Point of View 6800GX 128MB AGP
  • 143 views sinds 30-01-2008
Bij Komplett staat een POV 6800GX te koop. Deze is gebaseerd op de 6800 core. Alleen zijn de clockspeeds hoger.
http://www.komplett.nl/k/ki.asp?sku=313321&cks=PRL
core: 360 / mem: 850 ( 2.8 ns DDR )
http://www.pointofview-online.com/products/index.php
Heeft iemand hier al ervaring mee? Ik kan er weinig over vinden.
Een koper van Komplett die een review heeft geschreven :)
Dr Bolouswki:
This unit falls somewhere between a standard 6800 and a 6800GT Default speeds on it are 350/850 and 12/5 on pipes and shaders.
The pipelines and shaders are hardware masked by the manufacturer. Riva tuner can unlock these, but you have to be lucky for them both to function. I am able to unlock the remaining vertex shader on mine without any problems. However, unlocking the pipelines sadly gives me artifacts. The new forceware Nvidia drivers have an overclocking feature that allows you to increase core/memory speeds quite easily, so get these too.
From a starting 3Dmark05 score of 3988 I rose almost 10% in performance to 4324 by simply enabling the vertex shader and pushing the core/memory speeds a bit.
The card has DVI and VGA and TV out. The box comes with drivers and some utilities (Overclocking etc) and a tv-out cable and handily a DVI to VGA adaptor for anyone looking to dual monitor (DM supported on VGA only). 3 Years hardware warranty is standard.
A decent card, with good overclocking potential, even for a novice (first overclocking I have done!). For anyone wishing to delay the expense of either a high-end card, or switching totally over to PCI-E, it's the way to go.
http://www.komplett.ie/k/ki.asp?sku=313321&cks=SPC
Volgens mij wel een nette kaart
Hier iemand die een lekkere score haalt
http://img402.imageshack.us/my.php?image=6800gx3yq.jpg
http://www.hwupgrade.it/f.../index.php/t-1038664.html
[ Voor 8% gewijzigd door Verwijderd op 11-11-2005 00:21 ]
  • XanderDrake
  • Laatst online: 20:56
XanderDrake
Build the future!
Die is nieuw :) . Ik kende em nog niet.
Ziet er uit als een of andere special "vanilla" editie. Niet slecht, 360/850mhz stock.
Als ie unlockbaar is, is tie gebaseerd op de NV40. Tot nu toe heb ik er goede ervaringen mee dus, ik zou het doen, of wachten tot ie goedkoper wordt.
Hephaestus: Xeon 2680 v2 - 64GB ECC Quad - WD Blue 3D 1TB
Virtualis: Ryzen 3700X - 16GB DDR4 - Gigabyte 1080 Ti OC - Sandisk 2TB - Valve Index
Agon:Valve Steam Deck 64GB
Non scholae sed vitae discimus Seneca
  • GoldenSample
GoldenSample
Huub, Huub, Barbatruc!
sh*t, had dit topic niet gezien, zat er net in het 6800GT topic een stukje over te schrijven... klik
Ja het is iig DDR en geen DDR3 zoals bij komplett staat aan gegeven.
Er zijn genoeg op vooraad dus wachten kan nog wel even. :)
Wil eingenlijk graag wel weten of ie een beetje valt te unlocken. 1 Vertexshaders is ook al leuk.
  • Mastasidaz
  • Laatst online: 07-06 18:26
Leuke kaart, is die niet een soort GS met lagere clockspeeds?
[ Voor 6% gewijzigd door Mastasidaz op 10-11-2005 18:25 ]
  • JPS43
  • Laatst online: 23-11-2021
Ik heb deze kaart onlangs gekocht, erg tevreden (10430 3dmarks '03), en met rivatuner gemakkelijk unlocked naar 16/6 ipv 12/5 (scheelde zo'n 1000 3dmarks '03).
JPS
