Smc 2602 onder linux laten werken
  • 165 views sinds 30-01-2008
  • amauer
  • Laatst online: 23-10 22:32
Mede tweakers,
Voor Wireless Leeuwarden zijn wij bezig linux nodes te bouwen. Als wireless kaartjes gebruiken wij 2 gedoneerde smc 2602`s. De Wireless lan kaart gebruikt de ADMtek8211 chipset.
Nou ben ik niet zo bekend in de linux wereld. Dus ik ben opzoek gegaan op internet etc.
Helaas heb ik niks kunnen vinden om de kaartjes goed aan de gang te brengen. Wel het volgende:
I have been looking for a card to put in my Linux box and was tolod this SMC2602W would work! Is this a PCI card or a PCI card that a PCMCIA card slides into? I have seen two pictures of the card and both were different. Any way tech support from SMC wrote this e-mail to me of how to install: Follow these instructions to see if it works! I would like to know before I spend my money.
Please follow the below to install your SMC2602Wv.2 802.11b wireless
Adapter
1. Power on, make sure you have the privilege of superuser, and login as
root.
2. Download the "SMC2602Wv.2.tar.gz" into the "/usr/src" directory.
3. Run the following commands:
#cd /usr/src
#tar zxvf SMC2602Wv.2.tar.gz
#cd Install
#./install
When run the "./install" command you will see the following screen.
ADM8211 install begin....
Which type do you want to install ADMtek8211 WLAN driver(1/2)?
1. CardBus
2. mini PCI/PCI
Please type 2 and click the enter key.
4. #netconfig
Please use the command to configure your network.
#init 6 ----- reboot the system
5. After login the system, please run the following commands:
#ifconfig
Please check the WLAN adapter is eth0 or eth1
I assume the WLAN card is eth0 and the AP uses the channel 6.
#iwconfig eth0 channel 6
#iwconfig eth0 essid any
#cd /etc/rc3.d
#./S10network restart
If you set the WLAN card is the DHCP clinet and run the /S10network restart,
you see the following message.
Determining IP information for eth0...failed; no link present. Check cable?
Please run the follow command to obtain the IP address again.
#cd /sbin
#dhclient eth0
Als ik het zo bekijk zou het moeten werken. Maar het bestandje met de driver die ze gebruiken bestaat niet meer op de server. Ook google vind niks over het bestandje.
De fabrikant van de chip had eerst linux drivers voor het wireless kaartje. Maar het bedrijf is overgenomen door een ander bedrijf die de drivers heeft weggehaald.
Weet iemand nog op een andere manier hoe ik die kaartjes aan het werk krijg?
Met ndiswrapper kun je in sommige gevallen de windows drivers gebruiken.
  • Exirion
  • Laatst online: 11:38
Exirion
Gadgetfetisjist
Verwijderd schreef op zaterdag 15 oktober 2005 @ 23:28:
De 2602 wordt niet ondersteund. De 2802 wel. Been there, done that :)
  • marcelk
Hou trouwens ook in de gaten dat er verschillende versies bestaan van dat kaartje van het EU type. Een "standaard", versie 2 en versie 3. Dus waarschijnlijk ook andere chipset.
Kijk hier voor de specs : http://www.smc.com/index....riteria&localeCode=EN_NLD
[ Voor 30% gewijzigd door marcelk op 16-10-2005 12:16 . Reden: EU type toegevoegd ]
  • Exirion
Exirion
Gadgetfetisjist
marcelk schreef op zondag 16 oktober 2005 @ 12:12:
Een "standaard", versie 2 en versie 3. Dus waarschijnlijk ook andere chipsets.
Klopt, voor de V3 versie met AMD chipset bestaat wel een driver van AMD maar het is mij nooit gelukt die goed aan de praat te krijgen zonder dat alles volledig crasht. Overigens werkt ie alleen met 2.4 kernels. Ik gebruik 2 SMC 2802 V2 kaarten die vlekkeloos met ndiswrapper werken. Prima performance en absoluut stabiel.
Bij jouw chipset is het verhaal qua driver support niet veel anders, maar misschien heb je hier iets aan:
http://www.mines.edu/stud...DM8211_src_105_2.6.tar.gz
Begeleidende topic: http://www.linuxquestions...hread.php?threadid=132161
[ Voor 23% gewijzigd door Exirion op 16-10-2005 12:21 ]
