Blauw scherm / spelen lopen vast
  • 29 views sinds 30-01-2008
hallo
heb probleem met spellen die lopen steeds vast 1x zie ik van microsoft en bericht dat hij gecrasht is met bekende "niet verzenden of verzenden"
andere keer krijg ik blauw beeld!!!!
system:
Number of CPUs 2 (1 Physical)
CPU#1 APIC ID = 0
Name Intel Pentium 4
Code Name Prescott
Specification Intel(R) Pentium(R) 4 CPU 3.00GHz
Family / Model / Stepping F 3 3
Extended Family / Model 0 0
Package mPGA-478
Core Stepping C0
Technology 90 nm
Supported Instructions Sets MMX, SSE, SSE2, SSE3
CPU Clock Speed 3013.5 MHz
Clock multiplier x 15.0
Front Side Bus Frequency 200.9 MHz
Bus Speed 803.6 MHz
L1 Data Cache 16 KBytes, 8-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 1024 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 3013.5 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
CPU#2 APIC ID = 1
CPU Name Intel Pentium 4 (logical unit)
Mainboard and chipset
Motherboard manufacturer MSI
Motherboard model MS-7008, 1.0A
BIOS vendor American Megatrends Inc.
BIOS revision Version 07.00T
BIOS release date 04/02/01
Chipset VIA PT880 rev. 00
Southbridge VIA VT8237 rev. 00
Sensor chip Winbond W83697HF
FSB Select 800 MHz
Graphic Interface AGP
AGP Status enabled, rev. 3.5
AGP Data Transfer Rate 8x
AGP Max Rate 8x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 200.9 MHz
FSB:DRAM 1:1
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
# of memory modules 2
Module 0 Kingston DDR-SDRAM PC3200 - 512 MBytes
Module 1 Kingston DDR-SDRAM PC3200 - 512 MBytes
Software
Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX version 9.0c
videokaart = nvidea 6600 GT 128 mb ram 8 x agp
alvast bedankt voor het verhelpen van het probleem!!
  • Phreak
  • Laatst online: 09:26
Phreak
KTM SuperDuke
Wat zijn je temperaturen wanneer je pc vastloopt?
Wat voor onderdelen heb je nog meer in je pc, hardeschijven enz...
Dit kan misschien een voeding probleem aanduiden.
Als je een blauw scherm krijgt staat daar ook een stopcode in, wat voor code is dit?
Heb je al b.v. een keer memtest gedraait om je geheugen te testen?
Neem even de Hangen en Opstartproblemen troubleshooter door.
Welkom op GoT btw... :Y)
Blyatifull
  • BalusC
BalusC
Carpe diem
Sorry, maar dit is echt niet de manier om een "Help, mijn PC doet het niet!" topic te starten :) We kunnen namelijk nergens uit je topicstart afleiden wát je allemaal wel niet met behulp van o.a. de FAQ van dit subforum hebt uitgezocht, uitgevonden, uitgeprobeerd danwel uitgesloten. Dat wordt hier op GoT wel van je verwacht, zoals de [faq]registratievoorwaarden[/] je uitlegt.
Begin hier: PMG Beleid en probeer het opnieuw :)
