[PHP] class geeft alleen maar true
  • 61 views sinds 30-01-2008
Ik heb een domeincheck.class.php
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
class domeincheck
        function domeincheck($dnames)
            if(!isset($dnames) && $dnames!="")
             if(stristr($dnames,"http://") || stristr($dnames,"www."))
                if(stristr($dnames,"http://"))
                    $dnames=str_replace("http://","",$dnames);
                if(stristr($dnames,"www."))
             $dnames=str_replace("www.","",$dnames);
             while ($i < mb_strlen($dnames))
              { $punt = mb_substr($dnames,$i,1);
                if ($punt == ".")
                 $ext    = mb_substr($dnames,$i+1,mb_strlen($dnames)-$s);
                $dnames = mb_substr($dnames,0,$i);
                $punt="";
                     if(!preg_match('/^[a-z0-9]+$/i',$dnames))
                       $IDNcheck=TRUE;
                      $IDN = new idna_convert();
                      $idomain = $IDN->encode($dnames);
                        $search="$idomain.$ext";
                 if($ext=="com" || $ext=="net"||$ext=="org" || $ext=="COM" || $ext=="NET"||$ext=="ORG")
                        $NICserver="whois.internic.net";
                      if(stristr($domain, "xn--") && $IDNcheck=false){$search="$dnames.$ext";}
                        elseif(preg_match('/^[a-z0-9]+$/i',$dnames) && $IDNcheck=false) {$search="$dnames.$ext";}
                $i=$i+1;
                      $socket = fsockopen("$NICserver", 43);
                      if(!$socket)
echo "<font face='Arial' size='1'>failed to retreive $dnames.$ext , <B>$NICserver</B> probably doesn't exist.<BR>\n  A possible cause is the inexistence of the extension <B>$ext</B> .<BR>\n     Or the whois server is temporarily unavailable or overloaded.<BR>\n </font>";
                      }else
                                fputs($socket,"$search \n");
                                //echo "$search";
                                while(!feof($socket))
                                 $output .= fgetss($socket,128);
                                fclose($socket);
                                if(stristr($output,"No match"))
                                    return true;
                                 }else {
                                        return false;
Deze code wordt hierin aangeroepen :
PHP:
29
30
31
32
33
34
    if(!empty($_POST) && $dnames!="" && isset($dnames))
     mb_internal_encoding("UTF-8");
    $dnames =preg_replace('/\s\s+/',' ',$dnames); // de meervoudige spaties worden vervangen door enkelvoudige spaties
    $dnames=trim($dnames);
    $length=mb_strlen($dnames);
     $string=explode(" ",$dnames);
     $n=0;
    while($n<count($string))
         $check=new domeincheck();
         $name=$string[$n];
         $dcheck[$n]=$check->check($name);
         $n=$n+1;
     //$wsearch=new domeincheck();
     //the array is processed with the whois-search(for which a .class would be nifty) and the result is shown in a table
      $n=0;
        $name=$string[$n];
        echo "<h3>";
        if($dcheck[$n]=true){echo "$name is available";}
        else{echo "$name is reserved";}
       echo "</h3>";
       $n=$n+1;
Het probleem is nu dat deze klasse alleen maar true uitpoept, het lijkt erop alsof die functie uberhaupt niet wordt uitgevoerd aangezien het binnen een seconde gebeurd is.
[ Voor 35% gewijzigd door Verwijderd op 23-11-2005 18:58 ]
  • webfreakz.nl
  • Laatst online: 23-02 22:08
webfreakz.nl
el-nul-zet-é-er
Ok, leuk dat je een eigen domeincheck script maakt? Maar er zijn er toch al honderden van dus zonde van je tijd? Of is het gewoon om te leren...
Just my 2¢
"You smell that, son? What sir? Napalm, I love the smell of napalm in the mornin!" || Children of Bodom fan!
  • degroot
webfreakz.nl schreef op woensdag 23 november 2005 @ 19:01:
Sjah met zon instelling kun je net zo goed niet programmeren.
heel het internet staat vol met scripts en dergelijke , dus jij wilt zeggen dat niemand meer hoeft te programmeren want er zijn toch overal al scripts voor 8)7
Waarschijnlijk is deze jongen het gewoon aan het leren en vind hij het leuk om dit te maken , dont blame on him
EDIT:
PHP:
Moet dit niet zijn:
PHP:
if($dcheck[$n]==true){echo "$name is available";}
Dus 2x het = teken
nu zeg je bij het eerste dat die variabelen de waarde van TRUE moet bevatten , niet dat hij gelijk moet zijn aan TRUE.
mijn optie controleert dus of de variabele gelijk is aan TRUE
[ Voor 29% gewijzigd door degroot op 23-11-2005 19:07 ]
www.degroot-it.nl
  • whoami
  • Laatst online: 30-10 12:27
een class kan niets returnen, een functie kan dat wel.
Daarbij komt jouw post bij mij over als: ziehier mijn code, hij moet dat doen, maar dat doet hij niet; debug het ff voor mij.
Dat is hier echter niet de bedoeling; het is de bedoeling dat jij, als topicstarter, zelf al eens gekeken hebt waarom het niet werkt (debuggen). Als je er echt niet uitkomt, kan je altijd een topic openen, maar hier ontbreekt toch wel wat debugwerk van jouw kant.
https://fgheysels.github.io/
