Trackmania Sunrise Extreme server opzetten*
  • 169 views sinds 30-01-2008
  • FiXeR.nl
Hallo, ik heb Trackmania Sunrise Extreme. Nu wil ik een server starten alleen kan niemand joinen... jammer genoeg...
nu heb ik al de poorten open staan, en ik heb wat hieronder ook geprobeert, alleen snap ik er geen snars van :S
Heeft iemand een goede nederlandse beschrijving? Of ervaring/tips.. ik hoor het graag..
Dit topic is niet alleen voor mezelf, maar ook nog voor andere mensen.. SAMEN komen we er zelfs niet uit ;)
FF specs van de router...
IEEE 802.11g Wireless ADSL Router
You need to know your IP address. Get this from www.whatismyip.com or check your router utility s/w if you use a router..
*If no router on Win XP with SP2*
Start\ control panel\ security centre
Click Windows Firewall button
Click advanced tab
In Network connection settings area, click settings button
Under services tab click Add button
In Description of service type ''Trackmania''
In External AND internal port number type 2350
In Name or IP address box, put your IP address. If you dont know it, go to
www.whatismyip.com and write down the number to put in
Click the TCP radio button then click ok.
Under services tab click Add button again
In Description of service type ''Trackmania'' again
In External AND internal port number type 2350 again
Click the UDP radio button then click ok
Now just close down the open windows.
Start trackmania and on the start up screen click Configure then advanced
button
On the Network Tab set server port to 2350, client port to 0
In ''Force server address'' type your IP address
Do not tick ''Use local address'' unless you use a router or are on a network which has an IP assigning component
leave everything else blank.
Now start and set up a server. It should run ok.
Note: If your ISP provides you with a dynamic IP address (most do) then you will
need to check your IP address now and then and update the above to suit the
new IP address.
You could off course turn off your firewall, but this leaves you wide open to abuse. So why chance it when the above is so easy?
*If you use a router *
You can do the above but also:
In your #router utility software you need to set up a virtual server.
To do this you need to know the IP address your router assigns to your pc. There will be a specific number so hunt around the router software till you find it.
[Edit]If you can''t find it do Start/Run type ''cmd'', press enter. In the dos box type ''ipconfig'' then press enter. Note the ip address, then shut down the dos box.[/Edit]
This is a different number to the ISP IP address!
Now add a port, give it an id (anything) if asked, give a public port AND private port of 2350 when/if prompted, click UDP. If asked for a host IP give the router assigned IP address.
Now add another port, give it an id (anything) if asked, give a public port AND private port of 2350 when/if prompted, click TCP. If asked for a host IP give the router assigned IP address again.
button
In ''Force server address'' type your [Edit]ISP given[/Edit] IP address
Tick ''Use local address''.
Thats it! I''ve used this method to run trackmania for a year on XP and Win 98 on 2 different servers.
BTW. When you get up and running, on a 512k broadband connection, 16 players is about maximum before lag starts to set in. Thats a years experience talking, so don''t set your player level too high. Lag is the one thing that will get your visitors slagginbg you off.
Edit: Just for reference, EVERYONE gets the message about the NAT problem, whether they can host or not, so ignore it, go make a cup of tea, and give people a chance to join.
One more thing. You ISP will periodically change your IP address (unless you pay for a fixed IP address, most don''t), so check it before you run your server, and make adjustments if necessary.
[ Voor 9% gewijzigd door Crash op 17-11-2005 21:51 ]
  • Crash
  • Laatst online: 17-10 11:25
Titeltweak + wat overbodige [ubb] code uit je startpost verwijdert :)
  • FiXeR.nl
Ik wil geen server OPZETTEN, maar gewoon een game opzetten en zelf er op spelen, en me buurjongen kan joinen..
  • FiXeR.nl
Zo stil...
  • Hahn
  • Laatst online: 16-10 20:20
Het is mij een beetje onduidelijk waarom anderen niet kunnen joinen. Krijgen ze je hele server niet te zien? Of als ze direct proberen te verbinden krijgen ze dan een foutmelding? Zo ja, wat voor een foutmelding.
The devil is in the details.
  • FiXeR.nl
Cannot join the server....
  • FiXeR.nl
En het is precies het zelfde bij mijn buurjongen, en we hebben zeker zo'n uur zitten te kloten...
  • Crash
FiXeR.nl schreef op zaterdag 19 november 2005 @ 11:45:
Jij host de game, dus in feite zet je een server op :)
Ennuh... we hebben hier ook een edit-knopje. Je hoeft dus niet 2x onder elkaar te posten ;)
  • FiXeR.nl
i knuw, maar het internet stoorde ff :)
  • FiXeR.nl
Niemand?
