[Win2K Server] Active Directory Verwijderen
  • 238 views sinds 30-01-2008
  • HarryL
  • Laatst online: 13-08 10:19
HarryL
127.0.0.1
Ik probeer een Windows 2000 server te depromoveren als DC, Active Directory te verwijderen, alleen nu krijg ik dus met DCPromo de volgende foutmelding:
The operation failed because:
The Directory Service failed to replicate off changes made locally.
"The DSA operation is unable to proceed because of a DNS lookup failure. "
Ik heb alles gecontroleerd, DNS en alles staat ookgoed....
Op google kan ik niet bepaald een oplossing vinden...
I have gone to find myself, if I get back before I return, Please keep me here! PSNID: djmagich
  • cOOlrUnnINgs
  • Laatst online: 28-08 14:15
Wat voor events vind je terug in je eventviewer ????
  • HarryL
HarryL
127.0.0.1
Event Type: Information
Event Source: DNS
Event Category: None
Event ID: 708
Date: 10/18/2005
Time: 10:15:21 AM
User: N/A
Computer: EXCHANGE001
Description:
The DNS server did not detect any zones of either primary or secondary type. It will run as a caching-only server but will not be authoritative for any zones. For more information, see the online Help.
  • HarryL
HarryL
127.0.0.1
Event Type: Warning
Event Source: NtFrs
Event ID: 13508
Date: 10/18/2005
Time: 10:28:34 AM
User: N/A
Description:
The File Replication Service is having trouble enabling replication from \\fs1.Intoit to EXCHANGE001 for c:\winnt\sysvol\domain using the DNS name \\fs1.Intoit. FRS will keep retrying.
Following are some of the reasons you would see this warning.
[1] FRS can not correctly resolve the DNS name \\fs1.Intoit from this computer.
[2] FRS is not running on \\fs1.Intoit.
[3] The topology information in the Active Directory for this replica has not yet replicated to all the Domain Controllers.
This event log message will appear once per connection, After the problem is fixed you will see another event log message indicating that the connection has been established.
Data:
0000: 00 00 00 00 ....
  • cOOlrUnnINgs
Zoek de eventID's eens op op www.eventid.net. Hier kun je veel informatie vinden over events en wat je daar aan kan doen.
  • Zwelgje
  • Laatst online: 17-08 09:02
post je ip gegevens van die DC eens.. (ipconfig /all)
* Zwelgje vermoed een dns probleempje..
Ik heb alles gecontroleerd, DNS en alles staat ookgoed.... dat bepalen wij wel voor je :)
[ Voor 33% gewijzigd door Zwelgje op 18-10-2005 10:54 ]
  • HarryL
HarryL
127.0.0.1
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : exchange001
Primary DNS Suffix . . . . . . . : Intoit
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : Intoit
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : intoit
Description . . . . . . . . . . . : 3Com EtherLink XL 10/100 PCI TX NIC
(3C905B-TX)
Physical Address. . . . . . . . . : 00-10-4B-7B-21-68
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.32
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.2
DNS Servers . . . . . . . . . . . : 192.168.1.2
Primary WINS Server . . . . . . . : 192.168.1.2
Lease Obtained. . . . . . . . . . : Tuesday, October 18, 2005 10:52:36 A
M
Lease Expires . . . . . . . . . . : Wednesday, October 26, 2005 10:52:36
AM
  • FastBunny
  • Laatst online: 23:24
FastBunny
Give it the Works !
DHCP enabled op een Domain Controller :? is 192.168.1.2 je andere DC of is dat een router of iets dergelijks?
Server: Dell PowerEdge R610, 48GB DDR3 1333MHz, 3 x 4TB IronWolf RAID5, Dell H700, VMware ESXi 6.0
Laptop: Dell Latitude E6510, Intel i5-560m, 8GB RAM, 128GB Samsung SSD, 250GB 7200rpm, 15.4" WUXGA FHD
PSN: FastBunny_NL
  • HarryL
HarryL
127.0.0.1
1.2 is een andere DC...
had DHCP aan gezet voor testing purposes ;)
staat inmiddels weer uit en server heeft weer vast IP...
  • Zwelgje
single label dns :X
dat kan nog wel eens je probleem zijn
http://support.microsoft....aspx?scid=kb;en-us;300684
had onlangs bij een klant (door een extern bedrijf ingericht domain) ook problemen met ad/exchange met single label dns.. kan wel maar je moet wat dingen aanpassen (zie ook link)
[ Voor 71% gewijzigd door Zwelgje op 18-10-2005 11:04 ]
  • HarryL
HarryL
127.0.0.1
En dit is makkelijk aan te passen?
Hoe aan te passen??
(3C905B-TX)
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.4
Default Gateway . . . . . . . . . : 192.168.1.2
  • Zwelgje
DjMaGiCh schreef op dinsdag 18 oktober 2005 @ 11:00:
Hoe aan te passen??
(3C905B-TX)
nee is niet makkelijk aan te passen :)
hoeveel servers/users/workstations heb je in dat domain? ik mag voor je hopen dat het voor thuis is, anders heb je een fijn probleem
  • HarryL
HarryL
127.0.0.1
2 servers
3 users
3 werkstations
Ja sorry, maar wij gaan je probleem niet voor je oplossen. Ik zie in het verloop van dit topic 0,0 zelfwerkzaamheid en dat is niet de manier waarop dit forum werkt. Er zijn genoeg handreikingen gedaan, het is nu tijd zelf e.e.a. te proberen.
