[Ervaringen] Gigabyte GA-K8NXP-SLI
  • SmoothTweaker
Zijn er al mensen met ervaringen met dit moederbord ik kan hier op tweakers er maar weinig nog over vinden hier alvast paar specificaties.
Het lijkt mij wel een mooi SLi Moederbord. Ben zelf van plan om deze denk ik op de HCC dagen te gaan halen of jullie moeten er zulke slechte ervaringen erover hebbenAfbeeldingslocatie: http://www.maurice0.dutchweb.nl/photo_k8nxp-sli_big
Processor
Socket 939 supports AMD Athlon64 X2/ 64 FX/ 64
Chipset
NVIDIA nForce4 SLI MCPs (media and communication processors)
Super I/O: ITE IT8712 chip
Integrated peripherals
Silicon Image sil 3114 controller
T.I. IEEE1394b controller
Marvell 8053 Gigabit Ethernet controller
CICADA8201 Gigabit LAN PHY chip
Realtek ALC850 Audio AC'97 Codec
Memory
Type: Dual channel DDR400/ 333/ 266 -184pin
Max capacity: Up to 4GB by 4 DIMM slots
Internal I/O Connectors
8 x Serial ATA connector (4 X Serial ATA 3.0Gb/s)
2 x UDMA ATA 133/100/66 Bus Master IDE connectors
1 x FDD connector
3 x USB 2.0/1.1 connectors (supports 6 ports)
2 x IEEE 1394b connectors (supports 3 ports)
3 x cooling fan pin headers
CD in
Expansion Slots
2 x PCI-Express X 16 slot, supports two PCI-Express interface Graphics cards with SLI mode
2 x PCI-Express X 1 slots
2 x PCI slots (PCI 2.3 compliant)
Rear Panel I/O
4 x USB 2.0/1.1 ports
2 x RJ45 ports
Audio (4 x Line-out/ 1 x Line-in/ 1 x MIC) connector
Coaxial S/PDIF input/ output function
PS/2 Keyboard/ Mouse
1 x COM port
1 x LPT
CPU/AGP/DIMM setting
CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
PCI-ExpessX16 Voltage / Clock adjustable via BIOS
DIMM Voltage / Clock adjustable via BIOS
Power
ATX power connector and ATX 12V connector
Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
ATX form factor
30.5 x 24.4 cm
H/W Monitoring
System health status auto-detect and report by BIOS
Hardware detecting and reporting for case open, CPU voltage, and fan speed
BIOS
2 X 4M bit flash ROM, Award BIOS
Other Features
NVIDIA SLI multi-GPU support
Dual Power System (DPS)
802.11g compatible Wireless adapter
Support NVIDIA Firewall
Norton Internet Security
Download Center
XpressTM Installation
XpressTM Recovery
Q-FlashTM
@BIOSTM
[ Voor 14% gewijzigd door SmoothTweaker op 25-11-2005 10:13 ]
Hoi, ik wil zelf al een tijdje een A8N-E gaan kopen, maar begin nu toch te twijfelen door alle topics die ik hier lees en omdat ik nog een oude diamondmax10 schijf heb.. die schijnt voor forse problemen te zorgen.
Nu de vraag, is dit bord een goed alternatief voor de A8N-E?
Hmm.. niet te duur? :o
Gigabyte GA-K8NXP-SLI, nForce4 SLI (Sound, LAN, SATA II RAID) € 140,-
Ik hoef geen SLi... welke Gigabyte zouden je me aanraden voor onder de 90 euro?
[ Voor 28% gewijzigd door Verwijderd op 22-11-2005 20:06 ]
  • webfreakz.nl
  • Laatst online: 23-02 22:08
webfreakz.nl
el-nul-zet-é-er
Verwijderd schreef op dinsdag 22 november 2005 @ 20:06:
pricewatch: Gigabyte GA-K8NF-9, nForce4-4X (PCI-e, Sound, LAN, SATA, RAID, 1394B)
"You smell that, son? What sir? Napalm, I love the smell of napalm in the mornin!" || Children of Bodom fan!
Heb jij daar ervaring mee?
Jammer dat ie geen NForce 4 Ultra chip heeft maar de nForce4-4X chip...
[ Voor 60% gewijzigd door Verwijderd op 22-11-2005 20:31 ]
  • LoneWolf
  • Laatst online: 14-10-2025
LoneWolf
Just a Byte
De GA-K8N Ultra-9 schijnt dus niet voor SLI bedoeld te zijn, maar heeft wel 8 SATA (waarvan 4x Sata
II) en kost ook wat minder, al is het dan nog steeds boven de € 100,=
zie hier voor een review van dat bord
Life is to short to mess with it... Mijn V&A
  • BovenHond
  • Laatst online: 07:15
Verwijderd schreef op dinsdag 22 november 2005 @ 20:29:
Maar uit diverse test is gebleken dat het verschil tussen de NForce 4 Ultra en nForce4-4x verwaarloosbaar klein is.
De Gigabyte heeft wel een pasieve chipset kloeling
  • SmoothTweaker
Idd dat vind ik mooiste die passiefe koeling. maar pricewatch klopte niet nee bord is idd 140 euro de GA-K8N Pro-Sli was 106 euro
  • M.I.G.
  • Laatst online: 06-01 13:48
M.I.G.
[like an alien]
Ik heb zelf die GA-K8NF-9 en is een lekker bordje.
Ik heb wel ff moeten rommelen om de standaard houder met backplate eraf te krijgen om deze te vervangen voor de Zalman CNPS7000B-Cu.
In combinatie met de 7800GTX van Gigabyte geen enkel probleem ermee :)
  • webfreakz.nl
webfreakz.nl
el-nul-zet-é-er
M.I.G. schreef op vrijdag 25 november 2005 @ 10:18:
Ik heb ook de K8NF-9 maar heb jij er Cool&Quiet op zitten? En werkt de Nvidia-firewall goed bij jou?
(Ik gebruik nog de F3 BIOS, die kwam er standaard bij, maar de F8 BIOS is al 'leverbaar')
