Trident Video Accelerator 96XX/938X
  • 179 views sinds 30-01-2008
  • steef321
  • Laatst online: 20-11-2023
Mensen:
Een laptop AMD K6 333MHZ met WinXPPro waarvan de
Trident Video Accelerator 96XX/938X als beeldschermadapter na ongeveer een half uur steeds ophangt, d.w.z. de comp uitschakelt.
Comp wordt autom weer opnieuw opgestart met die melding en als reden een ernstige systeemcrash in die beeldschermadapter.
De melding van Watchdog:
// Watchdog Event Log File
LogType: Watchdog
Created: 2005-11-03 19:29:20
TimeZone: -60 - West-Europa (standaardtijd)
WindowsVersion: XP
EventType: 0xEA - Thread Stuck in Device Driver
// The driver for the display device got stuck in an infinite loop. This
// usually indicates a problem with the device itself or with the device
// driver programming the hardware incorrectly. Please check with your
// display device vendor for any driver updates.
EventCount: 10
BreakCount: 10
BugcheckTriggered: 1
DebuggerNotPresent: 1
DriverName: tgiul50
Shutdown: 0
ShutdownCount: 4
EventFlag: 1
DeviceClass: Display
DeviceDescription: Trident Video Accelerator 96XX/938X
HardwareID: PCI\VEN_1023&DEV_9660&SUBSYS_00000000&REV_D3
Manufacturer: Trident MicroSystems
DriverFixedFileInfo: FEEF04BD 00010000 00050000 099E000F 00050000 099E000F 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverCompanyName: Trident Microsystems Inc.
DriverFileDescription: Trident Display Driver
DriverFileVersion: 5.1.2462.0015 (ReleasedBinaries.010308-1115)
DriverInternalName: tgiul50.dll
DriverLegalCopyright: Copyright © Trident Microsystems 1990-1998
DriverOriginalFilename: tgiul50.dll
DriverProductName: Trident Video Driver
DriverProductVersion: 5.1.2462.0015
sysdata.xml
[knip]
</DRIVER>
<DRIVER>
<FILENAME>tgiulnt5.sys</FILENAME>
<FILESIZE>138528</FILESIZE>
<CREATIONDATE>10-29-2005 15:08:52</CREATIONDATE>
<VERSION>5.0.2462.15</VERSION>
<MANUFACTURER>é</MANUFACTURER>
<PRODUCTNAME>
Trident Video Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
[knip]
Overigens in apparaatbeheer geen uitroeptekentje of iets dergelijks.
Ik begreep uit sommige (oude) berichten op inet al dat de videodriver nogal gammel blijkt te zijn, maar zijn er oplossingen (behalve nw videokaart)? Want het lijkt er ook op dat er weinig updates zijn geweest, sterker nog dat dit de nieuwste/ meest recente driver is.
  • steef321
Ik dacht dat hier nog wel wat tweakers rondhingen.
Is er echt niemand die hier iets op weet/ over te zeggen heeft of gaat dit iedereen boven zijn pet? ;-)
  • Teun_2
  • Laatst online: 31-08 08:16
Goh, als de win9x drivers al niet te stabiel zijn, zullen ze dat zeker niet zijn onder xp. Bovendien lijkt het me ook geen goed idee om winxp op die bak te draaien, als je voldoende ram hebt, dan kan je win 2000 proberen, maar daarmee is je videokaartprobleem nog niet opgelost. Mij lijkt het beste om win98se erop te zetten, daar is je laptop immers voor gemaakt.
  • Calvin&Hobbes
  • Laatst online: 17-08 17:00
Volgens mij zijn er van Trident niet eens drivers voor XP wel 2000, ME en 98SE, wel knap dat je XP erop kan draaien bij mij AMD-450 draait win98se al langzaam.
