PHPtriad
  • 53 views sinds 30-01-2008
  • Taenadar
  • Laatst online: 19:36
Ik heb phptriad geinstalleerd. Een maandje of 2 werkte dit allemaal heel erg perfect. Maar nu werkt het opeens niet meer. Als ik bijvoorbeeld apache wil starten. Krijg ik dit:
"); system("c:\apache\Apache -n \"Apache\" -k start &") or die ("
Back to Index"); print("Apache Service Started
Back to Index"); } elseif ($action == "stop") { print("Stopping Apache Service
"); system("c:\apache\apache -n \"Apache\" -k shutdown &") or die ("
Back to Index"); print("Apache Service Named \"Apache\" Stopped
Back to Index"); } elseif ($action == "restart") { print("Stopping Apache Service
"); system("c:\apache\apache -n \"Apache\" -k restart &") or die ("
Back to Index"); print("Apache Service Named \"Apache\" Restarted
Back to Index"); } elseif ($action == "install") { print("Installing Apache as Service
"); system("c:\apache\apache -i -n \"Apache\" &") or die ("
Back to Index"); print("Apache Service Named \"Apache\" Installed
Back to Index"); } elseif ($action == "uninstall") { print("Uninstalling Apache as Service
"); system("c:\apache\apache -u -n \"Apache\" &") or die ("
Back to Index"); print("Apache Service Named \"Apache\" Uninstalled
Back to Index"); }elseif ($action == "test") { print("Testing Apache Service Settings
"); system("c:\apache\apache -n \"Apache\" -t &") or die ("
Back to Index"); print("Apache Service Named \"Apache\" Settings
Back to Index"); }elseif ($action == "editconf") { print("Opening httpd.conf
"); system("notepad C:\apache\conf\httpd.conf") or die ("
Back to Index"); print("httpd.conf Opened.
Back to Index"); }elseif ($action == "showlogs") { print("Opening Logs
"); system("notepad C:\apache\logs\error.log") or die ("
Back to Index"); system("notepad C:\apache\logs\access.log") or die ("
Back to Index"); print("Logs Opened.
Back to Index"); } else { print("No action to perform"); } } apache($action); ?>
Heel fijn dus. Ik verwijder phptriad. Installeer opnieuw, ik dacht van joepie nu werkt het weer. Nee dus nog steeds het zelfde. Even nieuwe downloaden van die site. Misschien had ik wel oude versie ofzo, maar nee nog steeds niks. Nog 50 x geprobeert. Maar nu werkt me hele php niet eens meer. Ik heb php.exe aanstaan maar verder gebeurt er niks.
Hoe krijg ik dit weer werkend want het is best wel lastig want het werkt zo makkelijk. :)
- ik werk trouwens met windows xp.
[ Voor 16% gewijzigd door Taenadar op 25-11-2005 17:39 ]
  • aex351
  • Laatst online: 04:13
aex351
I am the one
Begrijp er niets van. Maar om je toch om weg te helpen :
www.apache.org - http server
www.php.net - php
www.mysql.com - mysql
downloaden en installeren.
< dit stukje webruimte is te huur >
  • marko77
  • Laatst online: 06-05-2025
je kan ook ff easyphp proberen, daar heb ik erg goede ervaringen mee.
Mijn rig
  • whoami
  • Laatst online: 30-10 12:27
In P&W bieden we geen ondersteuning op software van 3den.
Probeer het support forum van phptriad eens.
https://fgheysels.github.io/
  • Creepy
  • Laatst online: 22:34
Creepy
Tactical Espionage Splatterer
Je hebt dus zelfs niks geprogrammeerd? Waarom open je dan een topic in Programming & Webscripting?
Een puur installtie probleem zou je kunnen openen in Software Algemeen echter verwachten we iets meer eigen inzet dan dat je nu toont. In elk geval zou je eens kunnen aangeven wat je nu zelf precies hebt geprobeerd en wat daar niet mee lukte. Alleen een her-installatie is hier niet voldoende voor ;)
Omdat er nogal wat informatie mist sluit ik je topic i.p.v. dat ik het verplaats naar Software Algemeen. Mocht je een nieuw topic willen openen doe dat dan op de juiste plek en let AUB op het faq/beleid topic aldaar zodat je in elk geval een goede startpost hebt ;)
Edit: * Creepy mept whoami
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
