[asp.net] pagina wordt niet getoond
Op een Windows 2003 server draait IIS6. De pagina default.aspx wordt niet getoond als je vanaf een werkstation deze pagina opvraagt. Een testpagina zoals hieronder werkt wel.
<html>
<head>
<title>Example 1: Hello World</title>
</head>
<body bgcolor=white>
<h1>
<% response.write("Hello World") %>
</h1>
</body>
</html>
Dit is de inhoud van de default.aspx. Deze werkt niet.
<%@ Page CodeBehind="Default.aspx.vb" language="vb" AutoEventWireup="false" Explicit="True" Inherits="DotNetNuke.Framework.CDefault" %>
<%@ Register TagPrefix="dnn" Namespace="DotNetNuke.Common.Controls" Assembly="DotNetNuke" %>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML>
<HEAD id="Head">
<TITLE>
<%= Title %>
</TITLE>
<%= Comment %>
<META NAME="DESCRIPTION" CONTENT="<%= Description %>">
<META NAME="KEYWORDS" CONTENT="<%= KeyWords %>">
<META NAME="COPYRIGHT" CONTENT="<%= Copyright %>">
<META NAME="GENERATOR" CONTENT="<%= Generator %>">
<META NAME="AUTHOR" CONTENT="<%= Author %>">
<META NAME="RESOURCE-TYPE" CONTENT="DOCUMENT">
<META NAME="DISTRIBUTION" CONTENT="GLOBAL">
<META NAME="ROBOTS" CONTENT="INDEX, FOLLOW">
<META NAME="REVISIT-AFTER" CONTENT="1 DAYS">
<META NAME="RATING" CONTENT="GENERAL">
<META HTTP-EQUIV="PAGE-ENTER" CONTENT="RevealTrans(Duration=0,Transition=1)">
<style id="StylePlaceholder" runat="server"></style>
<asp:placeholder id="CSS" runat="server"></asp:placeholder>
<asp:placeholder id="FAVICON" runat="server"></asp:placeholder>
<script src="<%= Page.ResolveUrl("js/dnncore.js") %>"></script>
<asp:placeholder id="phDNNHead" runat="server"></asp:placeholder>
</HEAD>
<BODY ID="Body" runat="server" ONSCROLL="__dnn_bodyscroll()" BOTTOMMARGIN="0" LEFTMARGIN="0"
TOPMARGIN="0" RIGHTMARGIN="0" MARGINWIDTH="0" MARGINHEIGHT="0">
<noscript></noscript>
<dnn:Form id="Form" runat="server" ENCTYPE="multipart/form-data" style=”height:100%;>
<asp:Label ID="SkinError" Runat="server" CssClass="NormalRed" Visible="False"></asp:Label>
<asp:placeholder id="SkinPlaceHolder" runat="server" />
<INPUT ID="ScrollTop" runat="server" NAME="ScrollTop" TYPE="hidden">
<INPUT ID="__dnnVariable" runat="server" NAME="__dnnVariable" TYPE="hidden">
</dnn:Form>
</BODY>
</HTML>
Wat staat hier fout? ASP werkt toch gewoon? Iemand een idee waar ik dit verder moet zoeken?
  • BtM909
BtM909
Watch out Guys...
Je mag je code gerust tussen [norml]
ASP:
[/] tags plaatsen; maakt het wat leesbaarder :)
Het resultaat:
ASP.NET:
<html>
<head>
</head>
<h1>
</h1>
</body>
</html>
Als je IIS6 draait, wat voor meldingen zie je precies in je log verschijnen?
Ik zie trouwens dat je ASPX gebruikt en standaard ASP voor je voorbeeld. Is ASPX wel geconfigureerd?
stomme vraag wellicht... maar waar kan ik die log bekijken van IIS 6? Op de Windows 2003 server en dan Systeembeheer - Logboeken?
Toevoeging:
Rechtstreeks op de server wordt het bestand default.aspx wel getoond. Alleen vanaf een andere pc niet. Lijkt me dat aspx wel goed geconfigureerd is.
[ Voor 40% gewijzigd door Verwijderd op 21-11-2005 14:10 ]
  • CaptBiele
  • Laatst online: 13-06 11:32
CaptBiele
No Worries!
Verwijderd schreef op maandag 21 november 2005 @ 14:09:
Toevoeging:
makkelijk: start > uitvoeren > eventvwr
Er zijn geen meldingen in het logboek... ik start vanaf een andere pc http://ip nummer/dotnetnuke/default.aspx maar zie niets veranderen in het logboek :?
  • CodeCaster
CodeCaster
Stop AI Slop
Daar staan je IIS logbestanden ook niet.
Die staan in de map die je opgeeft bij IIS -> "Eigenschappen van site" -> "Vastleggen in logboek" -> Eigenschappen.
Wat voor melding zie je op je scherm als je de pagina op een client opvraagt?
[ Voor 33% gewijzigd door CodeCaster op 21-11-2005 16:05 ]
Waar is de brand, meester?
  • Not Pingu
  • Laatst online: 07-10 08:47
Not Pingu
Dumbass ex machina
Toevoeging:
In Dotnetnuke staat het alias van je portal standaard op localhost. Als je dus via een andere URL naar je DotNetnuke site gaat, zal ie redirecten naar het standaard alias. En dat gaat dus fout op remote computers want daar wil ie dan ook de localhost van opvragen.
Ga in Dotnetnuke naar Admin -> Site settings -> Portal Aliases, en voeg een portal alias toe met het adres vanwaar je je DNN site wilt bereiken.
[ Voor 5% gewijzigd door Not Pingu op 21-11-2005 16:08 ]
Certified smart block developer op de agile darkchain stack. PM voor info.
