[ASP.NET] Meerdere selecties listbox
  • 52 views sinds 30-01-2008
Hallo. Ik moet de geselecteerde values uit een Listbox, in de WHERE zetten van de SQL-query. Als ik het volgende doe, krijg ik slechts de eerst geselecteerde, de rest wordt genegeerd. Hoe kan ik mijn code zo wijzigen dat de andere geselecteerden ook meeneem?
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
<%@ Page Language="C#" AutoEventWireup="true"  CodeFile="Default.aspx.cs" Inherits="_Default" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns:t ="urn:schemas-microsoft-com:time">
<head runat="server">
    <?import namespace="t"
      implementation="#default#time2">
    <style>
        BODY { background: url("design.gif"); background-repeat: no-repeat;}
        .time {behavior: url(#default#time2);}
    </style>
    <title>IBSTEST</title>
</head>
<body>
    <form id="form1" runat="server">
    <div>
        <asp:Panel ID="Panel1" runat="server" Height="50px" Width="125px" Visible="true">
            <asp:SqlDataSource ID="SqlDataSource2" runat="server" ConnectionString="<%$ ConnectionStrings:50469ConnectionString %>"
                SelectCommand="SELECT * FROM [ibs] ORDER BY [liedTitel]"></asp:SqlDataSource>
            <asp:ListBox ID="ListBox1" runat="server" DataSourceID="SqlDataSource2" DataTextField="liedTitel"
                DataValueField="liedID" Font-Names="Arial" Font-Size="X-Small" Height="300px"
                SelectionMode="Multiple" Width="175px"></asp:ListBox><br />
            <br />
            <asp:Button ID="Button1" runat="server" Text="Play" OnClick="Button1_Click" Height="25px" Width="75px" /></asp:Panel>
        <br />
        <asp:Panel ID="Panel2" runat="server" Height="50px" Width="349px" Visible="false">
        <asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="<%$ ConnectionStrings:50469ConnectionString %>"
            SelectCommand="SELECT * FROM [ibs] WHERE ([liedID] = @liedID) ORDER BY NEWID()">
            <SelectParameters>
                <asp:ControlParameter ControlID="ListBox1" Name="liedID" PropertyName="SelectedValue"
                    Type="Int16" />
            </SelectParameters>
        <asp:Repeater ID="Repeater1" runat="server" DataSourceID="SqlDataSource1">
            <HeaderTemplate>
                <t:seq repeatCount="1">
            </HeaderTemplate>
            <ItemTemplate>
                <t:par>
                <t:audio dur='<%# DataBinder.Eval(Container.DataItem, "liedDuur") %>s' src='<%# DataBinder.Eval(Container.DataItem, "liedID") %><%# DataBinder.Eval(Container.DataItem, "liedExtensie") %>' type='<%# DataBinder.Eval(Container.DataItem, "liedType") %>' />
                <div dur='<%# DataBinder.Eval(Container.DataItem, "liedDuur") %>s' class="time" timeAction="display">
                Titel: <%# DataBinder.Eval(Container.DataItem, "liedTitel") %><br />
                Artiest: <%# DataBinder.Eval(Container.DataItem, "liedArtiest") %></div>
                [img]'<%#[/img].jpg' />
                </t:par>
            </ItemTemplate>
            <FooterTemplate>
                </t:seq>
            </FooterTemplate>
        </asp:Repeater>
            <br />
            <br />
            <asp:Button ID="Button2" runat="server" Height="25px" OnClick="Button2_Click" Text="Stop"
        <br />
        &nbsp;</div>
    </form>
</body>
</html>
Hoop dat iemand mij kan helpen, hartelijk dank. Kin Wei.
  • Daos
Als je gewoon de specs leest, dan zie je dit in het voorbeeldje staan:
Visual Basic:
' Iterate through the Items collection of the ListBox and
' display the selected items.
Dim item As ListItem
For Each item in ListBox1.Items
  If item.Selected Then
    Message.Text &= item.Text & "<br>"
  End If
Next
Je moet zelf maar bedenken hoe je dat kan gebruiken in je code.
  • whoami
  • Laatst online: 30-10 12:27
Dit kon je gewoon wel uit de MSDN halen; gewoon ff kijken naar de properties en methods van listbox en listitem.
Verder was het ook niet nodig om hier de hele lap code te posten.
https://fgheysels.github.io/
