provides a cost effective and compact solution
* Passive Heatsink provides a silent cooling solution
INCREASED PRODUCTIVITY FOR END-USERS
Seamlessly integrated within the familiar Microsoft® Windows® environment, NVIDIA nView™ multi-display technology offers a robust set of features to maximize productivity. For example, the
Application Extensions feature allows applications such as Microsoft Internet Explorer to take full advantage of multiple displays.
NVIDIA nView™ Multi-Display Software
Sets a new standard in workstation productivity by delivering unprecedented stability, image quality and performance. No other solution features rock-solid stability with productivity-enhancing functionality, all seamlessly integrated into the Windows environment
* Intuitive and interactive NVIDIA nView Setup Wizard
* Multi-desktop support enable users to create up to 32 individual desktops
* Improved desktop management
* Superior application and profile management
* Advanced window effects
IT FRIENDLY SOLUTIONS WITH INDUSTRY’S BEST SUPPORT
NVIDIA Quadro NVS solutions are built not only with the user’s productivity in mind, but also to streamline and enhance deployment and maintenance. The nView Profiles feature allows IT managers to create custom desktop settings for all their users. These settings can then be globally applied to multiple systems using nView IT management tools.
p.s. Ik heb review gezocht maar kan niks vinden :(, dus niet zeuren over te weinig inzet }:O
[ Voor 71% gewijzigd door J-air op 16-12-2005 22:46 ]
  • -ErikE-
  • Laatst online: 30-08 18:05
batman73 schreef op vrijdag 16 december 2005 @ 22:43:
nou lekker dan |:( , over alles is een review geschreven dus een voordehand liggend antwoord is, verder zoeken :Y)
Het blijkt na een beetje zoeken, dat het een kaart is met NV37 (geforce 5300) chip met een PCIe voetje.
/me p43000 wordt zo moe van mensen die beweren gezocht te hebben naar reviews en dit niet gedaan hebben
kijk eens wat /me p43000 gevonden heeft met google: klikkerdeklik
damn you krizzle }) klik
[ Voor 59% gewijzigd door -ErikE- op 17-12-2005 10:45 ]
  • J-air
is dat een review ? of is dat een winkel waar ze hem verkopen??
Oftewel zelf heb je ook geen review gevonden ;)
Neeh bedankt, je hebt me erg geholpen en dat meen ik serieus.
Maar hebben mensen nog ervaringen met zo'n kaart?
  • Krizzie
  • Laatst online: 30-08 12:09
Krizzie
Progressive Music \o/
Niks kunnen vinden? :?
http://www.nvnews.net/vbulletin/showthread.php?t=59083
Hij zit dus rond het niveau van een FX 5300, niet echt denderend snel dus. Maar wel snel zat voor CS.
Geluidswolk
Op zich een mooi kaartje, maar de Quadro chips zijn een stuk langzamer met games, daar zijn ze ook helemaal niet voor bedoeld. Ik denk dat het erg kan tegenvallen. Met een game is mijn Quadro FX1000 ook niet vooruit te branden.
