Online radio beluisteren lukt niet met WMP 10
Ik krijg altijd deze error met windows media player 10 als ik radio10gold of andere radiozenders (niet allemaal!) wil beluisteren:
Windows Media Player cannot play the file because the specified protocol is not supported. If you typed a URL in the Open URL dialog box, try using a different transport protocol (for example, "http:" or "rtsp:").
C00D11BB: Cannot play the file
Windows Media Player cannot play the file because the specified protocol is either not supported by the Player or not supported by the server.
If you encountered this error by clicking a link on a Web page, the link might not be valid.
If you encountered this error by typing a Uniform Resource Locator (URL) in the Open URL dialog box, try opening the file by using a different transport protocol (for example, "http:" or "rtsp:").
A list of protocols that are supported by the Player and the correct syntax follows:
mms://server/filename (for example, a file with a .wma, .wmv, .asf, or .mp3 extension)
http://server/filename
rtsp://server/filename
mms://server/sami.asf?SAMI=http://server/sami/sami_demo.smi (SAMI file)
If Windows Media Player supports the protocol and you still cannot play the content, verify that the Player is configured to use all of its supported protocols.
To configure protocol settings
On the Tools menu, click Options, and then click the Network tab.
In the Streaming protocols area, select all the protocol check boxes.
Note
The supported protocols can be used only to stream digital media files. Windows Media Player cannot be used as a browser.
Error ID = 0xC00D11BB, Condition ID = 0x00000000
Wat heb ik gedaan?
# Download and reinstall Windows Media Player. Don’t try and uninstall it first.
# Navigate to Tools | Options | Files Types in WMP. Highlight the extension that you are having problems streaming, make sure it's checked and press Ok.
# If your system has RealPlayer or RealOne installed try the steps below.
* Open RealPlayer, go to Tools, Preferences, File Types tab. Look under File Types. Uncheck everything except RealAudio and RealVideo files.
* Uncheck the box to make RealPlayer the default player.
* Open Internet Explorer and go to Tools | Internet Options | Programs and check Internet Explorer should check to see whether it is the default browser.
* 3) Reinstall Windows Media Player. Select all supported file types when asked.
* 4) Restart your PC and then try and access the stream.
# Check HTTP and Uncheck Multicast, UDP, TCP under Tools | Options | Network
# Select all Streaming Protocols that you just disabled from above.
A)Update your windows media player .Go to HELP > Check for Media player updates
B)Try to use clear the Media PLayer URL list.To do this follow the below steps
Close Windows Media Player (if it's running).
1)Click Start -> Run, and type in: regedit.exe
2)Open up the branch HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\Player\RecentFileList
3)Delete each File# key listed.
Ik heb dus al zitten zoeken maar niets wil maar helpen, ik krijg die dingen geloof ik wel beluisterd met windows media player 9. Ik gebruik windows Xp pro en ik heb geen service packs gedownload. Ik heb geen firewall of antivirus. Alvast bedankt!
[ Voor 4% gewijzigd door Verwijderd op 16-12-2005 22:11 ]
