[PHP/MySQL] Datetime omzetten in NL formaat
  • 311 views sinds 30-01-2008
Beste mensen, ik kom er ff niet uit en zou wel wat hulp kunnen gebruiken.
Ik heb een gastenboek gemaakt, hieronder de code:
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
include("../Script/connect.inc.php");
// Aantal berichten per pagina
$count = 5;
// hoogste id ophalen
$max_id_query = mysql_query("SELECT max(guestbook_ID) FROM guestbook");
$max_id = mysql_fetch_array($max_id_query);
// $count aantal berichten ophalen uit de database, nieuwste eerst
if(!isset($_GET['pos'])){
  $guestbook_query = mysql_query("SELECT * FROM guestbook ORDER BY guestbook_ID DESC LIMIT ".$count);
}else{
  $guestbook_query = mysql_query("SELECT * FROM guestbook WHERE guestbook_ID < ".($_GET['pos']+1)." ORDER BY guestbook_ID DESC LIMIT ".$count);
// Vorige link
  $new_pos_next = $max_id[0] - $count;
}else{
  $new_pos_next = $_GET['pos'] - $count;
if($new_pos_next >= 1){
  $link_next = "<a href=guestbook_adv.php?pos=".$new_pos_next.">volgende >></a>";
}else{
  $link_next = "volgende >>";
  $new_pos_prev = $max_id[0] + $count;
}else{
  $new_pos_prev = $_GET['pos'] + $count;
if($new_pos_prev-$count < $max_id[0]){
  $link_prev = "<a href=guestbook_adv.php?pos=".$new_pos_prev."><< vorige</a>";
}else{
  $link_prev = "<< vorige";
// Hier de items uit de database lezen en weergeven
while($guestbook_data = mysql_fetch_array($guestbook_query))
<link href="../Script/style.css" rel="stylesheet" type="text/css">
<table width="400" border="0" cellspacing="0" cellpadding="0" align="center">
  <tr>
    <td width="250" height="25" class="news_tekst"><?php echo $guestbook_data['guestbook_name'] ?></td>
        <td width="150" height="25" class="news_plaats" align="right"><?php echo $guestbook_data['guestbook_datetime'] ?></td>
  </tr>
  <tr>
    <td colspan="2" class="news_main"><?php echo $guestbook_data['guestbook_text'] ?></td>
  </tr>
  <tr>
    <td colspan="2"><hr width='400' size='1' noshade></td>
  </tr>
</table>
<?php
  <tr>
    <td class="login_hyperlink">
          <?php echo $link_prev . " " . $link_next ?>
        </td>
  </tr>
</table>
Nu is het probleem dat de datum in een 0000-00-00 00:00:00 volgorde wordt weergegeven, dat is natuurlijk ook logisch omdat het zo uit de db komt. In de db heb ik het veld guestbook_datetime als type 'datetime' meegegeven. Dit omdat de berichten op datum (en tijd) gesorteerd moeten worden. Werkt allemaal prima maar ik zou graag het formaat 00-00-0000 00:00:00 willen toepassen.
Na een tijdje zoeken en proberen begrijp ik het volgende, ik zou een query kunnen toepassen waarin ik date_format gebruik. Helaas heb ik geen idee hoe dat dan precies toe te passen in bovenstaande code. Verder kreeg ik de volgende code van een maat van me:
PHP:
function GeefDieGodVerdommeseDatumGoedWeer($sqldatum) {
    $positie = strpos($sqldatum, "-");
    $jaar = substr($sqldatum, 0, $pos);
    $restdatum = substr($sqldatum, $pos+1);
    $positie = strpos($restdatum, "-");
    $maand = substr($restdatum, 0, $pos);
    $dag = substr($restdatum, $pos+1);
    $jouwdatum = $dag . "-" . $maand . "-" . $jaar;
Hiermee zou het ook moeten kunnen, helaas begrijp ik ook niet goed hoe ik dit werkend zou kunnen maken.
Zou iemand me ff kunnen helpen?
Ik ben zelf voorstander voor de query oplossing...
[ Voor 31% gewijzigd door NMe op 15-11-2005 16:43 ]
  • dip
  • Laatst online: 16-01-2023
dip
shut up ulé
SELECT DATE_FORMAT(COALESCE(guestbook_datetime, CURRENT_DATE), '%d-%m-%Y') AS datum FROM guestbook
bij %d-%m-%Y kan je zelf de gewenste teruggave opgeven
[ Voor 36% gewijzigd door dip op 15-11-2005 14:18 ]
It's scientifically known, that base improves the tase of cheezes!
  • disjfa
  • Laatst online: 21-10 16:41
disjfa
be
PHP:
setlocale(LC_ALL, nl_NL.ISO8859-1);
echo strftime("%m %Y", $datum);
Even uit mn hoofd . strftime voor hoe je deze wilt inelkaar zetten.
Ik zie dat die setlocale niet eens nodig is. Je wilt alleen maar de nummertjes omdraaien :P
[ Voor 61% gewijzigd door disjfa op 15-11-2005 14:19 ]
disjfa - disj·fa (meneer)
disjfa.nl
Ik voel me noob :)
Krijg die kut query niet werkend, waar en hoe zou ik die moeten inbouwen?
  • dip
dip
shut up ulé
aan de hand van deze site moet het toch lukken :)
  • NMe
  • Laatst online: 28-10 12:53
NMe
Quia Ego Sic Dico.
Verwijderd schreef op dinsdag 15 november 2005 @ 15:05:
Ik voel me noob :)
Als je eerst eens zegt wat je al geprobeerd hebt komen we verder. ;)
Trouwens, als je code post, wil je dat dan tussen [code] of [code=taal] tags doen? Dit is gewoon niet te lezen. Ik zal je startpost even voor je aanpassen, doe je het de volgende keer zelf?
  • JKVA
JKVA
Design-by-buzzword fanatic
dip schreef op dinsdag 15 november 2005 @ 14:17:
Je ziet dat Dip er een alias achterzet waarmee hij de kolom als het ware 'hernoemt' naar 'datum'?
Dan moet je het in je PHP code ook zo aanroepen, en niet met 'guestbook_datetime'.
Als dit niet de oorzaak is, weet ik het ook zo snel niet. Dan moet je even aangeven wat er echt mis is. :P
@dipje: Ik zie overigens het nut niet van die coalesce :)
[ Voor 11% gewijzigd door JKVA op 15-11-2005 19:26 ]
Fat Pizza's pizza, they are big and they are cheezy
  • dip
dip
shut up ulé
stfu @ JK :)
kheb dit uit jouw werk geknipt :-)
maar je hebt wel gelijk. COALESCE vervangt de return waarde door een bepaalde variabele wanneer de huidige return waarde niets teruggeeft, en dat is in dit geval niet relevant.
Dus schrijven we het maar als volgt:
SQL:
SELECT DATE_FORMAT(guestbook_datetime, '%d-%m-%Y') AS datum FROM guestbook
[ Voor 3% gewijzigd door dip op 15-11-2005 19:46 ]
PHP:
$admin = 1;
$count = 5;
$test = mysql_query("SELECT DATE_FORMAT(guestbook_datetime, '%d-%m-%Y') AS datum FROM guestbook");
$test2 = mysql_fetch_array($test);
if ($admin == 1)
   echo $test2
Ik heb dit geprobeerd, ik krijg echter de waarde 'array' dan van $admin.
Het word tijd voor een basis cursus php :)
[ Voor 16% gewijzigd door Verwijderd op 17-11-2005 18:03 ]
  • Observer
  • Laatst online: 30-10 10:37
Verwijderd schreef op donderdag 17 november 2005 @ 18:02:
PHP:
$admin = 1;
$count = 5;
if ($admin == 1)
   echo $test2
Allicht, $test2 is het resultaat van een mysql_fetch_ARRAY(). Je kan de datum nu ophalen met $test2['datum'].
Basiscursusje is idd nooit verkeerd...
There are 10 kinds of people in the world: those that understand binary and those that don't
  • maartenba
  • Laatst online: 26-10 19:03
Misschien ben je met deze 2 functietjes nog wel iets:
PHP:
* mysqldate2phpdate - MySQL Date to PHP Date
function mysqldate2phpdate($pDate) {
  $year = substr($pDate, 0, 4);
  $month = substr($pDate, 5, 2);
  $day = substr($pDate, 8, 2);
  $hour = substr($pDate, 11, 2);
  $min = substr($pDate, 14, 2);
  $sec = substr($pDate, 17, 2);
  return mktime($hour, $min, $sec, $month, $day, $year);
* phpdate2mysqldate - PHP Date to MySQL Date
function phpdate2mysqldate($pDate) {
  return date("Y-m-d H:i:s", $pDate);
  • disjfa
disjfa
be
maartenba schreef op vrijdag 18 november 2005 @ 14:51:
Waarom zou je extra functies maken als er al tig php eigen data conversie functies zijn.
disjfa.nl
  • NMe
NMe
Quia Ego Sic Dico.
disjfa schreef op vrijdag 18 november 2005 @ 14:52:
Sowieso kun je de inhoud van die eerste functie door één regel vervangen:
PHP:
return strtotime($pDate);
Daarnaast klopt de functienaam niet met wat de functie doet (hij converteert niet alleen de datum, maar ook de tijd). Sterker nog, beide functies gaan hele gekke dingen doen als je ze alleen een datum voert. 8)7
PHP:
$admin = 1;
$count = 5;
if ($admin == 1)
   echo $test2
Hoe kan het dat je een compleet gastenboek heb geschreven dat werkt, en je toch nog zo'n beginnersfout maakt als deze? Je doet het in de rest van je gastenboek toch ook goed? :?
  • MissingDog
Ik gebruik zelf vaak deze constructie, zodat ik de losse elementen van de datum beschikbaar heb (inmiddels mooie display functie omheen gebouwd).
$mysqldate is de datum zoals deze uit de DB komt.
PHP:
list($year,$month,$day,$hour,$minute,$second) = sscanf($mysqldate,"%4s-%2s-%2s %2s:%2s:%2s");
nevermind...zit met bier @ kantoor en had niet goed gelezen. Wat je eventueel nog kunt gebruiken voor je query is de MySQL TIMESTAMP() functie...zodat je een nette unix timestamp terugkrijgt, hiermee kun je vervolgens alles wat je wilt.
[ Voor 29% gewijzigd door MissingDog op 18-11-2005 18:55 ]
  • DemonTPx
  • Laatst online: 19-10 18:35
Verwijderd schreef op dinsdag 15 november 2005 @ 14:12:
*KNIP*
PHP:
*KNIP*
Is het iemand opgevallen dat er een $positie gemaakt wordt. En dat er een $pos gebruikt wordt?! :o
NCIS schreef op vrijdag 18 november 2005 @ 11:59:
Het is inderdaad triest hoe simpel, ik moet af en toe wat meer rust nemen... :)
Bedankt!
  • NMe
NMe
Quia Ego Sic Dico.
Nee, juist wat minder rust nemen en wat meer zelf opzoeken. ;) Dit staat allemaal ook gewoon in de manual. :)
-NMe- schreef op vrijdag 18 november 2005 @ 15:00:
Ik ben nogal wazig en chaotisch in m'n hoofd zo nu en dan. Op het ene moment kun je een gastenboek maken en een moment later zie je simpele oplossingen zoals hierboven niet meer.
Ik ben blij dat jullie tijd en moeite in de oplossing (voor mij) hebben willen steken..
Bedankt!
(slotje kan erop)..
-NMe- schreef op zaterdag 19 november 2005 @ 12:00:
De shrink wil toch dat ik wat meer rust neem.. ;)
