Acer Travelmate 4101 WLMi probleem (keyboard)
Allereerst de specs, dan weten jullie waar ik het over heb:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
Item    Specification
Processor   Intel Pentium-M 715 (1.6 GHz, 400MHz FSB, 2MB L2 cache)
RAM 512MB 333MHz DDR (2x256MB - No free slots)
Chipset Intel Alviso 915GM Centrino
System bus  PCI Express (Intel 82801FB)
Video   Intel 915GM Extreme (Shared memory - 16MB @ TFT res. - Max 64MB)
Screen  1280x800 WXGA widescreen (16:10) TFT
Wired NIC   Broadcom BCM4401 10/100 base-TX
Wireless NIC    Intel Prowireless 2200GB
Hard drive  Hitachi Travelstar IC25N080ATMR04-0 80GB ATA100 4200RPM 9.5MM
Optical drive   Pioneer DVR-K15RA DVD+/-RW burner
Sound   Intel 82801FB AC'97 (ICH6) Audio
Modem   Intel 82801FB AC'97 (ICH6) Softmodem
USB Intel 82801FB USB 2.0
Keyboard    (88-/89-key Acer FineTouch™ keyboard) 89-key Windows keyboard plus 4
programmable keys and a button each for bluetooth and wireless kill. I should point out that the
keyboard is an ergonomic, curved "smiley" shape. Initially this reduced my typing accuracy since
the keys weren't quite where I expected them to be. The key feel is nice though.
Rodent  Reported by X to be a Synaptics Touchpad. Also has a 4-way scroll rocker between the mouse buttons
Ports   3x USB 2.0
    1x Infrared (FIR)
    1x VGA for external monitor
    1x PC Card slot (Type II) Texas Instruments
    1x S-video out (NTSC/PAL)
    1x IEEE 1394 port (4-pin small [iLink] connector)
    1x Modem (RJ-11) port
    1x Ethernet (RJ-45) port
    1x speaker/ headphone/ line-out jack
    1x microphone/ line-in jack
Charger/PSU 100-240V in 19V 3.42A out 65W
Power Consumption   65W (OK for airline in-seat power - Airline power adaptor not supplied)
Omdat er bij de aanschaf Windows XP Home op stond en het 1 en ander aan acer meuk, heb ik een complete format gedaan en er Windows XP Pro SP2 opgezet en die acer meuk achterwegen gelaten. Met Acer meuk bedoel ik dingen als eManager, ePower Manager, eLaunch Manager...
Nu doet het probleem zich voor dat ik na de installatie alles werkt m.u.v. de 'speciale' toetsen op het toetsenbord. Ik bedoel toetsen als het euroteken boven <- en het dollar teken boven de -> cursor toetsen. Tevens Alt Gr + 5 levert geen euroteken meer. Ten slotte werkt aanhalingsteken en vervolgens een e voor in het woord 1 niet meer.
Nu ben ik opzoek gegaan naar een driver voor het zogenaamde 88-/89-key Acer FineTouch™ keyboard, maar heb het niet mogen vinden via de Acer site of ftp, ook zoeken via Google had geen resultaat. Op tweakers ben ik alleen twee topic tegen gekomen waarin men het over twee acer notebooks als geheel had.
Heeft iemand dit probleem ook wel eens gehad en een oplossing gevonden of heeft iemand de gouden tip voor mij?
MvG, Ties
PS. Excuus als ik dit topic onder de verkeerde sectie heb geplaatst...
  • Damsplaat
  • Laatst online: 07-10 20:02
volgens mij zijn dan gewoon de taalinstellingen vor je tobo niet goed. ieder taalinstelling heeft een andere manier van omgaan met euro-tekentjes (ik gebruik altijd Alt+0128) en puntjes op de e.
Wat betreft de é is het opgelost een ook Alt Gr + 5 levert €, maar die speciale toetsen boven de cursor links en rechts werken nog niet.
