Opnieuw loop ik vast op het installeren van een perl module namelijjk: Net::DNS.
TIjdens de installatie krijg ik de volgende foutmelding:
Ik heb al geprobeerd om het probleem op te lossen door:
Ik heb geen idee hoe ik dat op kan lossen. Wie weet er raad?
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
| Testing module
Executing make test ..
PERL_DL_NONLAZY=1 /usr/bin/perl5.8.4 "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'bl
ib/arch')" t/*.t
t/00-load..................ok
t/00-pod...................ok
t/00-version...............ok
t/01-resolver-env..........ok
t/01-resolver-file.........ok
7/8 skipped: Could not read configuration file
t/01-resolver-opt..........ok
t/01-resolver..............ok
t/02-header................ok
t/03-question..............ok
t/04-packet-unique-push....ok
t/04-packet................ok
t/05-rr-opt................ok
t/05-rr-sshfp..............ok
t/05-rr-txt................ok
t/05-rr-unknown............ok
t/05-rr....................ok
t/06-update................ok
t/07-misc..................ok
t/08-online................ok
t/09-tkey..................ok
t/10-recurse...............Server [194.134.5.5] did not give answers at /tmp/.webmin/Net-DNS-0.53/bl
ib/lib/Net/DNS/Resolver/Recurse.pm line 85.
Server [194.134.5.5] did not give answers at /tmp/.webmin/Net-DNS-0.53/blib/lib/Net/DNS/Resolver/Rec
urse.pm line 85.
# Failed test in t/10-recurse.t at line 91.
# got: undef
# expected: '3'
# Looks like you planned 12 tests but only ran 9.
# Looks like you failed 1 test of 9 run.
dubious
Test returned status 1 (wstat 256, 0x100)
DIED. FAILED tests 9-12
Failed 4/12 tests, 66.67% okay
t/11-escapedchars..........# Using the XS compiled dn_expand function
# disabling XS based dns_expand for a moment.
# Continuing to use the XS based dn_expand()
ok
t/11-inet6.................#
# The libraries needed for IPv6 support have been found
# Now we establish if we can bind to ::1
# Testing for global IPv6 connectivity...
# preparing...
# Trying to connect to ns-pri.ripe.net (2001:610:240:0:53:0:0:3)
ok
3/6 skipped: No answer available to analyse
Failed 1/23 test scripts, 95.65% okay. 4/1076 subtests failed, 99.63% okay.
Failed Test Stat Wstat Total Fail Failed List of Failed
t/10-recurse.t 1 256 12 7 58.33% 9-12
10 subtests skipped.
make: *** [test_dynamic] Error 255 |
- het instellen van andere nameservers (/etc/resolv.conf)
- door het draaien van een caching dns (bind):
chmod a+x /etc/rc.d/rc.bind;
/etc/resolv.conf: nameserver 127.0.0.1
Velen die leven verdienen de dood en sommigen die sterven verdienen het leven.
