Problemen op het einde van branden CD met Nero.
  • 100 views sinds 30-01-2008
  • abusimbal
  • Laatst online: 11-08 23:31
Hallo, ik heb sinds kort het probleem dat ik geen CD's meer kan branden.
Alles lijkt goed te gaan tot het einde.
HP DVD writer DVD630i
Dan krijg ik onderstaand probleem; HP
1A25-0006-7130-1356-5695-6301
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 28/05/2003 17:53:46
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 18:35:34
Nero Version: 6.6.0.18
Internal Version: 6, 6, 0, 18e
Recorder: <HP DVD Writer 630c> Version: AH02 - HA 0 TA 0 - 6.6.0.18
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <HL-DT-ST DVD-ROM GDR8163B>Version: 0C21 - HA 0 TA 1 - 6.6.0.18
=== Scsi-Device-Map ===
CdRomPeripheral : HP DVD Writer 630c atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8163B atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST3200822AS atapi Port 1 ID 0 DMA: On
DiskPeripheral : ST3200822AS atapi Port 2 ID 0 DMA: On
CdRomPeripheral : SCSIVAX DVD/CD-ROM 2.7a Vax347s Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
HP DVD Writer 630c F: CDRom0
HL-DT-ST DVD-ROM GDR8163B G: CDRom1
SCSIVAX DVD/CD-ROM L: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2047MB (2096428kB)
Free physical memory: 1424MB (1458628kB)
Memory in use : 30 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
5.12.2005
CD-ROM (ISO)
19:59:44 #1 Text 0 File Isodoc.cpp, Line 6359
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
19:59:44 #2 Text 0 File Burncd.cpp, Line 2948
HP DVD Writer 630c
Bescherming tegen buffer-underrun geactiveerd
19:59:44 #3 Text 0 File Reader.cpp, Line 127
Reader running
19:59:44 #4 Text 0 File Writer.cpp, Line 122
Writer HP DVD Writer 630c running
19:59:44 #5 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
19:59:44 #6 Text 0 File Burncd.cpp, Line 3233
Turn on Track-At-Once, using CD-R/RW media
19:59:44 #7 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 359847 ( 79:59.72)
Last address to be written: 274239 ( 60:58.39)
19:59:44 #8 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
19:59:44 #9 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: HP DVD Writer 630c;
CDR code: 00 97 26 45; OSJ entry from: FUJI Photo Film Co., Ltd.
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
19:59:44 #10 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
19:59:44 #11 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 274240 (274240) = #274240/60:56.40
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 274238 blocks [HP DVD Writer 630c]
19:59:44 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [HP DVD Writer 630c] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 561950720, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
274240 | lead-out | 1 | 0x41 | 0x00
19:59:44 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1119
Removed 2 run-out blocks from end of track 1. Length: 274240 -> 274238.
19:59:45 #14 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
19:59:45 #15 Text 0 File Burncd.cpp, Line 4122
Cache writing successful.
19:59:45 #16 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
19:59:45 #17 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 40x (6.000 kB/sec)
19:59:45 #18 SCSI -1189 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03A45200
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0x40 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x30 0x02
19:59:45 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:59:45 #20 Text 0 File Mmc.cpp, Line 21774
Set BUFE: Buffer underrun protection -> ON
20:02:18 #21 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
20:02:26 #22 SCSI -1135 File Cdrdrv.cpp, Line 1182
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x35 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x0C 0x00
20:02:26 #23 CDR -1135 File ThreadedTransferInterface.cpp, Line 2104
Write error
20:02:26 #24 TRANSFER -18 File ThreadedTransferInterface.cpp, Line 2104
Could not perform EndTrack
20:02:26 #25 Text 0 File Mmc.cpp, Line 16452
<HP DVD Writer 630c > start Close Session
20:03:04 #26 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 40x (6.000 kB/sec)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 28/05/2003 17:53:46
File 'Drivers\PXHELP20.SYS': Ver=2.03.27a, size=20576 bytes, created 26/01/2005 2:03:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 3/08/2004 22:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Ik heb op GOT gezocht, de meeste mensen konden dit oplossen door Nero opnieuwe te installeren.
Ik heb Nero verwijderd door bij software op verwijderen Nero te klikken.
Dit heeft niet geholpen.
Ik heb ook problemen in Alcohol 120% alsmede ook een CD-RW snel te wissen in Nero.
Deed ik de uninstall en install goed ?
Bestaat er een programma om DVD-writers te testen ?
Andere suggesties ?
Bij voorbaat dank en vriendelijke groeten.
  • abusimbal
Ik denk dat ik het zelf gevonden heb !
Alles deinstalleren en opnieuw installeren hielp niet zoals ik hierboven al aangaf.
Wat wel hielp was de registry checker op de Nero site.
http://www.nero.com/nero6..._and_RegistryChecker.html
